Question about Winix PlasmaWave 5000 Air Purifier
Winix will not turn on - Winix PlasmaWave 5000 Air Purifier
I found a key and it has, winix, 5 circles, and a british flag, all ingraved in it. i want to know what the key opens! please answer my question!!!
Apparently they used for Vaultz storage boxes. It seems to be a common item. Here is a photo of a box with the key installed. I will post the link as well. You can make out the word WINIX on the key is you look carefully.
https://s.yimg.com/hd/answers/i/d95612a21fc34b5290ee92ffb5718d0e_A.jpeg?a=answers&mr=0&x=1449781209&s=aaecb71a94c8c70b96084689a3d14bda
Dec 10, 2015 | Winix Air Purifiers
Can you add a prefilter to an oreck truman cell to grab the larger dust particles and decrease the zapping?a humidifier in the room helps but when the furnace is going it can still be often.
it should have a prefilter already on it. they have a screen looking filter that goes on the front of the cell. If you don't have one you need to get one. You should also have a charcoal filter on the back side of the cell, if not then you'll need to get one of those also, the charcoal is for odors and not for filtering dust. Putting any other type of filter in front of the cell will just be turning this into a filter type cleaner and will be defeating the purpose of the reusable Trueman cell. You may as well just buy a different cleaner if you don't mind buying new filters instead of cleaning the cell. I would recommend cleaning the cell every 2 weeks to keep it working properly. This will also keep it from snapping, if yours is snapping it's already too dirty and needs to be cleaned, if it's snapping right after it's cleaned then you have a plate that is arcing in the Trueman Cell, I have posted a fix for the ProSheild Models to stop the cell plates from arcing.
Feb 19, 2015 | Oreck Air Purifiers
What air filter do i buy for a replacement?
http://www.amazon.com/Winix-115115-True-Replacement-Filter/dp/B002QUZJAS
Jun 26, 2014 | Winix PlasmaWave 5000B Air Purifier
Reset engine indicator light
1. With the Car Off, Press and hold down the Odometer Trip Reset Button. 2. While still pressing the Trip Reset Button, Turn the Ignition Key half way on where all your oil, check engine lights etc.. turn on. Don't turn it as far as you would to normally start the car. Wait a few seconds and the Check engine light will turn off. 3. Turn the key back to the Off position and you're done.
(source: Yahoo Answers)
Feb 08, 2014 | aFe 2004 Honda Accord - 3.0L V6 - Air...
Where can I find replacement filter for Kenmore 85500 air cleaner
I just went to the chat site for sears parts and asked them to find one. They ordered part #119010 Filter CATEGORY: Plumbing and Heating
PART NUMBER: 119010
which comes up to this page... http://www.searspartsdirect.com/partsdirect/part-number/119010..... I did order it through them.. I hope this helps anyone else looking for a replacement filter for the Kenmore #85500 with filter #85501.. With the link above you can order it online.
Feb 14, 2013 | Kenmore EnviroSense 85501 Air Purifier
Fan wont turn
I have taken one apart. reassembled and the fan would not turn, although there was power to the motor and it wanted to turn.
Sorry this is long...only this is about taking the motor itself apart..and I have yet to find a replacement motor.
1. Tried a little WD 40...(only on iron motor Housing!) nothing.
2. Took apart inside of motor. some rust inside..
3. carefully rubbed clean with WD 40..
4. leaned off WD 40 with contact cleaner...
5. Then worked little bearing loose on back side.
-Kind of turned upon reassembly..
6. Found some silicone High temp lubricant and took motor inside part again.
7. a very thin coat of lubricant inside rotor.
-Re assembled yet again..began to turn at high speed, kept running..24 hrs..
- It .finally turned at silent mode. and continues to work
This may be ar beyond what you want to do, however if all else fails...what else can you do? buy another one?
Tips:
1. mark rotor holders with housing. (do not reverse.)
2. make sure you remove all lint, dust, etc inside.
3. the rotor bearing I had to work by hand again and again repeatedly syringing a little WD 40 at a time to until it turned easily.
Jun 04, 2012 | Oreck XL Professional Air Purifier
When I'm in my bathroom and showering the light turns red- what does this mean- Mold?. moisture?
The simple answer is moisture. If you have a bathroom exhaust fan, be sure to run it during and after you're showering. Typically, for a bathroom exhaust fan to reduce the moisture properly, it should remain ON for at least 15 minutes after your showering is complete,
Hope this helped to answer your question.
Apr 23, 2011 | Winix PlasmaWave 5000 Air Purifier
I just replaced my filter for the winix 5300 model and the replace filter indicator does not seem to turn off. Are there any solutions or procedures as to how i should go about this matter?
Remove the front cover and locate the FILTER RESET button below the DUST SENSOR level display indicator lights. Press and hold this button for 3 seconds until the unit beeps and the REPLACE FILTER indicator light goes out.
Apr 02, 2011 | Winix PlasmaWave 5000 Air Purifier
I've replaced the filter. why won't the red replace filter light shut off?!
Remove the front cover and locate the FILTER RESET button above the dust sensor level indicator lights. Press and hold this button for 3 seconds until the unit emits a beep and the REPLACE FILTER light goes out.
Sep 03, 2010 | Winix PlasmaWave 5000 Air Purifier
How do I reset the "replace filter" light? I put a new filter in an don't know how to make the red light go out. Thank you
With the unit on - take off the front panel - right under where the "replace filter" light is, there is a button that says "Reset" hold that button in until it beeps - then the light should turn off. Hope this helps :)
Jul 31, 2010 | Winix PlasmaWave 5000 Air Purifier
Winix PlasmaWave  5000 Air Purifier Logo
83 people viewed this question
Top Winix Air Purifiers Experts
Are you a Winix Air Purifier Expert? Answer questions, earn points and help others
