I have a Zyxel q1000z and would like to hardwire everything. Is there a way to use it as a regular modem and turn off the wireless signal?
  • 242 Answers
You can certainly turn off the wireless signal. This is located under Wireless Setup -> Radio Setup on the router's administrative page. If you are hard wired to the router, do the following:
  1. Access login by clicking: http://192.168.0.1
  2. Enter default* username: None
  3. Enter default* password: None
If any of the default information has changed and you do not know what it is, you will likely have to reset the router to its default specifications.
Posted on Jan 14, 2013
SOURCE: wireless light is green but i don't receive any signal on my laptop?
how do i do that
Posted on Feb 22, 2008
SOURCE: Zyxel Modem Router P660hw wont work on LAN
If a LAN connected PC will not work while a wireless laptop is connected you need to go into advanced router setup, bandwidth management, and untick the three boxes labeled "active" to disable the band width management. Easy!
Posted on Apr 30, 2008
SOURCE: modem reboots when using wireless
Did you try upping your lease time and see if that changes things.
The lease time is the amount of time before a DHCP request a new IP address.
Ususally it get the same, but if it is malfunctioning it can cause problems like this.
Posted on Oct 19, 2008
  • 68 Answers
SOURCE: I`VE GOT ZYXEL P-660HW-T1 WIRELESS MODEM I BOUGHT
You will have to reset the router to factory settings. There is a small hole in the back, depress the microswitch with a paper clip when the power is on. The default password is 1234. Some of these devices are general, while others are hardwired to work with certain providers. So if, say, this 660 is branded with embarq it is unlikely that you can set the parameters to work with other providers.
I should mention that if you care about security you should not use WEP - a cracker can break an internet connected WEP device in minutes with the right toolset. The protocol has many problems that simply can't be fixed, period. Consider using WPA2 with WPA backcompatability, as allowed by the 660.
Posted on Jan 07, 2010
  • 68 Answers
SOURCE: I'm not able to go wireless with my Macbook (I am
This was asked a very long time ago, and I presume you have not been waiting for 7 months for a response from here.
I use a lot of different devices with my 660HW. including a PS/3 and my Android cellphone.
My suggestion would be to:
1. Broadcast your SSID, at least until you have gotten wi-fi working.
2. Use WPA2 with WPA compatibility turned on. You should not use enterprise solutions unless you have a radius server, and if you do I don't expect you to be asking these questions here.
3. Initially select a simple, repetitive security key, like dumdumdumdum. Do not leave it like that. Be sure you have turned on "let me see what I type".
If you post another question here, please give us more info. For example, what message do you get? Can you see the access point with your macbook at all? If it fails to connect, does it take a while or fail in under a second?
If you can't see the AP at all, maybe you need to enable it in the zyxel. These devices are used by one of the big providers as the default device that is given to end users, and wi-fi may default to off.
How do i fix connection for router zyxel wap3205
Turn your DSL/cable modem off.
Turn your ZYXEL router off.
Turn your DSL/cable modem on.
Turn your ZYXEL router on.
Restart your computer.
You should now have an Internet connection.
Mar 05, 2015 | Zyxel WAP3205 Wireless Access Point -...
How to set up zyxel NBG416N in universal repeater mode
Yes Zyxel nbg-416n does indeed support repeater mode but you need to make sure you have at least firmware version v1.00(USA.5)C0 and you can switch to that mode via maintenance/sys op mode.
Jun 14, 2012 | Zyxel Communications NBG416N 11N 150N Wlan...
Q1000z red light
You may need to reset your device and you will see a reset button at back of your router so all you need is to keep holding it for 10 seconds then unplug the power jack for like 1 min and then your device shall be reset.But please make sure to backup your all settings first. Good Luck
May 02, 2012 | Linksys High Performance Zyxel Q1000z...
Dec 11, 2009 | Zyxel P660HW-D1 Router
I tried to reset my security password and now it won't work.
Make sure you have the physical connection connected properly.
-Modem should be connected to the Internet/WAN port of the router.
-Your laptop must be connected to port 1 of the router as well.
-Make sure you can go online hardwired to the router.
Then configure the wireless settings of the router by accessing the router setup page http://192.168.2.1, change the wireless settings.
Jan 19, 2009 | NetGear WGR614 Wireless Router
Wireless connection fine but internet connection impossible
if you only have usb connection in your modem, internet on the zyxel router will not work since it's using ethernet connection. in order for your zyxel device to work with tiscali, you will need a cable/dsl router that has ethernet connection as well. you can contact tiscali if they can provide you with that kind of modem.
hope this'll help you
ciao
Nov 10, 2008 | Zyxel Prestige 334 Router
What is LiteOn Modem DP/N 0H9379. Is this a wireless modem?
It's just a regular modem, LiteOn is name brand, just like Conexant. Also, modems are used for dialing on a land line, and must be connected or hardwired to a land line, there is no such thing as a wireless modem, however there are modems that can communicate with computers through wireless receivers, but they are not considered wireless modems, they're considered and called wireless capable modems. These are generally found in high end office fax machines.
Aug 14, 2008 | Dell Inspiron XPS M140 Notebook
Connecting using wireless
because of zyxel support only zyxel product only
Apr 03, 2008 | Zyxel Prestige 660R Router (91004397002)
Wireless connection of 570s ap to zyxel wireless modem
did you get the cd with the router? I would run the cd. if not, what OS you use?
Nov 11, 2007 | Zyxel ZyAIR G-570S - Wireless access point...
Computers & Internet Logo
155 people viewed this question
David Payne
David Payne
