Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA green light clicks three times but no power or picture
I replaced the flyback already but have the same problem. I am going to replace the 16v 2200uf cap, I noticed that it is beveled on the top so im hoping this will fix the problem. I will let you guys know if it works.
  • 1 more comment
  • snowboarderm Jan 24, 2009
    I was unable to find a 2200uf 16v cap so i was forced to use a 2200uf 35v cap. I replaced the part and now the tv turns on but the convergence is out of wack. Does anyone know if the cap could be causing this problem because it was not a 16v? or does anyone know what else I might need to look at? Thanks, snowboardermc@hotmail.com
    RCA d52w20-
    I read on a simular thread that this could possably be the flyback. I had a brand new flyback for this tv already so I put it on. It still has the same convergence issue. The only thing I can think of now is that I need to replace the 2200uf cap to the 16V instead of the 35V ....or replace the FL231 fuse next to the flyback... If anyone can lead me in the right direction on what I might need to do to fix this convergence issue, it would be appriciated. Thank you!
  • snowboarderm Jan 26, 2009
    Thanks for your replies, where can i find the horizontal ouput transistor?
    Sergeant:
    Champion:
  • 346 Answers
Check fl231, insert 2200/16v cap, 220/35v caps,check horizontal output transistor,
Posted on Jan 26, 2009
  • cyriacus joseph Jan 26, 2009
    call the manufacturer
    give the model number of tv
    the location number of the part you need e.g Q14401 or Q502 -
    the location number is written on the circuit board
    the horizontal output transistor could be 2sd2539 or 2sc5148
    the transistor is black with 3 pins. it is next to the flyback
I have a RCA D52W19 52in Rear Projection HDTV and the light flick
Deflection board , its bottom board to the left has FBT flyback transfomer CK capacitors cp 150 2200uf 16v use 25v and two more cp114 cp120 220uf 35v if cp 150 is puffed up on top it is bad replace All 3 capacitors for parts call Mats Electronics 1-800-628-1118, also For Deflection replacement board Call Encompass Electronics Parts 1-800-638-3328
Nov 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 gets power but won't turn on
Hi, thank you for visit fix ya.
Common problem on thi tv.
Capacitors on power supply bad.
Replace this:
2200uf 16V, 220uf 16V. Upgrade to 35V.
Located on power supply- deflection board.
(picture)a57b905.png Thank you
Jul 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a RCA model# D52W20. The TV will not power up.
ON the deflection board ck capacitors 114,130,150 if 150 is puffed up on top it is bad 2200uf 16v use 25v and the other 2 are 220uf 35v replace all 3 of them and resolder around all pinns on FBT flyback transfomer.
Apr 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 36' RCA TV JUST QUIT WORKING. TURNED ON POWER
A shorted horizontal output transistor or shorted flyback. If the flyback is shorted replace also its HOT.
Apr 05, 2009 | RCA F36650 36" TV
Tv's green light comes on then off three times
Check capacitors cp150 ,114, 120 ,if cp150 is puffed up on top it is bad.2200uf 16v and the other 2 are 220uf 35v.
Feb 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
On same Board that you replaced fuse Look at cp 150 if it is puffed up on top it is bad so replace cp150,114,120 one will be 2200u 16v
other 2 caps will be 220uf 35v With tv turned OFF Press and Hold Vol- and CH - at same Time on Front Panel board wait untill set comes on you should now be in Service mode Go to Convergence Try to aline convergence Do Auto converge
Feb 08, 2009 | RCA Televison & Video
Rca HD52W59YX36
Thats the error for a bad flyback You will need to replace the flyback #259296 and also CP150 you can get replacement flyback and cp150 at the following link and they provide free installation instructions with pictures so you can easially do the repair yourself.
http://servicemanuals.vstore.ca/
Feb 01, 2009 | RCA HD52W59 HDTV Projection Television
3 blinking lights after replacing CP150, CP110, Flyback, CL031, and (2) 10 Watt 1.5ohm 5% resisters.
Your right on these sets you have to replace all 3 capacitors 2200uf 16v and two 220uf 35v.
Aug 30, 2008 | RCA D52W19 52" Rear Projection Television
Won't power on
my d52w19 chassis itc222 as posted most of the time wont turn on and the green light flashes three times every time it makes a small noise. sometimes it does turn on and you hear a little pop and the tv fires up.  latley there is a really high pitch noise that will slightly change pitch if you move the tv or put slight pressure on the top or botttom rear part of the chassis. thanks for the help as I have seen that this has been posted before without mention of the high pitch noise.
Aug 23, 2008 | RCA D52W19 52" Rear Projection Television
Tv won't come on
you need to replace the flyback. You need flyback number 259296 you can get a replacement at the following link with free step by step installation instructions.
Aug 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
74 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
