Question about Makita DCS51018 18" 45cc Chain Saw 2 Cycle
Husky 460 chains too long (or is the bar too short)
I got a new 460 last month. The chain was a tad too long for the bar. After a few hours cutting, it was fully adjusted and there was no more room to take up the slack. I had bought a Sthil replacement chain when I got the saw, so I put that on. There was less than a quarter inch left on the adjustment screw when tightened. After a few more hours of cutting, it too had stretched beyond adjustment. I've been cutting for many years and always use Husqvarna. I've never seen this problem on any other saw.
  • 1 more comment
  • mcfadden586 Jan 23, 2009
    Oops. I meant to put the brand in my initial post. Husqvarna 460 with 20" bar. That's the new model upgrade of the 455 rancher. I can see that happening once (the dealer put the original bar on), but twice?
  • mcfadden586 Jan 26, 2009
    Yes, I follow the standard procedure. I'm taking it to the shop today. Seems the trigger is failing and the kill switch has quit working. This is my fifth Husqvarna (two 55's, a 365, and a 372xp) and I've never had any problems with the earlier ones, except a 55 Rancher that quit idling after a couple of years. No amount of tweaking the carb would permanently fix the problem. The 365 was stolen (hence the 372) and this 460 is supposed to replace the no-idle 55.
  • mcfadden586 Feb 04, 2009
    My first solution was to put on a 18" bar and chain. That had plenty of adjustment room. I then took it back to the dealer. They couldn't do a thing. Seems there's a flaw in the 460 chain cover that puts the adjustor screw in the wrong place. I'm basically screwed with dealing with 71 link chains (I hate that) until/if Husky owns up to the problem and issues a corrected chain cover plate. This saw uses the same 3/8 bar as the 372.
    Problem Solver:
  • 11 Answers
I'm am guessing the bar is not a stock bar or was miss matched at purchase by the dealer.
Have dealer look up factory bar to see what was original and either go with that or if you already have it. ask for a new rim sprocket with 1 extra tooth. If you don't have a replacable sprocket then best bet would be to have chains custom build which usually is the same price, if they treat you right.
Remember the new sprocket MUST be the same pitch and width of your chain and bar and they do make a large and small ID also.
Last resort If not wanting to trash a new bar or change out sprocket, run a couple chains when they get loose have your dealer take out a link.
Also a stihl 20" can be a 72 drive link chain where a husky could be a 70 or other.
Everything must be matched, hard nose bar is exception.
Bill Czerkie
Posted on Feb 03, 2009
  • bczerkie Feb 04, 2009
    Add a tooth or 2 on the drive sprocket, should be able to run a 72 then. Will increase chain speed but lower, low end power, but with higher speed it will cut faster just be careful of high speed at no load. why we love to hear them run wide open at no load is just a Man thing, but be careful.
    In the app I m looking at there is a dfferent listing for the 372 and 460 bar.
    Have to look close but one bar fits many saws and the 372 and the other fits many saws and the 460 but niether lists both..
    looks like not 100% iterchangable.
    Scholar:
  • 140 Answers
Hello, your bar may not be seating on the adjusting pin properly.Like you I have cut thousands of cords used every saw made and the only time something like this happens is when the adjuster isn't seating properly. Give me your model number and I'll try and round up a manual for you.
Posted on Jan 23, 2009
  • David Robinson Jan 24, 2009
    I know this sounds dumb but, when you are tightening the chain do you loosen both nuts, lift the tip of the bar up and the tighten the nuts tight. After you do that use the adjusting knob to finish tightening. My Stihl is different but, my ( don't laugh ) Sears Craftsman ( made by Husky ) is the same as yours.
Own a 450 husky saw tool less and cut 4or5 blocks of wood chain completely loose im tighting goof buy loosens.
Hi Dale:
Here's the process that I use. Have a look and see if it works for you.
1) Slacken the nuts that clamp the bar to the saw.
2) Lift the tip of the bar and hold it up through the next 2 steps.. This will put the most slack to the chain.
