Question about Vacuums
Vax vstm1500 leaving streaks on floor - Vacuums
Why is my Dyson v8 leave white streaks on my hardwood floor. the vacuum is clean. I cleaned the wheels underneath and it still leaves streaks.
Get solution for this online at www.reliable-store.com and get complete guide on whether to repair or not, service it, and how to repair etc
Mar 12, 2018 | Dyson Vacuums
Tip
Shark Steam Pocket Mop Cleaning Problems
After watching Shark Steam Pocket Mop from the vantage point of Fixya.com for a few months and seeing the many problems that people were having with the Shark Steam Mop streaking their floors and especially hardwood or laminate flooring I decided to do some research and reading about this problem.
What I found was very interesting.
Many people are blaming the steam mop for their problems, when in fact the problem is just coming to light because of the use of the steam mop. It seems that if other cleaners have been used on the floors they leave behind a residue. Then you come along with this mop that produces a heated steam type cleaning and you start to take this residue off of the floors. This then leaves the flooring blotchy or streaking.
So now what do you do with you floors when you get this mop and what will cure your streaking, blotchy floors? There are a couple of ways....
First way is to just keep on using the mop. Many people report that their persistence has paid off and that after a few uses the shine comes back to their floor as the old scum and residue is more completely removed.
The second way is to use a vinegar and water solution to manually clean the flooring before using the mop. This takes a bit more elbow grease, but will get the floor looking really sharp much quicker. Here is a site that tells about that.
So if you are having a heart attack because your mop seems to be making things worse instead of better then don't give up too quickly!! Use it a few times first... it has a 1 year warranty. Or get on your knees with that pail of vinegar water and get the old gunk from all those other cleaners off of your floor first.
heatman101
Here are some other related tips to check out....
http://www.fixya.com/support/r5859780-euro_pro_shark_steam_mop_problem
http://www.fixya.com/support/r6896271-find_shark_parts_accessories
on Nov 07, 2010 | Vacuums
Shark steam mop leaves streaks on tile floor
We only use distilled water in our Shark so minerals do not build up. Even doing that ... probably every year we run a 50/50 vinegar solution through it (heat unit up and let it steam for several minutes ...but do not use on the floor). This helps to remove any buildup. That might be the cause of the streaking....
Dec 14, 2017 | Shark Vacuums
How do I stop the brush turning on my Vax U86-PM-B when on hard floor mode
Take it to your local vac shop for service. It sounds like the drive pulley and idler pulley need adjustment.
Feb 19, 2015 | Vax Vacuums
How do I put water in a Vax steam hard floor mop
GO HERE> http://www.vax.co.uk/video-gallery/
Sep 30, 2014 | VAX Appliances Vacuums
Vax u90-p4p not picking up
You need to look for a blockage in the floor suction area.
Dec 03, 2012 | VAX Appliances Vacuums
How do you use vax 2000 to shampoo carpets. do not have a manual
Set up is complicated unless you are patient.
Remove the paper dust bag from the bottom of the canister and then filter ring. Then put in the recovery bucket of which 4 litres of warm water should be added and a capful of floor cleaning solution.
Then remove the pump wire on top of the Vax motor where the blue filter circle is (keep the filter in, do not remove it!).
If the 2000 has a separate pump notch on the rim of the Vax motor head on the outside then you should plug the black cord in that has a washer screw type metal connector. Push, twist and lock in. Then the black cord which eventually leads to a clear pipe with the older clip on wash handle that has to be clipped to the main hose handle has to have the black and see through cord clipped to the main hose and eventually down the extension pipes until you get to the floor head. If you have the older style T shaped floor head the cord should slip into the floor head easily. Then either squeezing the trigger to release the cleaning solution in, switch the Vax on and hit the secondary pump button. This will pump the cleaning solution and water into the carpet. To stop the pump you can either lock the wash trigger to stop the liquid or squeeze the trigger to make sure no other liquid comes out. Generally you can see the foamy carpet solution flowing through the see through rubber hose and eventuallly through the floor head.
To **** up the rest of the carpet solution, stop the pump button and the Vax can be used to **** out all the dirty solution/water in the carpet. Its a big and tedious task generally!
See an alternative manual for the Vax 1000 which is an older model but similar to the 2000. It is free and in pdf downloadable form:
http://www.vax.co.uk/downloads/pdf/VaxGuideNo8a.pdf
Jun 15, 2009 | VAX Appliances 2000 Canister Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
