Question about HP OfficeJet 6100 All-in-One CB863A
Attention required on printer - HP OfficeJet 6100 All-in-One CB863A
SHOWING ATTENTION REQUIRED PRINTER HAS A PROBLEM THAT REQUIRES YOUR INTERVATION
The page at the link below has a comprehensive listing of all of the error codes for your printer.If you do not find an answer there, you may need to find and install drivers for your printer.
PIXMA Printer Error Codes and Error Messages
Apr 28, 2015 | Canon PIXMA Office Equipment & Supplies
How can I fix the issue when my printer says "User intervention required?"
I'd guess you have a paper jam, maybe even tiny piece.
Check error message on printer's panel. try turn off for 10min.
turn back on. Users manual on software install CD may help understand message.
Mar 08, 2015 | HP Office Equipment & Supplies
Red light blinking
The Attention light is flashing red.
Solution The printer requires attention. Try the following:
* If the printer is connected to a computer, check the computer screen for
instructions.
* If you are printing a CD label on a CD/DVD, insert the CD/DVD holder in the
CD/DVD tray now.
* If you have a digital camera connected to the printer, check the camera screen
for instructions.
* If the printer is not connected to a computer, check for the following problems:
- Main cover open - Out of paper - Paper jam - Print carriage jammed or stuck - Print cartridge missing or inserted incorrectly - Print cartridge tape not removed - Incorrect print cartridge installed - Packaging materials are not removed * If you are unable to solve the problem by using the instructions above, turn off
the printer and unplug the printer power cord. Wait 10 seconds, and then plug
it in again. Turn on the printer.
Feb 18, 2014 | HP Photosmart D5160 InkJet Printer
There is 2 inch black smudges (tire tracks) across every page I print.
This would indicate that either the developer ,Drum or Fuser requires attention .If you stop the paper before the fuser unit is the mark there? if not then it would point to the fuser unit.
Jan 24, 2013 | Kyocera Mita FS 3800 Laser Printer
! mark is blinking
I had the same problem on my HP Officejet J4580 All In One. Control Panel Guide jsut said it requires attention but no further details. I disconnect4ed the power supplu and waited a minute, pluget it back in and it seemed to work fine. go figure...good luck
May 17, 2012 | HP OfficeJet J4580 All-In-One Laser...
The red triangle light with the "!" in it keeps flashing. I've just printed some things off but now it's not printing. Need it to print obviously..
ATTENTION light(triangle): Indicates that the print-cartridge door is open, print cartridge is missing, and other errors.
If ATTENTION and READY light is blinking:
Printer initialization
The printer is initializing.
No action is necessary.
Cleaning mode
A cleaning page is printing.
Wait until the cleaning page has finished and the printer is in the Ready state.
This could take up to two minutes.
If ATTENTION and READY light is on:
Fatal error
Turn off the printer, and then unplug the printer power cord for 30 minutes.
Plug the printer power cord into the power outlet, and then turn the printer on.
If the error persists, replace the printer.
If ATTENTION light is blinking and READY light is off:
  1. Attention: door open, no print cartridge, or media jam
The printer is in an error state that requires operator intervention.
Check the following:
? The print cartridge door must be completely closed.
? The print cartridge is correctly installed.
? There is no media jam.
2. Out of memoryThe printer is out of memory.
The page you are printing might be too complex for the printer's memory capacity.
Try lowering the resolution.
Aug 01, 2011 | HP LaserJet 1020 Printer
Describe your HP LaserJet 1012 Printer Problem light flashing
If your HP Laserjet 1012's attention light is flashing,
Door open, media out, no print cartridge, or media jam
The printer is in an error state that requires operator intervention or help. Check the following:
  • The print cartridge door is completely closed.
  • Media is loaded.
  • The print cartridge is correctly installed in the printer.
  • There is no media jam.
Mar 12, 2011 | HP LaserJet 1012 Printer
Printer sporadically displays a red light three successive flashes error and will not respond to till / keyboard. What does this mean?
PUT PAPER INSIDE PRINTER POWER OFF THE PRINTER.
THEN PRESS & HOLD THE BUTTON ON TOP OF PRINTER
BY HOLDING THE BUTTON NOW SWITCH THE PRINTER ON & WAIT UNTIL THE SIZE OF PAPER IS SCANNED .
IT WIILL BE DONE.
Feb 08, 2011 | Epson TM88II Thermal Printer
I get error message "Unable
Computer messages provide the presciption of the condition requiring attension. For example, the message unable to clean has an identification number also as reference to the the condition specified. An attempt to clean the printer would require preparotory measures described.
1. Examine the printer device qeenly to ascertain complementary requirements before further processes are achievable. For example, printer cleanup may require replacement parts, ink cartridges, ribbons, perhaps papers.
2. Acquire the printer cleaning kits. For example, cleaning solvent specificed for printer devices, cleaner clothes, and brushed tools for reaching into corners.
3. Acquiring the printer user guide as instructions provider to achieve the process. For example, prior to the cleaning activity, familiarise with the user guide of the printer. Take qeen attention to printer diagnostics found on the references catalog area because may have provided the means to acheiving the problem encounter as message.
How to clean up the printer with tools provided.
First, the printer require dismantling the removeable components. For example, the lose areas usually printer ink stations, paper feeders, printer out document holders would require removal before commencing printer ceanup.
Second, Take care in the process of removing part components. Meanwhile observe any broken parts that may require replacement on the compartmentalisation process.
Third, Cleaning the printer includes external areas, internal areas, and finally only components that require cleaning should be cleanedup. For example, the ink cartridege is delicate would leat require tempering with, especially should be stored at delicate area to prevent contact with moisture, or ink floating sepage.
What to expect duringg the clean up process
First, clean any noticeable particles, dusty, paper remnants etc.
Second, replace every component parts soon after the cleanup is complete
Third, printer accessories like printer paper, ink, ribbon soon after replacement would require reallignment. For example, powering on the printer, attaching to a computer, attempting to print a document should initiate the allignment procedures. A. The printer sends messages to the computer requiring test sheet printouts. For example, it is likely for the printer during this stage to produce malallighed printer out sheets. Also likely is several mesages requirng approval as users authority to reestablish printer. Every process taken until the first appropiate printer out is acheived is called an allignment process.
Jan 11, 2011 | Brother Office Equipment & Supplies
Power on,amber loight led on and no action
Exclamation light
The amber light in the shape of an exclamation mark (!) blinks when the unit requires attention. The display will give further information. The light is off when no attention is required.
Sep 25, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6100 All-in-One CB863A Logo
407 people viewed this question
Seeker5211
Seeker5211
