Question about Danby DWC610BL Wine Cooler
Why is ice building up in back of wine cooler
The wine cooler is cooling but the display does not show that the fan is running but it is. frost is inside the back of cooler
DOREEN1
  • 51 Answers
SOURCE: cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Posted on Jan 31, 2008
  • 1122 Answers
SOURCE: WINE COOLER NOISE
when the fan comes on so does the compressor,hold the fan with a rag and see which one is making the noise-mike
Posted on Nov 11, 2008
  • 1122 Answers
SOURCE: Wine cooler doesn't cool
you need to turn the temp. setting all the way up,use a rag to hold the fan,now see if the compressor. is running,let me know-mike
  • 44 Answers
SOURCE: danby wine cooler compresser not running and is hot
The compressor needs to be tested to see if it's operational. This normally needs to be done by a service tec.
Posted on Aug 21, 2009
I have frost on back of unit.what to do?
Usually if you see frost or ice it is because the Freon level is low. There is a 5 year warranty on the compressor and sealed cooling system so if your within that period, I would call the manufacturer.
May 14, 2016 | U-Line 75WC Wine Cooler
Why is our EuroCave DUO wine cooler model D264 freezing 1/4 inch of ice on back wall inside cooler?
Most cases of ice build up can be traced to seals that leak humid air into the cooler. Check the door seal carefully using a fresh $1 bill. The bill should not pull out easily when the door is closed. If the unit has a self defrost feature it it is not coming on. Ice buildup inside a wine cooler is very rare. The cooler box should not reach 32deg in normal operation. Does the unit seem to run continuously?
Sep 10, 2014 | Furniture
Why is there ice build-up in a frost-free cooler?
Check the drin, its probably plugged up.
Aug 20, 2014 | Furniture
Not colling
Check the back to see if the compressor is running or just really hot. If it is not running it could be a thermostat issue, but if it is hot and not running, that means your compressor has problems and will need to be replaced.
Apr 07, 2014 | Whirlpool 22" Dual Zone 38 Bottle Wine...
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
It just stopt cooling (wgersdorf@yahoo.com)
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
Ice build-up on GE ZDW24A wine cooler cooling coil
Probably the thermostat is bad , you can bypass it by putting together the two wires from the thermostat and if the unit starts working ,replace the thermostat ;only do this if you havesome knowledge of electrical work and be very carefull.
Nov 04, 2009 | GE ZDW24A Wine Cooler
My Frigidaire freestanding wine cooler only seems to cool as low as 53 degrees when I have it set to its minimum temp. The manual says the minimum temp should be 40. Is something wrong with the unit?
YES! Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Condenser Self-defrosting refrigerators all have a set of coils and a cooling fan, usually under the refrigerator, that need to be cleaned regularly. If these coils get coated with dust, dirt or lint, the refrigerator may not cool properly. The coils may appear to be a thin, black, wide radiator-like device behind the lower kick-panel. To clean them, disconnect the refrigerator from the power source, use a refrigerator condenser brush
Aug 22, 2009 | Refrigerators
Ice is forming on the outlet holes on the face of my 4200 xlt
you should check to see if the fan at the back of the unit is operating, and you also need to check for dust build up, if the fan is working then clean and defrost the unit, try it again, make sure there is nothing blocking the airflow, if the motor is not running, replace the motor, hope that helps
Jan 18, 2009 | Vinotheque Whisperkool 4200 Wine Cooling...
The fan to disperse air inside the STC55800 wine cooler is inoperable.
9721, Boul Métropolitain Est
Anjou, QC, Canada
H1J 3C1
Telephone : 514-374-5343
Fax : 514-374-5344
Oct 04, 2008 | The Cellar STC55800 / STC55810 / STC55820...
Danby DWC610BL Wine Cooler Logo
18 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
