Question about Samsung Televison & Video
La40b650 lcd tv hdmi not working
No signal from t box through hdmi cable
SOURCE: says no signal when switched to hdmi when there is one.
Have the same problem with a 532H - but here is what I did to resolve the issue:
1) Click your Menu button on the TV remote.
2) Go to Screen (click the right button)
3) Go to Main Picture Source (click the right button)
4) Select HDMI (click the Menu button when done)
Posted on Oct 13, 2008
  • 90 Answers
SOURCE: Cannot get a connection with HDMI input
When the tv won't scroll to the HDMI inputs, it means that the tv does not detect a signal on those inputs. This either means the tv has an issue and can't receive an HDMI signal(very unlikely) or there is no signal being sent from the source(converter box) The first thing I would do is unplug all output connections from the box except for the HDMI output and see if this gets rid of your problem. If not, I would be more inclined to think you have a problem with your converter box than with your TV. You could also try using the HDMI ouput of a DVD player if you have one.
Posted on Jan 14, 2009
  • 57 Answers
SOURCE: Insignia TV no audio on non HD channels via HDMI cable.
have you tried to change the audio settings to HDMI on tv? when u have HDMI hookd up u have to change the audio to HDMI also
Posted on May 31, 2009
SOURCE: samsung 610 46'' lcd - hdmi input not working
why hdmi input wont show up
Posted on Dec 22, 2009
  • 10 Answers
SOURCE: Philips LCD TV "47, model PFL 8404H/12, NO SIGNAL on all 4 HDMI
This is quite tricky as it was working until last night and suddenly stopped receiving signals. What can happen wrong?
Do you have any other Player or other HDMI cables to try out. Sometimes the cables would be damaged or PC may fail to detect the HDMI.
Try this out from Philips helpdesk where there is new SW and FAQs are available.
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PFL8404H/12&slg=en&scy=CZ
Let me know if you are not able to upgrade the FW (if you do not get the support on ugprading)
Posted on May 11, 2010
When I switch from one HDMI input to another I get a no signal & spinning LG box. after several minutes it gets a signal
Try a different HDMI cable, then try the other HDMI inputs on the TV, then try to connect another HDMI device to the TV. If all are still bad main board needs replaced
Oct 19, 2014 | LG 55LK530 55 inch 1080p LCD HDTV, with...
Why is tv saying no signal?
Connect a known working DVD player by using a new HDMI cable to HDMI INPUT 1 and check for signal.
If you have a DISH or CABLE system box, connect that also with a new HDMI cable to HDMI input 2 or 3 and recheck for signal. Your T V remote will have an input selector to change between the different inputs on your
T V.
Sep 08, 2014 | Proview HX303 30 in. HD-Ready LCD...
LC-26DA5U 26 in. HDTV-Ready LCD Television: i connect a hdmi cable 2 my hd cable box - the pic...
The cable box needs to be set to send different signals when using hd tv and standard tv. Usually a good setting would be 720p in hd and 480p in standard. The tv is working fine it is the cable box sending the signal. If you have another hdmi source such as a dvd player you may hook that up to show the tv is working just fine.
May 07, 2010 | Sharp LC-26DA5U 26 in. HD-Ready LCD...
"No signal" sign on TV screen using HDMI selector
it sounds like a refresh issue, double check you selector and make sure it fits the refresh of the tv. i had this once with a sharp where the tv was 120hz and the selector was 60 and it created a no signal and when it did come in it was jumpy. if you have a 120 tv then selector should be the same.
Apr 27, 2010 | LG 42LH30 42 in. LCD TV
On a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
Aug 11, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
I cant figure out how to plug in the direct tv cable
Ther is no "cable" connector on this model tv. Check your direct tv control module "cable box" for a hdmi output. If you have that output, you will need ahdmi cable for HD broadcast. If you donot have a hdmi output on your direct tv box, contact direct tv for the right one. Do not use RCA connectors because the picture will be fuzzy do to in-ability for rca connectoe to send HD signal. You MUST have hdmi signal from cablle box to tv.
Good luck.
Mar 07, 2009 | Akai LCT4216 42 in. LCD Television
Jan 14, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No Signal HDMI
Had the problem. Turned out to be a defective hdmi port circuit board.
Aug 04, 2008 | Insignia 42" LCD Flat-Panel HDTV
Televison & Video Logo
49 people viewed this question
Henry  Thomas
Henry Thomas
