Wat does ld mean when go to start washing
Top loader washing machine ewt606
  • Washing Mach... Master
  • 17,129 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Posted on Jan 14, 2013
3 Suggested Answers
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
SOURCE: simpson esprit 450 washing machine top loader
your drive belt is brobably loose or broken
Posted on Aug 10, 2010
Ld error on electrolux ewt606 How i can fix it
I've never heard for model EWT606.
So, generally speaking error code is displayed as a letter "E" with two numbers, or just two numbers. For exp. E10,E50,E60....or 10,50,60 depending of model washing machine. Some of them are equipped with display (they show E50) and some other only with LEDs diode (you must count number of flashes and color light, red and green).
Dado
Mar 05, 2017 | Electrolux Washing Machines
Flashing LD on panel and beeping cabrio top loader washing machine
Ld Long drain Clogged/slow drain/pump
"LD" stands for "long drain," meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I've even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the "LD" error code springs forth from such anomalies.
Hope helps.
May 18, 2011 | Washing Machines
What does "Ld" mean?
Ld
Long Drain
Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Check for obstructions.
www.appliancehelponline.com
Mar 22, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Top Loader reading LD code.
You may have an obstruction in your pump which causes it to drain slower than usual, or binds the impeller. Flow can still be pretty good even with this problem but the brain will sense a longer than normal drain time and flag the error. Try removing the water pump and look for underwires, paper clips or hairpins.
Mar 07, 2010 | Washing Machines
Keep getting a LD sign and washer want run
ld means long drain. if this is a frt loader remove acess panel and their will be a white pump in the middle or the base, remove screw on cap i believe counterclockwise get a pan to catch the water we use the panel you will probably find alot ofthings in pump filter do this about every 8 months to ayear. if this is a top loader look for drain pump and inpect for a cloggage inside we find socks, coin, dollar bills clogging pumps all the time..
Sep 16, 2009 | Kenmore Washing Machines
Top loader washer wtw6400sw3 will not finish drasining. beeping and flashing Ld
"LD" stands for "long drain," meaning it took an excessively long time for water to drain out of the washer. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose. Why, I've even heard of bra wires coming loose and getting stuck in that hose, collecting all sorts of gookus and pinching off the flow of water to the pump. Can you imagine? Yea verily, as surely as the Sacred Suds doth eternally pass my lips, the "LD" error code springs forth from such anomalies. Can I hear an Amen?
Aug 10, 2009 | Whirlpool WTW6400SW Top Load Washer
What does ld mean?
ld mean long, drain. the machine was unable to drain out water in a given amount of time, calypso is imfamous for collecting lint in the pump assy, id open that up and have a look
May 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washer beeps Ld a few minutes into each wash
LD means = Long Drain
Problaby samething inside the pump
Is your machine calypso
Apr 15, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
