Question about Sansui 19 in. LCD TV
I'm trying to use my 19" SANSUI SLED1953W Series A as a monitor for my late 2012 mac mini, but it does not show up when I use a HDMI cable.
I have tried going to the HDMI selection and then turning the mac on, but it still does not read. This is HDMI to HDMI instead of DVI to HDMI. I am not able to use the vga port on the tv as the mac does not have a vga female port on it.
  • 8 Answers
SOURCE: NEED A CODE FOR SANSUI 19" HDLCD1908 TV
Sansui Television 1023, 1107, 1122, 1273, 1382, 1383, 1384
Try one of these yet?
Posted on Dec 27, 2008
  • 5 Answers
SOURCE: driver for monitor
if u r using xp sp2 ,sp3 or vista no drivers r required for any monitors as such drivers r installed by windows automatically.ok next is go to divice manager and search for monitors if ur monitor has any issues it is displayed yellow.ok even if the device manager doesnt show up any issues with monitor,u can always upgrade the drivers to the drivers that came with the monitors installaion disk that may be supplied with ur system.
Posted on Jan 17, 2009
SOURCE: Sansui 26 HDLCD DVD Audio DVI/HDMI
Does Sansui HDLCD 19WB have a HDMI outlet
Posted on Dec 21, 2010
gopakumarg43
  • 74136 Answers
SOURCE: Computer vga cable/ sansui tv problem
Hello
Nvedia signals cannot be porcessed by Sansui Tv. You have tow options before you to connect your self assembled computer to this tV. The first one is try by reducing the resolution f VGA output. for that, go to Nvidea control [normally will be displayed at the right end of the taskbar] and chage relolution there. By default, the resolution will be 1024/768. Select it to the lowest; 800/600. If the TV display it, just advance it to the next highest; 960/600.
If this does not help you, there is no other way than change the computer's video card to any other, which works on Windows Video Drive. Can be bought from local computer component market, insert it to one amoung the free PCI socket of the computer and do the next proceedings to change over video output from on board video out, and feed this video signal to yur TV. OK.
Posted on Nov 02, 2011
Slinteriors
  • 8617 Answers
SOURCE: my sansui hdlcd1909 19 in. lcd tv won't turn on. the standby red light blinks once, what can i do to turn it on?
sounds like bad capacitors on the power board. Very common problem. I would look at the caps if any appear even slightly rounded on top they are bad. They should be perfectly flat on top any puffing up means replace that cap.
Posted on Aug 07, 2012
Mac serial numbers C07M3AV8DWYL
According to the serial number, the late 2012 Mac mini's maximum Resolution: Up to 2560 by 1600 (Thunderbolt) or 1920 by 1200 (HDMI). However, this mini does not have a slot loading DVD drive.
The last mini with a slot loading drive was made in 2010. That model's maximum resolution is Up to 2560 by 1600 (Mini DisplayPort) or 1920 by 1200 (HDMI)
Aug 20, 2014 | Apple MAC MINI 266GHz Intel Core 2 Duo 8...
Mac Mini - Signal is not compatible with this intput
Can you change the signal format in the display settiings? 1080p is the native one on your monitor, try difrent ones if availabe. also test difrent resolutions.
Jul 06, 2008 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
What cable is needed to stream Netflix to a Macbook?
If you want to use a TV as a secondary or mirrored monitor. All you would need is a Mini-DVI to HDMI adapter. Use the adapter to connect an HDMI cable between your computer and the TV. Once connected you will have an option to use it as a secondary or mirrored (exact copy of what is on your laptop) monitor. If you have one of the newer macbook pros you need a Mini Display port to HDMI adapter.
Jul 30, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Need to connect hp pavilion vf15 monitor to mac computer
First of all, before you look which one to buy, you need to find out which Video Port does you Mac has, i.e. VGA or DVI or Mini DVI or HDMI. Once it's confirmed, you have to find out the same with your monitor, so that you can buy the appropriate cable.
Pictures Below:
1. VGA
2. DVI
3. Mini DVI
4. HDMI
Good Luck.
Thanks for using FixYa.
Nov 02, 2012 | HP VF15 15 in.
Connect 26pf5520d to a mac mini
Try to connect your Mac Mini to another DVI-capable monitor. May be your DVI out on Mini doesn't function at all
Aug 29, 2017 | Computers & Internet
What adaptor do i need to connect a new Mac Mini with HDMI input to an older SyncMaster 914v?
I assume you mean HDMI output. You'd need a 'HDMI Female to VGA Male' adapter or a 'HDMI Male to VGA Male' cable.
Such as:
http://www.sourcingmap.com/17m-golden-plated-hdmi-vga-male-adapter-converter-cable-p-61779.html?currency=GBP&utm_source=google&utm_medium=froogle&utm_campaign=ukfroogle
I've no idea if that site is reputable or not, just did a search on Google.
Jan 20, 2011 | Samsung SyncMaster 914V 19" Flat Panel LCD...
Yes , i have a proview 22 inch monitor and i connect it to my xbox 360 using an hdmi to dvi cable . the only problem is with the sound , it dont work what can i do ??i even try connecting speakers into the...
How do you connect the XBOX audio line out to the monitor audio input? If the xbox HDMI output is set to send the digital audio through the HDMI cable, you will not get the sound since you are using HDMI to DVI because the DVI is not made to accept the digital audio. You will need to to use the XBOX analog audio output instead feeding the audio cable with mini stereo phone plugs, please read XBOX user manual.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 11, 2011 | Proview PL926WBi 19" LCD Monitor
I want to connect an LG 32LD550 television monitor to an Intel based 24" I mac computer---what cable is needed?
The LG 32LD550 television has HDMI and VGA.
Your iMac has a mini-DVI output port with support for DVI, VGA, S-video, and composite video connections via adapter.
So all you need is either:
1) mini-DVI to VGA adapter.
2) mini-DVI to HDMI adapter.
HDMI is better quality, and so I'd recommend something like this: http://www.amazon.com/PTC-Mini-DVI-Adapter-6ft-Macintosh/dp/B001H0REVK (You may want a longer cable though).
Dec 22, 2010 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
Sansui 19 in. LCD TV Logo
187 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Electro Med Services...
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
