Question about Epson Stylus Photo R1800 InkJet Printer
R1800 wheel marks on print
When printing on glossy paper at photo setting, I get wheel tracks on the printed image, it appears that the tiny "star" wheels are picking up ink from the printed page and leaving a dotted track behind. I have had the printer for about 1 1/2 years, this problem has just started.
  • 115 Answers
You can try to load your paper by the back of the printer. This problem problably arrived wen you taste a new heavy paper (too heavy?)
Posted on Feb 04, 2009
When printing, if I select any other form of paper than "Plain Paper", e.g. "Photo Glossy Paper", the print (of a photo) comes out with a distinct Magenta overhue. The true colours are...
Hello Landscapeman ,
You need to specify the paper type when the print dialog box appears. Heavy glossy paper needs to spend more time in the fuser so that the toner is fixed.
Mar 25, 2008 | Computers & Internet
Blotchy color on glossy paper
Hi
This link will take you to common problems and how to use glossy paper.
http://support.gateway.com/s/tutorials/Tu_844855.shtml
see it, and let me know if that didnt solved your problem
Jan 10, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Epson R1800 On Print Preview of a photograph
I print with the R1800 as well as the 24" 7880 in my studio. Whenever the "preview" shows less than the whole image I intend to print it is generally either the orientation (portrait/landscpe) is set incorrectly or the Paper size selected is incorrect for the size of the print.
Hope this helps
nickerjo
leaningpalmstudio.com
Mar 01, 2010 | Epson Stylus Photo R1800 InkJet Printer
When I print on photo paper the ink doesn't dry and picture quality is unrecognisable
You have to match your print settings with the correct type of media used !
When you print, set the preferences, set to PHOTO quality and not draft, set paper type to PHOTO PAPER, or GLOSSY PHOTO PAPER whichever - If you select wrong media type your colors might be off. Select the settings that match the closest to your media. If you use paper use "plain paper" setting, if you use glossy photo paper, use "glossy photo paper" as settings and PHOTO quality.
I recommend use you use inkjet PHOTO paper, glossy, you can use HP or EPSON or even the cheap LIKON ones work amazing for me, they should be able to dry quickly, if they don't you are not using the correct settings.
By your description above it looks like you are using economy or draft mode - NOT good for photo paper.
Sep 26, 2009 | HP Office Equipment & Supplies
Messy print when using glossy paper.
ok. sometimes the ink for hp if its not photo ink will do that. go to your printing settings/preferences and adjust your ink out put to less and dry time to more. you may have to adjust a few times to get the right balance. if you dont want to set it up for all printing you can also change settings when your ready to print. . just follow same steps when you are going to print. but you have to do it everytime you want to print a photo. also make sure to set your paper selection to glossy photo paper
Apr 24, 2009 | HP Color LaserJet 2600n Printer
R1800 head streaks
I have been plagued by the same problem - the nozzles don't appear clogged - yet on heavier media there is a definite abrasive sound - and its leaving horizontal bands. After many cleanings with no luck I tried cleaning the heads with a bunch of Q-Tips lightly coated in Windex. After removing a ton of black deposits - it didn't immediately fix the problem; frustrated I turned the printer off. The next morning when the clean-heads-on-power-up kicked in - I noticed a large amount of ink collected in the vacuum sponge. It seams the bit of reside left over from the cleaning may have finally dissolved what I can only guess was a large ink deposit that had hardened and was striking the media when heavier stock was loaded. At any rate - no more abrasive sounds - and more importantly no more horizontal banding.
To clean I disconnected the power when the head was traveling. Then the head was free to move as I gently tried using the Q-Tips to clean the heads.
Hope this helps.
Dec 07, 2008 | Epson Stylus Photo R1800 InkJet Printer
Samsung CLP-300 dark prints and smears
For starters remember this is not meant to be a PHOTO Printer, I am guessing the Spearing is because Glossy paper does not hold the toner like Regular paper or at least until it is fused. I am a technitiian and i also own this printer.
Jul 14, 2008 | Samsung CLP 300 Laser Printer
R1800 Borderless Printing Problem
Hi Tom, Have you downloaded the latest driver from the Epson web site. Also make sure the output tray is in the correct position and that you are using the correct paper. You can use the following media with this feature: Matte Paper - Heavyweight A3+, A3, A4 Premium Glossy Photo Paper A3+, A3, A4, 10 x 15 cm (4 x 6 in.), 329 mm x 10 m, 210 mm x 10 m (Roll paper) Premium Semigloss Photo Paper A3+, A3, A4, 329 mm x 10 m, 210 mm x 10 m, 100 mm x 8 m (Roll paper) Archival Matte Paper A3+, A3, A4 Watercolor Paper-Radiant White A3+ Velvet Fine Art Paper A3+ Ensure the output tray is in the correct position as if the tray is too low and the paper "falls" down into the tray the weight of the paper could pull the last few millimeters of paper out of the exit rollers, causing the band.
Aug 15, 2007 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
160 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
