Question about Vicks V150 Humidifier
Debris in vics vaporizer - Vicks V150 Humidifier
Where do the vapor pads go
most humidifiers have an area near the vaor outlet to set the vaor pads. as the vapor comes out it creates an effect that allows the essence of the vapor to be released and rides along with the vapor. see if there is a flat spot or an area that the pads would sit. Please always keep manuals or instructions. I keep mine in a file in the drawer that is easy to find them. I just label it "MANUALS".. If I replace a unit I find the instructions and toss them
Feb 27, 2015 | Vicks Ultrasonic V5100 Humidifier
WHERE CAN I BUY VICKS WARM STEAM VAPORIZER
Problems in a Vicks Warm Steam Vaporizer comes when it is mis-handled or when we buy non-warranted products. It is the best solution to spend money on the branded and cheap vaporizers.
http://www.vaporizerchief.com
Cheap Vaporizers Herbal Vaporizers For Sale
Jan 21, 2014 | Vicks Warm Steam Vaporizer 1.5 Gallon...
We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
Mar 25, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Use vick's vaporizer with "fog juice"?
Hi no i would buy some smoke pellets for a smoke test they have more power to do the job save the vick for when you have a cold .............
Feb 04, 2010 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vaporizer is making a spitting sound -
No salt, unless you had 0 steam - to stop water spit, throughly clean the water tank, just as clean as new. It will work like new if the tank is as clean as new! I dont know where the small particles of dirt come from, but trust me, I just went thru this with mine, it's got dirt in it!
Nov 19, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vaporizer That Works?
Have you tried adding salt to the water in the vaporizer? Sometimes the water needs to minerals for the humidifier to work...I add sea salt to mine every time I fill it.
Oct 12, 2008 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Vicks V150 Humidifier Logo
41 people viewed this question
Top Vicks Humidifiers Experts
Paul Carew
Robert
Are you a Vicks Humidifier Expert? Answer questions, earn points and help others
