Question about Sony KLV-32EX400 32 inch Multi System LCD TV
Sony KLV-32EX400 32 POWER LED ONLY BLINKING TWO TIMES
  • 7 Answers
SOURCE: kdf-e60a20
do a google, Sony 4 red blinking lights, there is lots to read. Read it all. We had 6 blinking lights and it was at $20 thermal fuse that we reinstalled ourselves and saved lots. It was past warranty. You can also put a message out on the blogs. But do your homework, it's worth it. Good Luck, Kim
Posted on May 22, 2008
eagle338
  • 4889 Answers
SOURCE: sony bravia l42" LCD TV. No power. Green light on
7 blinks in the this series(KLV) means there is a short in the power supply board. The easiest way to fix this would be to swap out the board. I can find you a replacement if you want to try fixing this yourself.
Sai.
Posted on Dec 24, 2010
  • 8909 Answers
SOURCE: I have sony Bravia KLV
AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Posted on Mar 09, 2011
Ecollier2012
  • 3459 Answers
SOURCE: Sony LCD TV Model #KLV-23HR2 The timer LED
This is a common problem an a failry easy DIY fix.
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Posted on May 01, 2011
SD Tech
  • 14553 Answers
SOURCE: Sony Bravia KLV-40S200A LCD TV standby indicator blinks 5 times
Here is a link to the service manual--
http://www.scribd.com/doc/46056922/KLV-23S200A-and-Other
Page 11 explains the error codes--unless you are a tech with a meter etc it will be a shop repair.
A lot of good info including taking set apart correctly.
"abnormal power"
SD TECH
Posted on Jun 02, 2012
Sony bravia klv 24ex430 red light blinking 2 times?
KLV-24 EX430
RM-GA022
Troubleshooting
3-3. Standby Led Blinking
3-3-1. 2-times Led blinking
2 times Blinking
Check DC voltage at
JL6023
Is it 18V 19 5V?
Yes Change
- 19.5V? B*board
No
Take out adaptor
and test at adaptor Yes
output is it 18V - 19.5V?
Change
B*board
No
Change
adaptor this is flow chart for 2 blink
Aug 13, 2017 | Sony Televison & Video
Sony bravia klv 24R402A RED LED 2 BLINKING FLASHING LIGHT
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 09, 2015 | Sony Televison & Video
Sony bravia klv 24R402A RED LED 3 BLINKING FLASHING LIGHT
I have a Sony bravia KLV 32bx300 LCD tv. From like 2 months the tv isn't turning on , it tries to turn on for 3 times with green light on and it stops starting and tv goes to 6 red LED blinks, when th
Jan 19, 2015 | Sony KLV-32BX300 SERIES BRAVIA LCD...
What could be the problem with my sony bravia klv 40-bx420 lcd flashing red led 2 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Sidebar" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Aug 11, 2014 | Sony KLV-40BX420 40 1080p Full HD Bravia...
Sony klv-42ex410 blink 6 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
May 09, 2014 | Sony 42 inch KLV-42EX410 Multi System LED...
Please provide SONY BRAVIA KLV 46X200A red standby led blinking error code meanings
May 04, 2014 | Televison & Video
Sony klv 26s550a red light blinking problem
Apr 08, 2013 | Sony KLV-26S550A 26 inch Multi-System HDTV...
My sony tv klv-23hr1 comes on for a few seconds and then goes off .a yellow light blinks every second without pausing.the blinking yellow light is at the standby power section .the light blinks every...
Hi Carlos,
First of all, thank you for posting your question here at Fixya.
I have a copy of Sony KLV-23HR1 repair manual but it has no LED error diagnostic lists to verify the caused of the blinking LED of your unit. I've checked the other KLV series on my collection but all of them does not have a blinking yellow error code.
After checking the blinking error code of KLV series, I found out that most of them indicating power supply failure. In your case I would advice you to check the output of the power supply(G board) feeding the other board to determine its condition. You must have a multimeter set in DC measurement. Place the black test prod to chassis ground while navigating the red test prod to each pin of the connector while the set is power on. Please let me know your reading to continue our diagnosis.
Please ensure safety precaution while on testing the DC output voltage, make sure that you will not short the lead to other pin to avoid further damaged.
Jdvillanueva
Jan 21, 2012 | Televison & Video
Model no. klv-22bx300 problem- green light
my sony KLV-22BX300 Tv when turn power on green led blinking,
and menu function not working properly
Jul 19, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Sony KLV-32EX400 32 inch Multi System LCD TV Logo
50 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
