Question about Samsung LE40B650T2 40 in. Full HD Crystal LCD TV
Samsung 1080 flat screen color picture quality
There's a blue hue on the picture and tne colors are not coming in.
SOURCE: blue tent while playing movie
It seems to be something wrong with the processor as it sometimes 'resets' when you turn the TV off and then back on again.
Posted on Mar 16, 2008
  • 5 Answers
SOURCE: Best Picture Quality
Check this link out. I think it should give you all the info you need for optimal picture settings.
http://help.cnet.com/samsung_LN_T4061/9602-12576_39-0.html?messageID=2510125&tag=tip-2510125&kw=samsung+LN-T4061
Posted on Jul 15, 2008
  • 2509 Answers
SOURCE: I have a samsung 1080 full hd 38" flat screen tv,
I think the backlight is failing, you will need to have it replaced. It is also possible that the backlight inverter (power supply) may be faulty but that usually shows up a fault. I think it unlikely that the screen itself has failed unless it has been subjected to pressure damage.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Posted on Mar 01, 2011
walesarumi
  • 6993 Answers
SOURCE: I have a Samsung LCD
First, connect the TV to a DVD player and observe if problem will still be there. If problem persists, then it mean the fault is from your TV's LCD inverter. Sometimes, a defective video cord can cause this type of problem, this is why I asked you to connect the TV to a DVD player.....
Your TV has a long board that is called LCD inverter board. This board is defective or dying.
This long LCD inverter board's only job is to provide the TV LCD screen panel to have a back-light to the LCD screen panel to produced a picture.
Try websites like shopjimmy.com, ebay.com to buy a refurbish long LCD inverter board for the replacement.
If you are not a TV expert, please take the TV to a repairman for the LCD inverter replacement. This is not expensive to fix...
Note that TV store current, so wait for some minutes before attempting to open the TV's back cover.
Good luck.
Posted on Apr 15, 2011
  • 5425 Answers
SOURCE: We own a samsung flat
It sounds like you have the Store Demo Mode on. To turn this off, press the volume button. While the volume is displayed in the OSD (onscreen display), press and hold Menu for 5 seconds (or a bit longer).
Alternatively, you can find this in the menu. When TV is the source, press Menu > Setup > Plug & Play followed by Enter. (It's the second choice after Language.)
The manual is available here: http://www.samsung.com/us/support/downloads/LN46C530F1FXZA . This is on page 7.
I hope this helps.
Posted on Jun 16, 2011
What is the perfect amount of red,blue,and yellow hue for the screen
that's got t o do with personnel preference and room lighting , but as a general rule adjust color hue's till the edges of a white color object on screen has just lost its primary color edge
the older projection TV's actually have voltage numbers for the service tech to adjust them too , but im not remembering seeing any in the LCD manuals
Mar 29, 2016 | Element Electronics FLX3210 32 in. LCD TV
Red blue hue on picture
ur color setting has certain problem. from ur remote control go to color setting and set ur req.color
Mar 10, 2012 | Televison & Video
My screen has little dots appearing sometimes red sometimes blues behind the picture i just replaced the lamp bulb as i thought it would cure the problem
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
Feb 06, 2011 | Samsung Televison & Video
Color section in tv receiver
can I know what is the answer for that question.
Feb 23, 2010 | SAMTRON 96B 19" CRT .22MM 1600X1200...
Blue streaks and faint blue blotches on screen
The Optical Block / Light Engine is the problem. Very expensive repair / over $1000
Aug 08, 2009 | Sony KDF-42WE655 Television
How to adjust color on sk-32h570d
This is from the MANUAL
www.westinghousedigital.com/pdf/197_User_Manual.pdf
PAGE 27
A-1 Settings
Use the Settings sub-menu options to manually adjust the display quality. Use the ◄/► keys to adjust the
option level.
Adjust the luminance level.
Adjust the brightness to darkness ratio.
Adjust the balance of the red, green, and blue colors in the display.
Adjust the color intensity.
Adjust the sharpness or softness of the display.
Adjust the brightness level of the screen backlight.
AND this is from the troubleshooting procedures in the manual
PAGE 64
Wrong, abnormal or missing colors
・ If any colors (red, green or blue) are missing, check the video cable to make sure it is securely connected. Loose or broken pins in the cable connector could cause an improper connection.
・ Press and select Picture | Settings to adjust the Hue and Saturation settings. You can also select
Picture | Advanced to adjust the Color Temperature settings.
・Connect the TV to another computer and check if the problem is with the computer screen.
Other than that there is no mention of color adjustment
May 08, 2009 | Westinghouse Electric SK-32H570D 32 in....
Static on 50
WHAT COLOR ARE THE SPARKLES? IF RED , BLUE AND GREEN, THEN IT NEEDS TO HAVE THE PANEL VOLTAGES ADJUSTED
Dec 08, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
DLP Colors Are Off - Picture Is Mostly Blue and Yellow
Sounds like you've lost your red video signal (chroma) somewhere along the line. This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. The analog has all your inputs on it, except DVI and RGB which go straight into the digital board. The digital scales (upconverts) the signal to HD (1080 or native) and sends it to the DMD or light engine. See which inputs are distorted. If only DVI is clean then you problem is the analog board. If you menu and everything is distorted then suspect the DMD board. If you run component or DVI through the resolutions (480i, 480p, 720p, 1080i) you can get an idea between the digital board and dmd. The menu is generated on the digital board. Somewhere red is getting lost.
Dec 08, 2008 | Samsung HLN5065W 50" Rear Projection...
Yellow hue
1)Please verify your model # from back of set......
2)Reduce the color to minimum or tune in a black & white chan.
you should see gray, not yellow hue
3)Remove lower front grill cover & access panel.....locate the
focus / screen control block...turn blue screen control slightly
CW......red,green and blue must mix to equal gray
4) reset color to normal level.......reassemble
Dec 22, 2007 | Toshiba 57H82 57" Rear Projection...
Samsung LE40B650T2 40 in. Full HD Crystal LCD TV Logo
Jerry Greenberg
Jerry Greenberg