3) Use the adjuster screw to tighten the chain until it will barely clear the groove when you lift it at the centre of the bar.
4) Still holding the tip up, tighten the nuts that you loosened at step 1.
Should work fine now.
Here's a tip. It never hurts to occasionally clean the bar and chain assembly. Dismantle it, keep the parts organized unless you know where they fit. Use solvent to loosen all the grunge. I like to use air to blast it all off.
The ONLY way a chain can loosen if the bar is solidly mounted is if the chain stretches or "wears". Make sure the chain oils system is functioning, and that the chain is properly sharpened so that it does not over-heat.
My old husky 266 just keeps running!
Cheerfuls!
Nov 11, 2015 | Husky Garden
Tested my new chain saw to see if the chain was getting oil. no sign of it after several minutes operating time. back to the retailer???
if you put the correct chain bar oil in the tank and it is not wetting the bar after a few minutes then take it back or take it to a service dealer and check why
It is not a stream as such as the small amount of oil in the tank will last around 1/2 hour of cutting
Jun 12, 2015 | Garden
I have a husky 235 (e = ?) & it has been very troublesome for me. My little 3000 Echo saw i purchased in 1995 (& have had refurbished once since then) outshines the husky reliability-wise. On the...
The oiling on this model has been an issue for a long time, the first and main problem was distortion of the bar pad due to heat from the muffler, and the ommision of a metal strengthener in the pad itself, what happens then is as the bar nuts are tightened, the bolts try to pull throught the bar pad, this creates a bulge around the bar bolt and causes the delivery tube to collapse, there was a later crankcase with steel inserts around the bar bolts to prevent this, and an updated delivery tube, you can tell when this has happened as the oil drips onto your shoes rather than going onto the chain, let me know it you need any more advice or i have not explained this very well, what has the dealer said about the oiling problem?
Apr 15, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
New 460 rancher 20" bar and chain cuts at an
It sounds like your chain is just dull.Or might not be sharpened right.This usually happens when the chain is getting dull.
Mar 09, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
Husquvarna 460 rancher 20" bar all new including
The normal reason for a saw to cut to the left, or right is because the cutters have been sharpened more on side than the other, they are now longer on one side, this then sends the cut off to that side. Measure the cutter lenghts, take the correct file and shorten the longer cutters
Mar 06, 2011 | Husqvarna 20" 60cc Rancher Chain Saw 460
I have a 460 rancher brand new and it cuts crooked it cuts to the left. i have tried several chains. it has a 20" bar. any ideas?
The chain may have the procedure but the driver plate is worn out - what happens when you are not attached to the chain lubrication oil lubrication channels or if the chain is about or when the pump is not working.
I'm using a Poulan 3416 and it's simply not cutting my neighbor and I used it last weekend to cut up fallen trees but it doesn't cut at all now?
It may sound oversimplified but....is your chain sharp? Is the chain on backwards?
When cutting you should be getting nice big chips from the cut. If you are getting more "dust" than chips the chain is dull and needs to be resharpened.
There is no set "time" to sharpen a chain,but you will only get a few hours of cutting before the chain dulls. In soft wood like pine you can go longer. In hardwood like oak or locust you may get an hours worth of cutting. If the bar digs into the ground or hits a rock it's time to sharpen right then because the chain will be dull.
I always carry an extra chain or two just for emergencies like hitting a rock or some wire in a tree.
May 17, 2010 | Garden
Poulan 2375 w/18 inch bar keeps throwing the chain
when you put the chain on new did you adjust the tension on the chain.most new chains need to be ran a few minutes to heat them up a little.then you need to readjust chian so it doesn't sag out of the bottem of the bar,also when you adjust the chain you need to push the tip of the bar down so the bar is in the up possition.if you don't the bar will work it's way up and loosen the chain.
Feb 24, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Makita DCS51018 18" 45cc Chain Saw 2 Cycle Logo
431 people viewed this question
Top Makita Garden Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you a Makita Garden Expert? Answer questions, earn points and help others
