Question about Canon ZR65E Mini DV Digital Camcorder
No picture In the recording (Camera) mode I cannot see anything on the display or through the view finder. It will play back earlier recordings fine. Thanks for help.
  • 1 more comment
  • hartsock Aug 05, 2008
  • katy616 Sep 28, 2008
    I have the same issue. The battery is fully charged yet I can't see anything. The camera has not been exposed to any extreme temperatures or light. We haven't used it in a while but that shouldn't be an issue.
  • mnr6505 Mar 29, 2009
    Hello, I just this camera and when i tried to record something, The display view finder wont show any thing. it's blank screen? when i played what was recorded, only can hear audio come out, but no image? Please Help?
Go to the manufacturer's website, for Canon it is <a rel='nofollow' href="http://www.usa.canon.com/consumer/controller?act=SupportIndexAct">http://www.usa.canon.com/consumer/controller?act=SupportIndexAct</a>
Select your device, and click the button for camcorder product advisories. There has been a known problem with the CCD chip in certain models, if that is the problem Canon will repair the problem free of charge, even without being under warranty. Free shipping as well.
Posted on Feb 20, 2008
He CCD (charge coupling device) went kaput like all those others who are complaining about no picture in the view finder. My technician told me that this happens when 1) on exposure to hot climate 2) if we focus too far, like into the sky or by mistake at the sun or some bright flourescent light. This fact is not mentioned in the accompanying instruction manual, atleast i did not find it. I hope all current users take these precautions, it is too late for me, I am not spending any more money on this digital camcorder. I sincerely request Canon to withdraw this product. i found this info hope it is helpful
Posted on Jul 09, 2007
2 Suggested Answers
SOURCE:
  • 472 Answers
SOURCE: no picture
The motor circuit on most handycams has it's own fuse since it draws more power then the rest of the camera combined.
The fuse will only be a tiny white blip on the circuit board about 1-2mm in size.
Safest option would be to have a technician take a look at it since they can be stubborn to even get apart, let alone track down mico fuses.
Posted on Apr 11, 2008
I bought a JVC GR-SXM250u Super VHS camcorder a couple days ago and the picture has horizontal lines flashing in and out so I can't see in the display both in pause mode and in record mode. He said he...
you may have a faulty camera there,,,or the vcr tape may be faulty and has spred some of the tape on the recording head try running a cleaning tape through the vcr first to clean the heads,,then use a new tape (not the old tape!) to try that out,, if its cleans the head up throw away the old tape so you never put it back in this vcr
Sep 04, 2010 | JVC GRD250 MiniDV Digital Camcorder
My digital video camcorder mv700 displays a black screen on record mode.now when operating in play mode it displays no card.please inform me of nearest service canon centre.
Have you accidentally switched on the view-finder? In this case the LCD screen will automatically switch off (usually to save battery power)
Also have you accidentally switched your camera to still-shot camera mode, or something else, so the camera asks for the memory card in playback?
Jul 09, 2009 | Canon Video Cameras
Canon zr-90
call 1800-ok-canon same thing happened to me they fix it for free. its a recall on their side. you get you camera back in about two weeks. good luck
Sep 26, 2008 | Video Cameras
No picture
Apr 11, 2008 | Canon MV700i Mini DV Digital Camcorder
Will not show anything in view finder
I sent my camera to a repair center for samsung and they replaced the ccd at no charge and it fixed the problem. I have used it and all is working and playing the old tapes as well. Thanks for your help, but got the answer from a blog as well as the address to send the camera to. Have a blessed day.
Jan 09, 2008 | Samsung SC-D23 Mini DV Digital Camcorder
Sony ccd tr series no picture in the view finder
camera have problem inside need to open by sony service center near you.
Dec 23, 2007 | Sony Handycam DCR-HC30E Mini DV Digital...
Camera mode recording/displaying right
what is the model number? if it's 10 years or older you are most likely dealing with bad surface mounted capacitors.
Sep 16, 2007 | Sony Handycam DCR-TRV140E Digital...
NO PICTURE
I had this with my Panasonic NV-DS60. I thought it would be the ribbon cables not making good connections from the camera lens electronics because I had a similar problem with another camera. So I took the whole thing apart and disconnected and reconnected the ribbon cables - unfortuantely this didn't work! So I thought there may be another connection I couldn't see so I tapped around the lens area with a hard object (tip of a screwdriver) and it worked! It may be well worth you tapping the case in this way (without pulling the camcorder to bits) on the top, about an inch back from the front of the lens a couple of times. I'm not an expert, but it worked for me! Obviously, don't hit it hard enough to damage it. Good Luck
Nov 26, 2005 | Quasar VM-L153 VHS-C Camcorder
Sony F55 Recorded Display
The filename (e.g. DSC0012.jpg) shows the image number, the filespec shows the date and time recorded. Most software will give you document info about resolution of the image. I wouldn't worry about what the battery status was when the shot was taken or how many other images were on the Mstick. I guess I'm not sure what you need.
Sep 11, 2005 | Sony Cyber-Shot DSC-F55 Digital Camera
Canon ZR65E Mini DV Digital Camcorder Logo
329 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
