Question about Dryers
Hotpoint tumble dryer tdl31p
I have just fitted a new heater element to tumble dryer i have power going to element ,have tested and deffinate 240v going through elements but they will not get warm , what can i do?
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    if you ha ve 220 volts to your element and its not heating you need a new element!
I have a 2nd hand hotpoint aquarius Autodry Model tdl31 tumble drier. I need an instruction manual. Can anyone help with emailing me one?
Posted on Aug 11, 2009
  • 135 Answers
If you are getting 240v on all element connections then you are missing a neutral and the element will not heat.
Please check this and post your findings.
Thankyou.
Posted on Jan 23, 2009
My hotpoint aquarius tvf760 tumble dryer keeps flashing and saying error-07........ Has it died?
Not really, just a bit sick. I found this
F07 Lower tumble dryer element failure
  • Check security of module connector J4
  • Test between pins 4 and 3 on J4 (approximately 48 Ohms). If open circuit, test lower element and wiring between J4 and the heater.
Nov 27, 2015 | Hotpoint Dryers
I have a vented TL61P Hotpoint Aquarius tumble dryer which will not heat with or without the no heat button pressed !Could this be a thermostat problem or the heater ?
check thermostats as above posts have commented check also condition of elements as my dryer elements are cracked and need replacing just had a new belt fitted so reluctant to let it go
Mar 19, 2011 | Dryers
The tumble dryer on my hotpoint WDL 540 is not getting warm. I assume it's the heating element, but would be grateful for advice if it could be anything else or how easy it is to fit a new...
hello i'd check the heat sensors first there may be 2 of them you will need a multimeter to test them if 1 is faulty change both of them hope it helps
regards
shaun
Mar 11, 2011 | Hotpoint Aquarius WD640 Front Load...
Installed new upper & lower elements & thermostats, only top htr works
If original problem was caused by sediment burning out lower element, did you clean sediment out of water heater when changing lower element?
Two element water heaters are 240V.
Thermostats cut power on one hot wire, but 240V circuit has 2 hot wires. So lower element has power at all times coming from the red wire.
1) Use ordinary tester or multimeter set to 240V <> test each screw of lower element to bare metal part of water heater. Each screw should show 120V. If there is no power, then upper thermostat is defective, screw on upper thermostat is loose, or red wire between upper and lower parts of water heater is bad.
2) Remove wires from lower element. Use continuity tester or multimeter set to ohms <> test across both screws of element to see if power travels through element <> if element is bad, then continuity tester will not light up and multimeter will show no ohms. Put wires back on element after test.
3) Start with cold water in tank. Turn on water heater & upper element will turn on. Put ear on side of tank to hear if upper element is heating water. Test #3 screw to #2 screw on low left side of thermostat, should read 240V > Test #3 screw to #4 screw on low right side of thermostat, should read 0V.
Put ear on side of tank. When upper element turns off: Test #3 screw to #2 screw on low left side of thermostat, should read 0V > Test #3 screw to #4 screw on low right side of thermostat, should read 240V. If this test shows 0V and 0V, then upper thermostat is bad. If reading is correct, immediately move to next test.
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
4) Turn temp on lower thermostat to 150. Using ordinary tester or multimeter set to 240V <> Test across both screws of lower element. If there is no reading, and you know element is good from step 2, then lower thermostat is bad, or wire is bad between lower element and lower thermostat, or wire is bad between lower thermostat and top part of heater.
5) Test across both lower thermostat screws, should read 240V.If this test is good, it means wires are good. Put jumper wire across both screws of lower thermostat, and test lower element again. If element finally turns on with jumper wire, then lower thermostat is bad.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
If wire is bad between upper and lower parts of water heater, and water heater has tight-fitting 2" foam insulation, it usually indicates water heater replacement.
Sep 20, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
My white knight condenser dryer doesn't heat up anymore what do i need to replace?
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat is this video does not help go to our video section and there are a few on other condenser dryers
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Mar 25, 2010 | Dryers
Dryer does not get hot, already changed the heating eliment
this might help
Feb 15, 2010 | Dryers
My hotpoint aquarius tumble dryer has stopped heating up.what can be wrong and what can i do
Probably faulty thermostat/s, or heater element.
Located at rear of dryer behind removeable panel.
You will need a meter to test with.
Feb 01, 2010 | Hotpoint Dryers
My hotpoint ctd00has stopped heating up how do i
You will find the thermostats located at the rear of dryer.
Remove cover, and you will see them adjacent to the heater element, change them both, even if only 1 is faulty.
Please rate my solution.
Thankyou.
Tumble dryer not getting hot
Likely to be a thermostat or heater element problem.
These are located at the rear of the dryer, behind a removeable cover, but you will need a test meter to check them out.
Hope this helps.
Dec 15, 2009 | Hotpoint Dryers
My hotpoint v3d00 tumble dryer only blows cold air.
It is probably going to be the heater element, or thermostat/s that are
faulty.
You need a test meter to determine which component it is..
Thanks.
Nov 22, 2009 | Hotpoint Dryers
Dryers Logo
380 people viewed this question
Top Dryers Experts
