Question about Sony PlayStation Portable (PSP) Console
Psp connection to the TV
We have lost our instruction to which coloured cables fit into which connections on the TV - we have the 5 cable type. a red and white audio connection and 3 other cables - blue, green and red
  • 30 Answers
The cables you speak of is called component cables. They only go into color coded connection in the back of your tv. The best way is to look behind your television and more than likely there should be rows of either three or five connection and or markings saying RCA or Component connection. What your looking for is component.
Just to give you some info:
The cables you own will play vids, music, and games. But in order for the games to work you must have a HD TV.
If you see RCA jacks for your psp 2000 (slim) or 3000 (lite) than the only things will work is vids, & music (on any TV so long there is a RCA connection doesn't have to be HD).
Hope that helps.
Posted on Jan 27, 2009
  • lunasea808
    lunasea808 Jan 27, 2009
    Sorry forgot to put RCA jacks are your standard RED, WHITE, & YELLOW connections.
How to connect DvD play?
It depends on the type of TV you're connecting it to.Please be more specify the models.Preferably,use Component Cable and left/right audio cable,next use a composite cable that has yellow video,white for left audio and red plug for right audio.The plugs and jacks are colour coded,so just match them and you're all set.
If it's a 1080 upconverting dvd player with hdmi and your tv is an HDTV with HDMI,use that.
Nov 23, 2012 | Hisense Televison & Video
My dvd player only plays movies in black and white. When I watch tv, it's in color so I know its not the tv.
I suspect you may have connected a COMPOSITE cable (red/white/yellow RCA type) to the COMPONENT video input sockets on the back of the TV.
COMPONENT requires 3 RCA type video cables - the plugs and sockets are usually colour-coded red, green, and blue. COMPOSITE only uses one RCA type video cable - the plugs and sockets are usually colour-coded yellow.
If you connect the yellow video cable to one of the three component inputs you will get a black and white picture although you will still have audio if the red and white cables are correctly connected.
If you are using a COMPOSITE cable (red/white/yellow RCA type), please check your connections. Make sure you have not connected to any sockets - either on the TV or the back of the DVD player - under the heading of "COMPONENT" - or individually marked "Pr", "Cr", "Pb", "Cb" or "Y".
If you have verified that you are using the correct sockets on the TV and it still doesn't work or if you are using any other type of cable, please let me know which cable you are using and the model number of the TV and the DVD player. I will then be able to assist you further.
Jan 14, 2011 | Insignia DVD Player with MP3 Playback/JPEG...
Connect ps3 to a non HD tv and picture only black and white?
Are you connecting it to a new SD tv after having been connected to an HD set? You can force the system to reset the video resolution settings by pressing and holding the On/Off button after the system has already turned on. I believe it is ~5-10sec. You will hear another beep after the initial startup beep. This will reset video setting to default and go through the resolution setup wizard again.
However, it is also possible that you are trying to connect a component cable to a composite tv. They are VERY different signals even though the cables fit interchangeably. If you use the Green component cable for video on a composite tv you will only see a grayscale image of the picture. This is most likely your issue. If this is the case you will need to buy a composite cable for the PS3 (the PS2 one is the exact same as the PS3 one.)
FYI Component cable has Red, Green, & Blue cables. Composite has Yellow (Video), White (Left Audio), Red (Right Audio). Both are normal RCA type plugs and will fit in each others plugs, but the signals are VERY different.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
Conection wires from psp to tv
If you're looking for the cables used to connect your PSP to your TV, you can find them here:
Look for either the PSPgo or PSP-3000 AV Cables. If your TV has Red, Green and Blue inputs, use the Component cables, otherwise just use the standard AV cables that come in Yellow, Red and White.
Mar 29, 2010 | Sony PlayStation Portable (PSP) Console
When i connect psp to tv(hd) the screen apears red. Pls help.
It sounds like either the cables are reversed, loose, or possibly bad. This is what happens when a cable connection is not "solid". Please make sure all the cables are attached securely and in the correct order, if they are you may need to replace the cable. If it still happens with a new cable, it is probably the input on your TV that has an issue.
Aug 30, 2009 | Sony PlayStation Portable (PSP) Slim...
How do i hook up a nintendo to my tv which cords go where and can someone walk me through it
Round peg into the round hole. Red peg on the red slot. etc. If the wire from the nintendo doesn't fit the slot on the tv then you're in the wrong slot. if the wire from the nintendo fits the slot on the tv (and is the same color if you are using red/white/yellow rca cables) then you're good. here's a hint on connection types (you will not mix): 1. RCA (red/white/yellow round connectors) Red=right audio sound White=left audio sound Yellow=video connect to the slots that look like they want some. 2. Coaxial (stiff cable with a pinner poking out of the end -- same cable that connects you to cable tv) just hook it up by itself; it carries audio and video. 3. Component (red/green/blue)(red/white) two 'bundles' red=red component of video green=green component of video blue=blue component of video red=right audio white=left audio 4. VGA + (red/white) VGA=video (computer monitor cable) red=right audio white=left audio 5. HDMI (flat hdmi cable. you spent $30 on this 3 foot ****) HDMI=audio and video 6. hugs and kisses hugs=video kisses=audio (both sides)
Jul 15, 2009 | Video Game Consoles & Games
Psp to standard tv
u need psp 2000 and up.if u have it so a converter cable already comes in its box
Apr 22, 2009 | Sony PlayStation Portable (PSP) Console
Hd connection for wii
The red and white ones, that should be linked or the same are sound.
Dec 26, 2008 | Nintendo Wii Console
Wii component cable - how to connect it?
on your tv, there should be color coded ports that tell you which cords go where but im almost 100% sure that the red and white cords are for sound and the blue and green cables are for hd video hookups.
Oct 14, 2008 | Nintendo Wii Console
PSP 6 pin gen 2 cable not working on tv?
you have the wrong cable. the cable you have is for HDTV's only.
by the ports on the TV, you have a standard TV.
The cable's colors are Red, Blue, Green, Red, and White. If you have a HDTV or these ports on the back of the TV, connect them like in the picture.
from what you said, it seems like your TV's port colors are Yellow, Red and White. If you only have these ports on the back (Yellow, red, white), you need this cable:
Aug 30, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
181 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
