Question about Thermador C302U Electric Double Oven
Thermador C302U double Oven - F24 Displays after running oven
A beeping noice and F24 is displayed on the panel after the oven is turned off. I believe the cooling fan is not running. We just replaced the hinges and gasket on the advice of our repair man but that did not solve the problem.
  • Anonymous Jan 31, 2009
    I can't use my oven and it is beeping and displaying F 24
4 Suggested Answers
  • 5 Answers
SOURCE: thermador c302 door hinges
487746 is the part number for the 30 inch model and
487747 is the part number for the 27 inch model if this is the parts you recieved then the should fit there should not be much difference
Posted on Jan 15, 2009
Macmarkus
  • 2605 Answers
SOURCE: How do I replace the
Welcome to FixYa.
WOW ! An oldie but a goodie. This is when Thermador made the best ovens money could buy, in my opinion.
To replace the roller will require pulling the oven from the wall, likely obvious by now. Since you've indicated you do have the part I'll assume you are confident this is what is worn...these are pretty simple devices with many components is the best way to describe them.
Have a look at this illustration below and see if this will help identify how you may change them and then I can explain what to do without having to describe from afar what goes where and confuse terminology.
I also have a complete folder of your model in a "pdf" if you'd like it. I'd need an email address to send it to though so you'd need to post it here.
I'll watch for your reply and then we can proceed if you need further assistance. Thank you for choosing FixYa and good luck going forward.
Regards,
Macmarkus :)
Posted on Nov 21, 2010
  • 195 Answers
SOURCE: Thermador 30" wall oven.
Your touch in put key is stuck, replace ,power relay board and the touch panel
Always unplug the oven first before service
Posted on Dec 02, 2011
F24 code
In some cases I have had to replace both the touch pad and power relay board. Expensive! HOWEVER, I have, on occasion, found the wide ribbon from the touch pad to the relay board to be at fault. I have not found replacements for these as of yet. I have been able to "open" the ribbon to clean the contacts within and reassemble it to find everything working. Needless to say, my clients have been extremely happy with my ability to do so, saving them thousands if having to replace the entire unit.
I found the bad connection when the lighting was dim and I saw a "flash" at the point ribbon it inserted in the end piece. Hope this helps.
Jan 23, 2014 | Thermador Ovens
My thermador double oven display is note openly connected. How do I fix it?
This board set can also be rebuilt at www.fixyourboard.com. Dim display is a common failure that can be repaired reliably at a fraction of the new board cost. Here are the relevant partnumbers :
35-00-760, 12001691, 492071, 14-38-901, 492069, 492067
1065923121 , 1065923160 , 1065923161 , 1065923200 , 1066025120 , 1066025150 , 1066025151 , 1066025160 , 1066025201 , SCD272T , SCD302T , SCE30500W , SCE30600B , SCE70600B , SCE70600W , SC272T , SC301T , SC302T , SMWS72YP AFTER S/N 8204 , SMW272B , SMW272P , SMW272S , SMW272W , SMW272YB AFTER S/N 8204 , SMW272YS AFTER S/N 8204 , SMW272YW AFTER S/N 8204 , SMW272ZS AFTER S/N 8204 , SM272B , SM272S , SM272W , SM272YB AFTER S/N 8204 , SM272YS AFTER S/N 8204 , SM272YW AFTER S/N 8204 , SM272ZS AFTER S/N 8204 , SVD48600B , SVD48600PF , SVD48600PG , SVD48600PK , SVD48600PR , SVD48600PT , S272T , S301T , S302T
Feb 02, 2012 | Thermador SC302T Electric Double Oven
F-24 goes on after oven on, and oven starts to beep
The F24 fault code is caused by a closed/stuck/shorted contact on the control panel for more than 60 seconds, such has someone leaning against the controls or objects hanging in front of the controls.
Solution: Touch OVEN OFF, or turn power OFF at the circuit breakers, wait 3 minutes and then turn it back on. If the condition persists the touchpad/control panel will likely need to be replaced. Turn the power off in order to stop the beeping.
Feb 28, 2011 | Thermador C302U Electric Double Oven
F24 shows on readout and oven shuts off
Jan 23, 2011 | Thermador SEC272BPSS Electric Double Oven
Thermador smw272 oven does not heat. the op panel
Likely to be the Hi Limit Switch or the relay/power board.
Best Regards,
Bruce
Jun 19, 2010 | Thermador C302U Electric Double Oven
I have a Thermador Model C302ZS
I did too!! My appliance guy told be to but it on the curb - it wasnt worth fixing and we only had it 3 years!!!
Aug 17, 2009 | Thermador C302U Electric Double Oven
Fading digital display on Thermador SC302ZS Double Oven
when the display is fading it has to be changed part number 492071 that is for a double oven display
Feb 19, 2009 | Thermador C302U Electric Double Oven
F-24 error, beeping after use - Thermador C302US
error code f24 oven shuts down while baking if i open the door and beeps continuously
Jan 24, 2009 | Thermador C302U Electric Double Oven
F24 Error code and incessant beeping
Being a software developer I guessed that the keyboard (the touch pad) was bad, because in my case one of the keys (the Top Oven OFF key) did not beep or work. So I went on the Thermador website and found the touchpad on the schematic. I ordered one yesterday from a firm called Mar-Cone in St. Louis, and it arrived today. It is a very easy replacement, and takes about 10 minutes. Happily it was a good guess, and it works fine. For the 27" SEC272BS/01 (stainless) the part # is 474083, and cost $189.20. They will express ship for $25.
Phew, we have 20 people coming for dinner on Thursday.
I'll be happy to let anyone know how to change the panel.
Nov 09, 2008 | Thermador SC272T Electric Double Oven
Thermador Built-in oven model cm301
Same issue w/our Thermador CM301. F23 and F24 codes - BSH acts like they have never heard of the problem! Awful service. This should be reported to the Consumer Board.
Feb 19, 2008 | Thermador SC302T Electric Double Oven
Thermador C302U Electric Double Oven Logo
115 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
