Question about Kenmore 24032\24036 Top Load Washer
How do I get to the lid switch to replace it on my washer
How do I get to the lid switch to replace it on a Kenmore washer Model # 110 22852 100
    Scholar:
  • 87 Answers
Pull of the end caps #14 & 11 on the diagram. Remove the screws and the front panel will flip up. Then there are 2 clips connecting the bac to the cabimet. Snap those out and the the WHOLE front of the machine comes off if you tilt it forward. Go to sears.com and parts to bring up any model for anything and you can kind of see how things go together. Good luck.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=11022852100&productCategoryId=0153200&brandId=0582&modelName=WASHER&diagramPageId=00002&componentDescription=CONTROL%20PANEL&documentId=P0103381&backToLink=Return%20to%20Sub%20Components%20list
Posted on Jan 23, 2009
Kenmore Washer 70 series Model #110.22722100 won't spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped.
Feb 25, 2013 | Washing Machines
My kenmore 90 series washer will not drain i have tried playing with the lid leaver any thing else i can do ,can i replace the leaver switch?
Yes you can replace the lid switch its fairly easy to do...this tip i wrote will help ya to replace the lid switch http://www.fixya.com/support/r9939128-whirlpool_kenmore_estate_kitchen_aid
Series 90 is unfortunitly not a model number please reply with exact model number as found on a label on the rim of the tub inside of the lid and i will give you the part number for the lid switch.
GENE
Sep 12, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore model 70 washer will not empty tub with lid closed.
This is a broken lid switch . You can replace the lid switch or if you need to get it working quickly you can bi pass the switch by unplugging the washer, removing the 2 lid latch screws, pulling out the switch cutting the 2 wires and twist them together with a wire nut.
This is assuming you do not have the self locking lid.But I don't think your model has that function.
May 14, 2011 | Kenmore Washing Machines
Kenmore washer lid switch problem
Good day,
Common problem, Change the switch, and make sure if it is the model with a plunger for the switch mounted on the lid, that that be replaced as well.
Thank you for using FixYa
Dec 29, 2009 | Washing Machines
Replace lid switch on a Kenmore washer
Sometimes on these you need to open the lid, remove the screws there first, then take the screws off the back. Try that.
Aug 06, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Mod# 110.25842400 lid switch
The following link gives you step-by-step instructions on how to replace a lid switch on a Kenmore top loader:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you have any questions about this repair, please let me know. I hope this helps you.
Jul 15, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
How do I get top lid off of Kenmore washer model 110.25852400.
The following link will explain:
I hope this helps you. If you require additional assistance, please let me know.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Need a diagram for a lid switch
Hello jafarrell
What is the exact model # ?
This was the part number!!
You said, you need a diagram of the Kenmore top loading washer, model 20432 lid switch.
This is a Kenmore part # you supplied, so here is where you can get it from Kenmore.
Part # 20432 lid switch as you supplied in our communications!.
http://www.searspartsdirect.com/partsdirect/retrievePartActionHome!search.action?productGroup=N%2FA&partNumber=20432&pop=flush
Thank you for using Fixya.
Huuum
Please remember to leave a rating
Sep 18, 2008 | Kenmore 22422 Top Load Washer
Replacing lid switch
me too...exact same washer and same problem...how do u fix it?
Apr 20, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
162 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
