Question about Sony Audio Players & Recorders
How much for a tech to come set our home theatre up properly
    Guru:
  • 417 Answers
Where you @?
if you think your able, then bell me & we'll do it over the phone.....lol
TEL: 07970306952
Posted on Jan 14, 2013
Pioneer home theatre xv-dv222 wont turn on
Seek tech support. The set need service. It is a skilled work.
Jun 04, 2012 | Pioneer Audio Players & Recorders
My sony Home Theatre DAV-DZ290K, is not functioning properly. The DVD drive opens back again immediately after closing it with a CD or DVD. The display would show us "CLOSE" and then instantly...
okay just plug it out from the current outlet let it stand for one hour then plug back in if that does not remedy problem then your motor is bad or the ic that controls the open and close circuit.have a tech look if my remedy does not work..sometimes plug in and out do the fix cause all the set wants is to reset itself.
Sep 13, 2011 | Audio Players & Recorders
I have connected the HDMI cable from the home theatre system into my TV but when I select to receive the Home theatre System signal (HDMI) on my TV it does not show the SONY Screen (It flashes as if it is...
Change/ reduce HDMI resolution in DAV-DZ810 so your tv can get proper video signal because it seems DAV-DZ810 is set on bit higher picture resolution and tv is unable to present that picture.
Thanks.
Jan 10, 2011 | Sony DAV-DZ810 Theater System
'No disc' message on Samsung DVD home theatre system
hello,
the problem the disc is samsung DVD home theatre is having is the lense that is weak. if yo replace the lencse then it wold work properly.
Jan 04, 2010 | Kenwood DV-6050 Multi-disc DVD Player
Sound does not come out of home theatre system
Check for power to the Home Theatre system. If you have lights on the front of the system, check your connections to the external speakers. Next check the output settings in your TV's setting menu. More info from you regarding this problem would have been helpful. I'm guessing your thoroughness is probably going to turn out to be a contributing factor.
Apr 21, 2009 | JVC Audio Players & Recorders
Multiple game systems through home theatre
what you need to do is hook all of your gaming systems into the "in ports" on your gameing switch, then hook the set of cables you want to use to the "out port" then the other end of those cables need to go to the "in port" on the home theatre system (you can pick which in port you would like to use, it should say which is which on the back by the ports) after doing this you need to find the out port on the home theatre system that corresponds with the cables you are using ie, rca component or hdmi. once you find that port you need to hook a cable to that into your 'in port" on your tv., lastly turn on all of your gaming systems, your tv and your home theatre system. and on your home theatre system select which ever port you hooked the gaming switch into, then turn your tv to the correct channel that you hooked the cables into the tv, lastly go through each swithc on your gaming switch to be sure that they all work, if not, you might want to use all the same cables for all connections, ie, all component all rca or all hdmi, i prefer component.
Mar 29, 2009 | Philips MX6050D System
Cannot access the System menu on home theatre
for sure call tech support from bose they are very helpfull
Dec 28, 2008 | Bose Lifestyle 18 System
Hdmi resolution problem
Check the settings for the HDMI on both your TV and Amp. Compare them to your brother's set up. See if that provides any clues.
Try replacing the HDMI cable too, it could be faulty.
Jul 26, 2017 | Audio Players & Recorders
PROBLEM HOME THEATRE SYSTEM HTDS490
Hi, Ive had the same problem and after talking to Samsung Tech Support, I re-checked all my speaker wires and thier connection... one wasn't quite making proper contact so I adjusted it and PRESTO all better!!!!!
Sep 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
21 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
