Question about SanDisk Electronics - Others
How to remove writeprotection from my micro sd adapter
When i am formating through the software sdcard formater it says that your card is write protected what i wil do??
  • SanDisk Master
  • 27,725 Answers
You have to be the computers administrator to change any values on any hard drive on your computer click start control panel user accounts on the users tab click the name of the computer administrator you must have full control click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7 click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
Hope this helps.
Posted on Jan 14, 2013
SOURCE: formatting micro sd card
i'll make a try:
i) remeber u must have kept any password to micro sd card when the card was in samsung mobile g600 and keeping password to the micro sd card will prevent it from using in other device or even in other mobile phone
ii) so you have remove the password of micro sd card by keeping the card in tsamsung mobile g600 and use the option remove password(the way u kept password or by clicking 'option' when u highlight ur memory card)
Thanking you
M. Sridhar
Posted on Jan 01, 2009
  • 71 Answers
SOURCE: 8gb PNY micro sd card isn't recognized in my samsung Alias
If the phone failed to format the SD card, try to format it through your computer. Connect the phone through the USB port located at the back of the tower. You'll be prompted that the PC detected 2 USB drives, the phone and the SD card. You will see it by going to My Computer folder. From there, right click the Letter drive represents the SD drive then select Format. I hope this helps.
Posted on Jun 18, 2009
steve_e_uk
  • 1675 Answers
SOURCE: cannot delete in transcend micro sd 2gb memory card.
hi if you look on one side of the disk you will see a little white switch ( very small ) move this in the opposite direction of where it is and that should sort you out....hope this helps please vote thanks
Posted on Mar 24, 2010
elix0411
  • 3530 Answers
SOURCE: How do I remove write protection from micro scan disk chip?
if you will look into the side of your SD CARD. theres a small toggle switch there. just slide it to the other side inorder to disable the write protection
Posted on Apr 03, 2010
deanptechwiz
  • 7 Answers
SOURCE: My 2GB micro SD card
If it says write-protected, then... there is nothing you can do about it.
It's protected to not be formatted.
Posted on Aug 23, 2010
My 128 gb sd card is no longer working after trying to make it adoptable storage in my s7, my phone or computer wont recognize it anymore pls help
64GB and higher capacities need to be formatted with exFAT.
Some help: https://www.youtube.com/watch?v=JA9fp863d-o
A tool for formatting SD and micro SD cards is SD-formatter:
https://www.sdcard.org/downloads/formatter_4/
Oct 23, 2016 | Electronics - Others
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I have locked my memory card and forgotten the password. Format card also requires password and my laptop cannot read it. Please help.
All you have to do is:
Step One:
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
I hope this information helps. Thank you for using FixYa!
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
Micro sd 2gb tidak bisa format
Hallo scorpio, semoga solusi ini membantu
If the micro SD format fails, do not you repeat the formatting process. Because it will exacerbate the damage to the micro SD. Follow the steps below. Good luck.
Step One:
Step Two:
If the second solution does not work, it means your micro SD damaged firmware. Based on experience, one of the causes of damage to the firmware is, the formatting process is done repeatedly, but always failed.
When i try to format my micro sd card system shows remove write protect how can i format it
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
My 1 gb micro sd card is corrupted and my nokia E63 phone and DELL inspiron is not recognising it
    • 1 If your aim is to repair a corrupted SD card so that you can use it to store files then proceed to step #2.
      If your aim is to recover the files on the SD card without erasing them, proceed to step #5.
    • 2 Insert the SD card into a digital camera card slot and choose to format your card. If this doesn't work then move on to the next step...
    • 3 Place the SD card into your computers SD card slot.
      Right click on the SD card drive letter IF it appears and choose to "format."
      If this doesn't work, proceed to the next step...
    • 4:You will need to go to the website
      http://www.sdcard.org/consumers/formatter/eula/
      Here you will download, install, and run the program to format your SD card. This is the most advanced step of the three, but most likely to work 99% of the time.
    • 5
      If you want to recover files ON your SD without erasing them, then you need to download and run the software on this site.
      http://www.cgsecurity.org/wiki/TestDisk_Download
      This is the best free software available for this type of problem.
Jun 02, 2011 | Maxell 4 GB Class 6 Micro SDHC Card with...
8gb micro sd card ,unable to format on pc as well as on nokia c7, tried deleting files but all deleted files came back when card put back into the phone and working as well.needs assistance to format the...
plug the card into your computer with a usb adapter or if you have an sdcard slot use that. then right click on My computer or computer if your using windows 7. click manage, click on Disk Management, under storage. You should see your SD card there. Right click and choose FORMAT.
May 04, 2011 | SanDisk 2GB microSD Memory Card
My micro sd memmory card has benn locked by a password by sum1 and it cannot be opened in any way so is there any solution i can open it. and i dont need any data in the memmory card. i just need it to be...
The micro sd has no lock tab to slide on the side, but the SD card adapter does. Unlock the SD card adapter, and format the micro sd card using a laptop or PC. The only way your micro sd card could be password protected is using encryption. If this is the case, formatting the card should remove the password.
Mar 10, 2011 | Lands Phones
Formatting errors on 2 memory cards - old 1gb & new 4gb micro sd sandisk
Go here follow the instructions to get a formatter program
May 16, 2008 | SanDisk 2GB microSD Memory Card
Need to reformat micro-sd card in up stage phone
to reformat micro sd card in your phone
go to menu>my stuff>select removable disc or memeory card then select options>format
>>or you can reformat the micro sd card using your pc
>>connect the sd card to the memeory card reader then connect it to the memory card adapter
>>go to my computer then select removable disc then right click then select format
Feb 28, 2008 | Samsung UpStage SPH-m620 Cellular Phone
Electronics - Others Logo
24 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
