Question about Air Tools & Compressors
Manual for kobalt air drill LGA-1230 - Air Tools & Compressors
2 Suggested Answers
  • 41 Answers
SOURCE: kobalt air compressor bleed the air tank...
if your asking how to bleed the air tank,it will be done by unscrewing the drain valve on the bottom of tank.
Posted on May 19, 2010
KDD 524B DRILL NEED REPLACEMENT SCREW [IN DRILL CHUCK]
  • A phone call where in your Country is the screw too get what can have a different but should have the same as always a counterclockwise chuck screw there are much handyman everywhere to get equivalent screws for it but maybe to much extra time for some places on earth, i think it should to get from the Kobalt website and by logistic transport it should not be the main cost
KOBALT
Jul 19, 2017 | Drills
Owners manual for Kobalt air tools
Go to Lowe's or Lowe's web site with the model number you should be able to get a replacement manual
Apr 16, 2017 | Air Tools & Compressors
Kobalt 350 impact runs without trigger pressed
Sounds like a problem with the throttle valve.
you will have to remove the air inlet (item# E) then pull the spring out (item# 37) and look to see if you find any foreign objects, if not the proceed to pull the throttle valve (pin cover) (item# 37) and check the seal (item# 34) for wear.
Follow this link for the parts manual:
http://pdf.lowes.com/useandcareguides/879686002796_use.pdf
Dec 31, 2013 | Kobalt 350 ft-lbs Air Impact Wrench...
Oil capacity of kobalt 80 gal air compressor
You could do a little searching on the web, and answer your own question. You can buy a manual for $4.95 at:
http://www.needanownersmanual.com/product_info.php?cPath=21_30&products_id=549&osCsid=tks6fj36b6skq8h7m155hh8kb1
But worse, you don't even need an answer to this question. Simply add oil until level is about half-way up the sight glass. And don't overfill. How simple is that?
Feb 08, 2013 | Kobalt 5.2 HP 80-Gallon 175 PSI Electric...
What oil should I use if Hitachi oil isn't avalible?
On your next trip to Lowes look for Kobalt air compressor oil in the tool department. It sells for under $3 and works great for normal use. They also have Kobalt synthetic compressor oil for extreme conditions and longer use between oil changes. Sell for about $7. I also used Hitachi synthetic oil #19210b 8oz about $8 but hard to find. Kobalt synthetic costs less and works. Good luck.
Aug 02, 2010 | Hitachi EC12 Portable Electric 2hp Air...
I need a kobalt hvlp spray gun manual where can i get one?
Go back to where you bought it and have them photocopy the book from another unit. Good luck!
Jun 19, 2010 | HVLP 10 Piece Hvlp Paint Spray Gun Set
Kobalt air compressor bleed the air tank
May 16, 2010 | Air Tools & Compressors
Need wiring diagram for a kobalt 60 gallon 3.7 hp air compressor.
I have a Kobalt 60 Gal 3.7 hp air compressor. Send me your email address and I'll make sure you get your schematic. Hope this helps! MichaelGG@health.ok.gov
Jun 16, 2009 | Air Tools & Compressors
Brand new Bosch PS 20 drill Kobalt 1/4" bits snap into place, however there is still "play" between the bit and the chuck, creating an untrue bit revolution while drilling. Anyone? ...
It's the nature of the beast. It should be snug enough not to fall out, though. Virtually all cordless screwdrivers have a bit of end play to them.
May 18, 2009 | Bosch PS20 2 Factory Reconditioned 10.8V...
Air Tools & Compressors Logo
66 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
