Question about Canon imageRUNNER 3300 All-In-One Laser Printer
My ir3300 xerox machine not print out.please solve thins problem.
I bought ir3300 xerox machine.but my xerox not run to print.
  • Anonymous May 18, 2009
    i have some problem like that my printer ( canon ir3300 ) not work properlly printing one than not print when i restart my machine print or not, is not fixed
    Sniper:
  • 89 Answers
How are you trying to print? You need N boot rom. Press Counter Check. Do you see IR3300(IR2200N) or IR3300(IR2200). If you see the N then you should be able to print with it. If not, you can't.
In Service Mode (to get into this press Additional Functions (button with * on it) > 2 then 8 > Additional Functions) go to Copier > Display > Version. What do you see for BOOT-ROM (does it have a N at the end?). For PS/PCL what do you see?
If your BOOT-ROM is N and you don't have a number for PS/PCL then call a technician to install networked system software.
If BOOT-ROM is not N, buy a Network Multi-PDL Kit C1 and get a technician to install it and load N system software.
If BOOT-ROM is N and you have number for PS/PCL check your IP settings. Make sure that DHCP is turned off. Set up your printer using an IP port with the static IP address assigned to the copier.
Use PCL5e or PS drivers, don't use PCL6.
Posted on Jul 15, 2009
  • imdadaliakdiwala
    imdadaliakdiwala Nov 01, 2013
    how to connect canon ir3300 zerox machine to windows pc????
    Sergeant:
  • 199 Answers
Check IP address for lan cable in the copier & print driver
Posted on Feb 26, 2009
Print is comming so light in between
Posted on Jun 16, 2012
How to connect this ir3300 xerox machine to computer plz tell me sir i request u
you need to have a driver installed on each P.C
http://www.usa.canon.com/cusa/support/office/b_w_imagerunner_copiers/imagerunner_2200_2220i_2220n_2800_3300_3300i_3300e_3300en_3320i_3320n/imagerunner_3300#DriversAndSoftware
You need an ethernet network of computers
You need to set up the ip addess and subnet mask in the printer via its setup menu . At the very least a ethernet network Switch with static ip addesses for each device , or A router with DHCP server to dynamically assign ip addresses.
you need an rj45 socket on the ir3300 which it should have 802.3 ethernet 10/100 tbase ethernet according to ir3300 specs if it is missing you need a network card to be added to ir3300 by Xerox / Cannon
Sep 05, 2015 | Xerox Office Equipment & Supplies
Tip
Canon ir3300 xerox machine
You can use the xerox machine as printer as well. As we all know this and we can take back to back printouts Here how to take it. When you are giving a print. Select properties. Then select finishing tab. In that in print style drop down menu select 2 sided printing and then press ok.
Here you can save paper and also can save trees as well.
Let's fight pollution
on Jun 12, 2010 | Computers & Internet
Error E000007 Canon xerox machine ir2200-ir3300
Error of E000007 -0000 IR3300 Machine What we can do ?
May 17, 2011 | Garden
In my ir3300 xerox in very light
That means that you have to clean copy glass , lenses, ccd,...maybe even laser unit if you know how.
On digital machines dirty optics means light copy, on analog oposite, dirty optics dark copies.
Just one more question how do you mean " charge toner"?
Jun 07, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Hello, i have a canon xerox machine ir3300 model. I have a problem in Error Code. The Error code is E000000-0000. Please tell me how to solve this problem. my e-mail id is: mcpx_vpy@sify.com
There is a problem in the fuser area of the copier. For some reason the fuser is not heating to the proper temperature. There are several possible causes such as a failing/failed thermistor (this is a heat sensor device that monitors the fuser's temperature) or a thermal switch (this is a device that, based on the current value of the thermistor, either turns on the heating unit or turns off the heating unit) or the heating element itself could be bad, etc etc etc
Unless you are a technician with extensive Xerox experience I will advise you to contact Xerox about tech support.
Oct 07, 2009 | Canon Office Equipment & Supplies
When i switch on the machine,error E000002 is comming
E00002 on iR3300 is problem on the heater assembly. Replace heater assembly and buy new heater assembly. Good Luck...!?
Feb 06, 2009 | Canon Office Equipment & Supplies
Canon ir3300 or 405 better
Definitely go with the 3300 (if you haven't already). It's one of the best B&W copiers Canon has ever produced. The 3300s still sold as refurbs by Canon in the US so parts will be around for them over there for quite a while yet.
Oct 08, 2008 | Canon Office Equipment & Supplies
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
1,180 people viewed this question
old marine
old marine
