Question about GE JES1142SJ Microwave Oven
Microwave won't heat, and turntable doesn't turn
I have a GE microwave oven that won't heat, turntable doesn't turn, but the display works and timer counts down. Makes a little click sound when you push start.
  • pelicanpam Jan 23, 2009
    Model # of micro is GE JES1142SJ. After researching I found it could be lower door switch, faulty relay, or triac. Sounds like it's time to get a new one.
  • William Miller
    William Miller May 11, 2010
    Please reply back with your model number so we can help you.
  • GE Master
  • 9,098 Answers
All the parts you mention are very inexpensive, but yours does not have a triac.
It could be the cook relay, but it's more likely to be a switch.
Looking at the schematic, it's probably a bad primary interlock (upper door switch) or maybe its mount is bad.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you have a broken mount, it's usually more economical and safer to just add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
Here are some helpful links:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or elsewhere, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Jan 23, 2009
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: MCM1290A Microwave Oven: the timer counts down but it wont heat or the turn...
Probably a bad door switch. See this file.
Posted on May 06, 2010
GE Microwave JVM1540LM2CS Doesn't Heat
The turntable and the magnetron are two separate items and one should not impact the other. Since the other items are working it is doubtful that the fuse is bad. Also you need to know that the proper way to work on a microwave requires the use of special equipment to check for microwave leakage, it is not recommended to service them yourself.
Jan 22, 2018 | Microwave Ovens
GE microwave not heating, sensor error.
first suspect is the inverter board (power) and magnatron a distant second----in either case the part involved unless an expensive unit is pricey.
Aug 26, 2012 | GE SpaceMaker Microwave Ovens
Microwave turns on but no heat and turntable doesn't turn
It is one of two things, a defective door switch, "most likely" or the keypad control board is faulty.
Apr 22, 2012 | GE Spacemaker JVM1540 Microwave Oven
My GE JVM1540 microwave appears to run but it won't heat. The lights and turntable work but it does not heat at all.
you will have to replace the microwave, sounds like a burned out magnetron, replacing the magnetron is almost as expencive as a new oven...
May 05, 2011 | GE Spacemaker JVM1540 Microwave Oven
My advantium lights, turntable turns, timer works, appears to be working as usual, but does not heat..
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Nov 14, 2010 | GE Advantium 120 Convection/Microwave Oven
Everything works (clock, timer, inside light etc.) but not the fan, turntable and will not heat. It stopped while heating lasagne.
Basic
Microwave Oven Troubleshooting Tips
heatman101
Sep 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE JES1358 Microwave: lights are on but doesn't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
Jun 06, 2010 | GE JES1358 Microwave Oven
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
GE JES1142SJ Microwave Oven Logo
1,624 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
