Question about Home
What thermometer is the most accurate? - Home
    New Friend:
  • 58 Answers
According to Consumer Reports, it's the digital stick fever thermometer.
http://articles.washingtonpost.com/2012-01-09/national/35438058_1_thermometers-temperatures-consumer-reports
Posted on Jan 14, 2013
How accurate are meat thermometers?
Meat thermometers are accurate to within plus or minus 1-2 degrees F.
Feb 14, 2013 | Home
What does an ear thermometer do?
Ear thermometers are great. Studies show that taking a temperature via the ear is more accurate than via an oral thermometer. It takes just second and is much easier to do on young children than an old fashioned thermometer.
Jan 14, 2013 | Medical
Why do people use meat thermometers?
: Meat thermometers are great ways to measure the internal temperature of meat while it's cooking. It allows an easy and yet accurate way of knowing if the meat is cooked.
Jan 10, 2013 | Home
Calibration for craftsman 1000 degree infrared thermometer
Apparently the reason it is not accurate is that it is a Piece of crap and Sears will not stand behind it. I recommend you do not purchase any type tool that requires precision from Sears.
Jan 05, 2013 | Craftsman 1000 Degree Infrared Thermometer...
Heaters are set between 77&78 and the thermometer reads 79.9
that's pretty accurate. If you think your thermometer is right, reduce the setting to get what you want
Oct 13, 2012 | Eheim AEH3616090 Jager Aquarium Heater
Grill will only heat to 350 degrees
I suspect the problem, is a result of either dirty and/or clogged burners and venturi valves (part of the burner). Or the grills gas regulator is partially locked close.
Since the regulator problem does not involve any real dismantling of the grill, I'll start with that solution first. The most important thing is - Do you have enough gas in the tank, for the grill to perform as it should? If it was recently filled, do the following.
1. Turn the gas valve on the tank OFF.
2. Disconnect the hose from the tank and wait 5 minutes.
3, Reconnect the hose to the tank and turn the tank valve ON, VERY, VERY SLOWLY (Slow
Motion, slow)
4. Once he tank valve is fully open, light the burner farthest from the tank first and turn the burner
knob to HIGH. Dose the flame height look correct? If so, light the remaining burners the same
way, until are are lit and burning. Do all the flame heights look correct when set on HIGH? If so,
you solved the problem. Close the grill's hood and allow it to heat in excess of 350 degrees. It's a
good idea to confirm that the thermometer on the grill is accurate. Place an inexpensive Oven
Thermometer (about $6.00) that will set on the grill grate(s), while you preheat the grill. When the
grill's thermometer reaches 350, raise the hood and compare it with the reading of the oven
thermometer. if they read approximately the same, then your grill thermometer is accurate. If the
oven thermometer reads higher, the grill thermometer needs to be replaced. Frankly, mind failed
to read accurately. Rather than replace it, I always use the oven thermometer, because it's not
reading the air temperature at the hood level, it's reading the temperature at the cooking level.
Which is really what I want to know.
If the above did not solve the problem, you will need to replace the grill's Hose/Regulator Assembly. You can purchase one from any home center or hardware store that sells gas grills and accessories. They run about $30.00. Take you old one with you for comparison purposes.
Hope this helped you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 17, 2011 | Ducane 30400040 Stainless Steel Grill
Won't get hotter than 300 degrees
If you are confident that there is adequate gas in the tank to maintain combustion ... Turn off the tank valve and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve On VERY, VERY SLOWLY (I'm talking, slow motion, slow). Once the valve is fully open, light the burner farthest from the tank, first. Turn it to high and light the remaining burners the same way. This should solve your problem. Just remember to always turn the tank on VERY, VERY slowly after it has been turned off.
Also, it's a good idea to test your grill thermometer to see if, in fact it's accurate. Buy a regular oven thermometer and set it on the middle grill grate, near the front of the grill. Preheat your grill with the lid closed and when the grill thermometer reaches 300 degrees, open the hood and look at the temp on the oven thermometer. Are they the same or with in a few degrees of each other? If so, your grill thermometer is accurate. If not, it's faulty.
Personally, I always use an oven thermometer when preheating my grill, because it's more accurate. And only cost about $5.00 @ Walmart.
Hope this helps solve your problem. Please be kind enough to let me know.
Happy Grilling!!!
Mar 06, 2011 | Weber Genesis Silver B Grill
There is a discripincy between dynamap temperature and thermometer readings. Is there an expected % difference between dynampa readings and thermomters?
Hello dear
Thermometer reading is more accurate then dinamap reading.
In dinamap take three reading and then the average of these three are the correct one, But in thermometer the first reading is accurate.
Well in dinamap it shows usually plus minus 5 difference.
Hope the answer will help, do rate it please
Regards
Feb 28, 2011 | Health & Beauty
Home Logo
471 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
