Question about Mitsubishi VS-60603 60" Rear Projection Television
Finding a Capacitor for TV VS60707
I have looked all over the net to find this Ceramic Capacitor R3.15KV1000P-K Part # 154P265000 I need 3 I could use the help to find them TY
    Scholar:
  • 140 Answers
Mouser electronics
Give them a call and give the information. They will have a replacment.
Posted on Jan 23, 2009
I bought a second hand philips tv 29ht2212/79r and have tuned in the channels via the interaction menu using 3 1 9 7 5 3 mute on remote and the sound wont work now. is there something i have to enter to...
open the cover of your tv look for the sound IF using a plastic precesion screw driver adjust the IF counter clock wise slowly untill you reach a good sound or clockwise...if nothong happen solder a 0.2 ceramic capacitor to your sound IF at the coil of the IF under the board the IF has two terminals for the coil.sound if is located near the tuner section..there are two IF the video I.F and sound I.F
May 20, 2010 | Televison & Video
Arcing issue? My tv seems to be arcing in the right rear(facing front of tv) Is it an easy fix that I can do?
Common problem on this tv, ceramic capacitor .087uf 1600V.
Take out the chassis,and inspect under fly bac area, you will se a burn area; replace thsi ceramic capacitor. for parts. go to:
encompass.com thank you
Aug 02, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Need to know the value for Capacitor CX3211 on the edge of the board. The CX3212 next to it reads HR R 561K 2KV and I wonder if they are the same. THe CX3211 burned and the TV died. I am layed off and...
The value of CX3211 is 1000pF 10% 2000V, ceramic disc.
You can also download the service manual from this website. Make sure to download all the 7 files.
Good Luck.
Jul 26, 2009 | Zenith B27A11Z 27" TV
Will not power up
I had a similar problem. Look for a burned/shorted out capacitor on the main board. (It is marked J-something I forgot), 10mm diameter ceramic capacitor, 1000pF 20k SON116175400
It is about 3-4" from the left edge of the main board (power supply side), near the middle of the board. It is close to a large transistor mounted vertically on a cooling plate. It is a special high-voltage capacitor, you can find it online. Check the large transistor - it may be damaged too (mine was ok). After installing the new capacitor I got good sound and really weak picture. I called a repair guy who found a bad chip - after 3 hours of looking. The TV works fine ever since. As I learned, in most cases all you need is a new $5 capacitor. If you had a good picture before, it is worth the "investment" to fix this problem.
Jun 10, 2008 | Sony KP-53XBR45 53" Rear Projection...
Mitsibishi vs60707
This a deflection problem. Both 2-3 and 2-4 are deflection. Most likely a verticale problem. a tech will need to fix it.
Mar 15, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Tv flutter
If your going to do the repairs yourself you can probaly get by fairly cheap, but service techs usually run between 3 and 6 hundred for video problems sounds like a capacitor issue. If you need a service manual and unlimited support for your set go to this link. Its 10.99 for the manual the supports free. They will mail it unless you return to the site and request that they email it along with the instructions on how to obtain the chat support. I am one of their support Techs, Hope this helps.
http://servicemanuals.vstore.ca/
Jan 16, 2008 | Mitsubishi VS-60707 60" Rear Projection...
Standby timer light blinking, tv will not turn on
Check out Ceramic Capacitor C514 by the horiz. output transistor (burned/shorted?) My question is how do you find the specs of the capacitor and where do you buy one?
Dec 11, 2006 | Sony KP-53S65 53" Rear Projection...
TV power supply problem
.01 mf 2000 volt. in flyback circuit .it is a timing capacitor. the red high voltage block is bad and that took out the capacitor. also check the horizontal output transistor...it is probably shorted.
Aug 25, 2006 | Sony KV-27V26 27" TV
Televison & Video Logo
70 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
