Question about Welding Tools
I need a tri arc 160 welder manual - Welding Tools
SOURCE: miller axcess 40v wire feeder
just checking to see if you got any ideas on this problem
Posted on Oct 27, 2008
  • 583 Answers
SOURCE: no arc
check your fuses
Posted on Aug 19, 2009
harlan301
  • 205 Answers
SOURCE: NO arc or power on my Welder/Generator
check your back panel fuss and brakers
Posted on Oct 11, 2009
  • 7 Answers
SOURCE: trying to find a manual for a Pro Arc 1150B 115
Go to proarcwelding.com . I didn't see a manual available,but they have a contact page. If anyone can get you one ,they should.
Posted on Oct 13, 2009
GiantTechGuy
  • 25 Answers
SOURCE: Looking for manual for my mitech super 160 welder
When you press the torch trigger what sound/sounds do you hear from within the machine?
Posted on Oct 18, 2009
225Bobcat gen.runs but will not excite when trying to strike arc
#Tags bobcat 250 welder service manual
coop.bounceme.net/term/bobcat-250-welder-service-manual
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and ... Won't strike an arc,fuses ok brushes and slip.
Aug 11, 2015 | Electrical Supplies
I just bought a mishto 220amp 3 in 1 welder, didn't come with user manual!@!.. the arc (mma) works fine but can not get the mig working.
I found a forum addressing the welder you mentioned. They are amused, as you will be, by the manual. https://dl.dropboxusercontent.com/u/11148130/MishtoWelder/MIG200.pdf
It is ridiculously useless. Try taking your welder to a high school shop teacher or find a local hobbyist welder -- because welding supply stores hate these Chinese boxes that cut into their sales and will not be helpful.
Sep 12, 2014 | Welding Tools
Need a hook up maual
According to the specs for this welder
You need a 50 amp breaker and #6 wire
Century/Lincoln Inverter Arc 230 DC stick welder.
  • 230 Volt stick welder compatible with optional TIG equipment. Welds 18ga to 5/16. Includes:
  • 10 ft Work cable with small dins connector and clamp,
  • 10 ft Electrode holder with small dins connector,
  • shoulder strap for portability,
  • 6-1/2 ft input cable with attached 50 Amp (NEMA 6-50P) plug
Oct 12, 2012 | Century lincoln K27901 Inverter Arc 230...
Old AC180T welder has a weak arc no weld
Are you using cored wire? Or shieldgas? if the later, you may not be getting any to the gun.
If you are using solid wire without shield gas, you will get what you describe.
In the off chance you are using the correct combinations, you may have a loose connection in the circuit that adding resistance to the circuit and lowering the effective voltage at the tip. Make sure all connections are tight inside of the machine as well as the cables and gun assembly as well.
Mar 30, 2012 | Welding Tools
I have a champion 10000 watt gen welder won't bur
Make sure the switch for remote power or control at machine is on the right setting. It will arc but very faint if this switch is not on the right setting.
Mar 17, 2012 | Hobart Welding Tools
Need wiring diagram for buffalo 110 amp. arc welder
They do not make it available. So a generic wirefeed such as this http://www.northerntool.com/downloads/manuals/628575.pdf will be reasonably close.
Rarely will the circuit board schematic be shown. If however your wire feed circuit stopped, usually it is the SCR's that fail and they can be replaced with comparable units, or even higher voltage and current ratings than the original within reason. http://www.digikey.com is a global vendor.
Jan 25, 2012 | Welding Tools
MY CLARKE WELD 235 TEN TURBO ARC WELDER HAS SUDENLY STARTED BLOWING FUSES WHEN IT ARCS UP ANY IDEA
More then likely you have a shorted component (positive or hot wire to ground). Verify that the gun/trigger assembly is in good shape and has no broken wires that are touching the ground or case (may have to disassemble). Thats the easiest thing to check, everything else is inside the unit and will take more sophisticated knowledge and equipment to diagnose.
Oct 12, 2011 | Clarke Power Products Clarke 130EN...
Have a century 125 gl mig welder 110v and it arc's with out pulling the trigger
Need to ckeck the gun switch trigger the terminals? See if there are grounding out.
Jan 17, 2011 | Miller MATIC 140 MIG WELDING PKG w/cart...
My Lincoln SA 200 welder will not rev up when I strike an arc.
Need code number to be exact, but sounds like the wiring to the current transformer is incorrect.
Sep 17, 2009 | Lincoln Welding Tools
Can't fine a operate-parts manual for a chicago arc 180 welder
I would go ahead and contact someone with <a href="http://www.suburbanweldingandsteel.com">chicago welding</a> they really know will be great.
Apr 09, 2009 | Welding Tools
Welding Tools Logo
64 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
