Question about SHAPE Services IM+ Lite with multitasking
Cannot log into yahoo messenger using im+ says authorization failed check your id and password
Using nokia x6 symbian
When im trying to log in to yahoo messenger using one ID i get a error code 81003002, and at the same time im able to log in using a different ID
Clickthe "Messenger" menu in Yahoo! Messenger and select "ConnectionPreferences." 2.Enable the "No network detection" option and then click the"OK" button at the bottom of the window. 3.Yahoo! Messenger will ask you if you want to sign in again with your new proxysettings. Click the "OK" button. 4.Enter your Yahoo! ID and password and click the "Sign In" button. youmay have a registry problem download registry cleaner reginout to fix the issue
Feb 18, 2011 | Yahoo Messenger
Change my password
  1. Click on the Yahoo! Messenger icon found on your computer desktop, or enter the program from the Yahoo! home page. Log in to Yahoo! Messenger with your user ID and current password. Click the "Yahoo! Messenger" link when the Yahoo! Messenger window opens.
  2. Go to "My Account Info." This will take you to the Yahoo! Messenger account information page.
  3. Find the link that reads "Change Password." Type your old password into the first field, then type a different password into the new password field.
  4. Enter your new Yahoo! Messenger password into the next form field to confirm it. Save the new password into your Yahoo! Messenger account.
  5. Log out of Yahoo! Messenger, then log in again. Test your account by entering your user ID and new password.
Dec 21, 2010 | Yahoo Messenger
Why i cannot log in to yahoo messenger my cousin yahoo ID?I
Logging into Yahoo messenger is similar in a way to logging into an email account, a log in ID and a password are required.
You mention that you are trying to log into your cousin's Yahoo messenger : has your cousin autorised you to log into his/her Yahoo messenger ? If yes, then get his/her Yahoo messenger's login ID and password & then, you can log into it.
Sep 27, 2010 | Yahoo Messenger
How to register at yahoo messenger?
When you a have an account with yahoo mail automatically you are sign to yahoo messenger. So you need a yahoo ID before you can enter yahoo messenger and you have you have yahoo id you will log in with your yahoo id and password. to enter yahoo messenger.
You can click on yahoo messenger icon and enter you id and password and then click sign in.
But if don't have the yahoo messenger icon, just go to yahoo and click on yahoo messenger and enter your id and password to sign in.
Aug 09, 2010 | Yahoo Messenger
How i can log in
Just go to yahoo messenger and enter your ID and Password to log in. The ID and password will be the same you use in your yahoo mail. Note, if you don't have yahoo ID you can't log in to yahoo messenger.
How to change my yahoo.messenger password
1.Click on the Yahoo! Messenger icon found on your computer desktop, or enter the program from the Yahoo! home page. Log in to Yahoo! Messenger with your user ID and current password. Click the "Yahoo! Messenger" link when the Yahoo! Messenger window opens.
2.Go to "My Account Info." This will take you to the Yahoo! Messenger account information page.
3.Find the link that reads "Change Password." Type your old password into the first field, then type a different password into the new password field.
4.Enter your new Yahoo! Messenger password into the next form field to confirm it. Save the new password into your Yahoo! Messenger account
5.Log out of Yahoo! Messenger, then log in again. Test your account by entering your user ID and new password.
Apr 09, 2010 | Yahoo Messenger
Cant log in to yahoo messenger
Try creating a new account, or try the forgot password link.
Jan 21, 2010 | Yahoo Messenger
I cant insall yahoo messenger. it says: incorect command line parameters and portions of this software are based in part on the work of the independant JPEG group, and it also says this application failed...
I would like to help you with your issue. but we have to check the following first
http://webmessenger.yahoo.com/ try log into the Web Messenger
> Step 1: Test Your Internet Connection
> Step 2: Verify Your Yahoo! ID and Password
Open Internet explorer and www.mail.yahoo.com
Check by sign in to you account
> Step 3: Test Your Access to Secure Pages
Make sure that you can access secure pages from Internet Explorer
Try to sign in to Yahoo! by going to the Yahoo! sign in page and enter the same Yahoo! ID and password you were using before.
> Step 4: Verify Credentials
Verify that the same Yahoo! ID and password you used before in the last step also works in the online version of Messenger, Yahoo! Messenger for the Web:
> Step 5: Check Connection Settings
Click the Messenger menu and select Connection Preferences.
Click Connect directly to the Internet, and then click OK.
Check by Changing the connection type to a connection via a proxy server:
Click Connect via a proxy server, then under this option, select HTTP proxy, and then click OK.
Last is Uninstall all the Yahoo Tool Bars and Yahoo applications , Yahoo Messenger, and Yahoo Updates from Program list i.e Control panel - Add/Rem Programs ..
And reinstall the Yahoo Messenger again -
from www.yahoo.com
Hoping the above info will be useful for you
Jan 19, 2010 | Yahoo Messenger
Why won't IM let me sign in? It keeps going to sleep
Jan 18, 2010 | Yahoo Messenger
It won't let me im!
are you able to access your data services. If you dont have access to your mobile internet IM will fail. IM services use text messaging and wap access. Make sure you have both.
If you do try to log on with IM short codes.
Text in [Yahoo! ID] [password] to 92466. Do not include quote marks, brackets or commas. For example, if your Yahoo! ID is chatsalot77 and your password is 123456, your text should read : in chatsalot77 123456. Leave a space between in, your Yahoo! ID and your password, as illustrated.
  • You will receive a text message confirming that you are logged into Yahoo! Messenger on your mobile device.
  • To log out: Text out to 92466.
  • Alot of the time after this is successful you can log off through the menus in the phone and be able to log on successfully.
    Jan 19, 2008 | LG VX8300 Cellular Phone
    SHAPE Services IM+ Lite with multitasking Logo
    47 people viewed this question
    Top SHAPE Services Apps Experts
    Erin Wood
    Erin Wood
    Are you a SHAPE Services App Expert? Answer questions, earn points and help others
