Question about Goodman CLQ36AR49 Air Conditioner
Defrost timer One of the tects told me to set the defrost timer on 30 min, he said that he sets all of his units like this is this true? he also said that even though it is on 30 min it will not defrost every 30? is this true? Thanks
  • jarighter Jan 24, 2009
    Thanks guys, I called my service tech, and asked him to check the defrost timer and freon, as I have received many comments concerning my Goodman Heat pump freezing up and running too long on AUX heat. He did, I told him that I received the information on this site. He found that the timer was set too high, and it was low on freon. Thank you so much for your time and knowledge, I don't think he even thought to check the settings, apparently he said the factory sets them, and there is no need to recheck them. I would not have known what to have him check for, without your expert knowledge and input. Thanks again. John, now warm in Tennesse, and saving money. P.S. he to did not know because I talked to him before about this problem and he said it was normal, without looking at the unit. You guys are GREAT!!!!!!!!!!!!
    Scholar:
  • 144 Answers
The settings are for different regions. The colder your region the sooner you want it to go into defrost. If you have it set at 30 then every 30 minutes of run time the board will want to go into defrost. However there is a sensor that is mounted to the coil that registers the temp. of the coil. If the coil is not cold enough it won't let it go into defrost and the sequence starts over. The more it runs in defrost the costlier it is to run and the more wear/strain you put on the compressor and the system in general. Start at 60 and go from there.please don't forget to rate this solution. Thanks.
Posted on Jan 23, 2009
    Novelist:
  • 88 Answers
Thanks for your question,
as to the first part of your question, it has some variables, first the area of the country you live in, the type of system you have, how large your home is, and up to the tech to figure out how many minutes it should run in defrost, for the area I live in Defrost timers are set from 10 to 30, normally around 15 mins, the unit will only go into defrost when the defrost sensing bulb senses ice build up and will then go into defrost mode, if you live in an area where it is almost always freezing, then running the defrost for 30 mins is not a bad idea, but if its a milder climate then turning it down to 20 or 15 mins is about right, hopefully this helps you out to better understand the defrost setting on your heatpump, please rate this so we know how we did, thanks again,
mr.grzz
What is the standard setting defrost timer control of ts-49f
our freezer is set to defrost every 8 hours for 15 min. this seem to do the trick. we have a true t-49f reach in freezer. try this setting and see if it works for your situation.
Mar 30, 2015 | True TS-49F Stainless Steel Freezer 2...
What is the standard defrost timer control setting
Usually every 6 hours will keep the evaporator coil clear of frost. I set the time at 45 minutes per defrost. This unit has a defrost termination control that kicks it out of defrost when the coil reaches a certain temperature. The defrost timer is only a backup if the defrost control fails.
Defrost cycles
Defrost cycle usually comes on after about 7 hours. If it is happening every 30 minutes or so, the defrost timer is not working properly and your internal temperature will never have a chance to go down to zero as SOP.
When defrost cycle comes on, the compressor is automatically shut off and internal freezer temps can go up by close to 25 degrees or more. It is for this reason that commercial freezers do not have auto defrost - the latter extols a price, convenience at the price of higher average temps and less time to properly store foodstuffs in freezer.
Nov 20, 2013 | Freezers
How to set defrost timer for t19f
In general I use 4 defrosts in 24 hours for 30 - 40 min each.
Jun 06, 2013 | True T19F Commercial Freezer
Proper defrost time true t-49f
They don't even ship them properly set. They expect that a trained technician is on site at start up. I generally use 4 defrosts in 24 hours at 30 - 45 minutes each. It depends on which timer is installed.
Mar 28, 2012 | True 49 cu. ft. / 1388 liter Commercial...
Compressor turns on takes 30 mins to cool on -18 setting, Then freezer drops from -18 to minus 27 then 6 mins to warm up to -18 this repeats continuesly using alot of power Problem is. Temp is...
Sounds like it keeps cycling on defrost... find the defrost timer below the kick plate the one with a dial on it... turn the small dial slightly... if it works then the timer is faulty
Jul 20, 2011 | Refrigerators
On carrier model 25HCB318A300 there are 3 switches to set the defrost time from 30 60 and 90 min. the diagram shows 2 switches. which 2 switches actually set the time. One has on beside it is that included...
Hello
On that model the 30 60 and 90 are times unit will be in defrost.
So depending on how long you feel the need to defrost ,set accordingly.
If this is a refrige usually 30 min is fine.If a freezer 60 min should work.
Jan 11, 2011 | Heating & Cooling
We have a true single door freezer, it is iced up inside . what should the dial inside the unit be set on.
On the freezers a setting of 7 or 8 should do fine. I would be more concerned with the defrost timer, defrost heater, and settings. Also a HUGE problem is that the door switch on the top center of the door can sometimes barely contact the door (this happens when a unit is slightly warped or out of level) or the spring loaded hinge on the door can break causing the door to stay propped open at times. When the door doesn't close the evaporator fan stops but the compressor will continue to run. I have had to tape a nickel on top of the door to make better contact with the switch. Make sure the switch isn't the problem before going any further.
Nov 17, 2010 | True 23 cu. ft. / 651 liter Commercial...
What initiates the defrost?
Hi and welcome to FixYa I am Kelly.
Your defrost cycle is controlled by a mechanical defrost timer similar to a spa timer
Download this manual then see pages 13 and 14 for locating and setting the defrost timer.
http://www.mbm-service.de/mbmTechTwo/True_/GDM-9+/Service_Manual.pdf
There are 3 different types of GDM units. NOTE the one 2 and 3 door timer locations on page 13. There are all in different locations.
Also see page 109.
If you need service or technical help:
TRUE MANUFACTURING TECHNICAL SERVICE
1-800-325-6152
Thanks for choosing FixYa.
Kelly
Sep 26, 2010 | True GDM-23 Refrigerator
Defrost timers 8141-00
Setting Defrost time, Place the start pins(screw pins) in the outer dial, at the time of day- When you want defrost to start. (8am-2pm-8am-2pm) 4 hours min. between hours.
Set the Time of Day, Grasp knob marked - Turn to set. rotate, until the correct time of day. Ever timer there is a power interuption, this will ahve to be re-set.
Depress and rotate the bronze pointer on the inner dial to the length of defrost wanted, - apx 30 minutes.
done.
Oct 24, 2008 | Paragon 4001-0G Defrost Timer
Goodman CLQ36AR49 Air Conditioner Logo
147 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
