Question about LG Washing Machines
I have a LG 7kg Intellowasher front loader washing machine - model WD-1074FHB. Working well APART from coming up with the alert "SE ERROR" - which apparently is a sensor issue. This fault is prevent
SOURCE: LG Intellowasher cannot complete spin cycle.
My LG front loader will not drain and is displaying OE
Posted on Mar 14, 2010
  • 901 Answers
SOURCE: LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Posted on Apr 07, 2010
Testimonial: "Thanks for the quick reply Ambari, that's exactly what I wanted to know. Atleast I'll some idea if the repair bloke is pulling a swifty. Cheers"
  • 4 Answers
SOURCE: LG Intellowasher 7kg 800rpm WD-8074FHB
It could be that the springs have become lazy (stretched) and not supporting the spinning weight as good as they once did or as happened to me one of the shock absorbers at the base of the unit has come adrift from its securing point. Replacement parts are easily available but you will need someone strong to fit them with all that new tension.
Posted on Jun 07, 2010
  • 1382 Answers
SOURCE: I have LG WD -1050F Intellowasher 7kg front load
The problem is due to the rubber boot is been torn that is causing you the leak. You have to check the rubber boot for leaks by removing the clamp assembly that secures the rubber boot to the outer lip of the door opening. Peel off the rubber boot then inspect it for any holes where it may be leaking. The rubber boot in your washer can be accessed only when you remove the front panel. This requires the removal first of the top panel then the console. Also check your inlet hoses on the outside of machine, also check the connections inside the panel in back.
Thank you !!
Posted on Jul 26, 2010
SOURCE: LG Front Loader Washing machine: WD8013F
when we press wash,does not start. all light start flashing after 30 seconds.
Posted on Aug 18, 2011
I need a troubleshooting manual for an LG intellowasher 7kg wd-1274FHB which is displaying an SE error code.
LG error code SE LG washing machines displaying error code SE are indicating a "motor fault" although the technical information also says it could be a main PCB fault. They recommend to, "try the motor first". It's vague and not too helpful, especially for a DIY repairer so you really need an engineer to try and sort this one. You can't possibly justify "trying the motor first" if you interpret that as buying and fitting a new motor, they are very expensive. You need to at least know how to test a motor for faults and check its connections and carbon brushes (if fitted) if you want to try and diagnose the cause
Nov 23, 2016 | LG Washing Machines
LG intellowasher 7kg wd-8015c
SURE VINEGER IS VERY GOOD ON CLEANING WASHER
May 02, 2014 | Washing Machines
I have a lg intellowasher 7kg wd-8015c (front loader), and its not spinning and the clothes come out wet. whats wrong and what parts will i need please
If the washer is not spinning you need to check on the motor, motor capacitor and the power from the program controller unit. If there is no power to the motor then the controller is a suspect.
Please check this link for tips: removing the motor:
Jun 23, 2012 | Washing Machines
You are right!
Apr 07, 2010 | Washing Machines
What does SE mean on my LG Intellowasher 7kg WE-8074FHB display
Error SE is a sensor problem as per LG support.
you need to change the senser of your machine...
Good Luck!!
Mar 22, 2009 | LG Washing Machines
Washing Machines Logo
37 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
