Question about Nordic Track NordicTrack COMMERCIAL 1750 Treadmill
Nordic track 1750 incline calibration failed
In settings, pressed the calibrate incline button but received the response "the calibration process has failed. Please try again." It's brand new and I have yet to use it.
5 Suggested Answers
  • 218 Answers
SOURCE: The Nordic Track machine's controls seem to be
Remove the console from the treadmill and remove the back
remove and replace the ribbon cables that run from the keypads to the control board (they are flat plastic strips that push into the board).
remove and replace all the connections on the console
reattach the console and calibrate by doing the following:
1. With the key off press the speed + and stop buttons at the same time and hold
2. place the key on and release the buttons
3. press the stop key once
4. press the speed up til it reaches 85
5. if your max speed is 10 mph then it should read about 9.8-10.2
If the keys will not work then the console is bad and would need replaced.
Posted on Aug 11, 2010
SOURCE: Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
Posted on Feb 13, 2011
ercupa190
  • 12223 Answers
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Posted on Nov 17, 2011
ercupa190
  • 12223 Answers
SOURCE: treadmill stuck in -3 incline
Double check that all connections are secure, especially the console cable. Unplug and reconnect the console cable to verify.
Unplug treadmill from wall outlet. Wait 60 seconds, allowing lower board to discharge built-up energy.
Remove motor cover.
Verify that there are no lights lit on the lower circuit board.
Verify that all wires are securely and correctly placed on the lower circuit board, especially the large wire harness on the top of the circuit board with 12 different colored wires coming out of it.
Posted on Dec 09, 2011
Incline not moving
Try to do the following hope it will solve the problem.
if its doesn't solve the problem then the the incline motor or the control panel is faulty.
HOW TO USE THE SETTINGS MODE T
he console features a settings mode that allows you to connect your incline trainer to your own wireless network and to log in to your iFit Live account. The settings mode also allows you to turn on and turn off the display demo mode. You may also be able to select the unit of measurement.
Select the settings mode.
Insert the key into the console . Next, select the start menu. Then, press the i button in the lower right corner of the screen to select the settings mode.
Select the maintenance mode.
Press the Maintenance button in the lower right corner of the screen to enter the maintenance mode.
Calibrate the incline system of the incline trainer.
Press the Calibrate Incline button. The incline trainer will automatically rise to the maximum incline level, lower to the minimum incline level and then return to the starting position. This will recalibrate the incline system. Press the Begin button to calibrate the incline system or the Cancel button to return to the maintenance mode. When the incline system is calibrated, press the Back button. IMPORTANT: Keep pets, feet, and other objects away from the incline trainer while the incline is calibrating. In an emergency, pull the key from the console to stop the incline calibration.
Restore factory defaults.
If necessary, press the Restore Defaults button to reset the firmware to the original factory firmware. This will erase all firmware updates that you have downloaded. Press the Begin button to restore the default firmware or the Cancel button to return to the maintenance mode. When the restoration is complete, the words PLEASE CYCLE POWER will appear in the grey box. Press the power switch into the off position. Wait for several seconds, and then press the power switch into the reset position. It may take a minute for the console to be ready for use.
Exit the maintenance mode.
To exit the maintenance mode, press the Back button repeatedly.
www.electro-medical.blogspot.com
Aug 31, 2015 | Nordic Track NordicTrack X7i Incline...
Incline problem
All icon models are the same. The easiest way to incline calibration is to start the treadmill, push the incline up button and then after you release the button, remove the safety key. Replace the safety key and the treadmill should calibrate.
If that doesn't work, press the stop and speed up buttons and hold, then place the safety key in place. This will bring you to the speed/incline calibration. Press stop again. now press incline up. This will run the incline calibration.
You may need to remove the hood and manually with a drill lower the motor. Using a slot screwdriver bit, lower the motor a bout 50 turns and then try the procedure above again if necessary.
Mar 05, 2014 | Proform Exercise & Fitness
Cybex 750T Treadmill
use the software calibration, and try again.
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step. The Calibration seq
God bless you
May 22, 2013 | Cybex 750T Legacy Commercial Treadmill
Calibrate
see this steps for calibration. and fix it. God bless you
Oct 15, 2012 | Proform 505 CST Treadmill
The programs on my new smooth 9.65 LCi do not work
adjust the REED SWITCH, see the diagram , clean it, tight any plug or connector very well.
Tight the ribbon cable, and clean it with rubber pencil, for keypads display, and tight any connector or plug from display.
after that RUN the software calibration, for diagnostic,troubleshooting, and fix it.
God bless you
Oct 14, 2012 | Exercise & Fitness
E3 error on sole E95 elliptical
The E95 incline motor is out of calibration. Recalibrate the incline by holding the UP INCLINE button and the START button simultaneously for 5 seconds. This will put the machine into incline calibration mode. Press ENTER to start the calibration and let it run. It will take a minute or two.
Refer to page 25 (the last page) of the user manual, hidden right at the bottom.
Sep 20, 2012 | Exercise & Fitness
My tunturi T 20 gets error code E 7. it starts up, and after 5 or 10 seconds, it stops and flashed the error code. I have tried the recommended solution, which is to unplug the treadmill, wait a minute to...
From time to time, error codes will pop up on your treadmill. It just takes a quick second to clear the error log and get the treadmill up and running again.
1.When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
2.Press the "ENTER" button three times to access the treadmill's error log.
3.Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
4.To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
5.To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
I hope you find it very helpful.
Sep 04, 2011 | Exercise & Fitness
Kettler atlantis 51L error!!!! what is the solutions?
I will advice you try re-calibrate your treadmill, follow the procedure below to re-calibrate it,
Step 1 Stand on the side rails of the treadmill for safety purposes. Remove the safety key. Step 2 Press and hold the two incline buttons. The incline buttons are blue and on the left side of the display. Hold the up and down button simultaneously. Release the buttons when the display reads "Calibration."
Step 3 Press the green start button located either above or below the large, red stop button (depending on your model). Stay on the side rails as the treadmill belt begins to move. Both the speed and incline should go through their full range from lowest to highest, and then back down again.
Step 4 Repeat the process if the display does not read "Calibration Successful." Contact the business where you purchased your treadmill if repeating the calibration process does not result in a successful calibration.
Aug 17, 2011 | Exercise & Fitness
I hae a Pro Form 540 Iteracive Trainer treadmill. When the key is inserted, the treadmill cuts on but the control panel doesn't seem to work when you touch start. I waited and cut it off and went...
Aug 08, 2011 | Sport & Outdoor - Others
While using iFit, my daughter accidently removed the magnet and my trademill is stuck to incline 5, there is no reset button so the whole console is not responding. Please help! or could you find me a...
You should try to do an incline calibration.
Use this process.
Hold the stop and speed up buttons simultaniously, while inserting the safety key. This will put you in diagnostics. Then press the stop button one time. Then press the incline up button. This should start a calibration. Wait until the unit completes the calibration. (goes all the way back to the bottom) Remove the safety key and reinsert it. It should be operational at this point.
Good Luck! Tim
Mar 24, 2010 | NordicTrack Exercise & Fitness
Nordic Track NordicTrack COMMERCIAL 1750 Treadmill Logo
765 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
