Question about Maytag MSD2756G Side by Side Refrigerator
Maytag model mff2055 freezer fan noise - Maytag MSD2756G Side by Side Refrigerator
2 Suggested Answers
kachbibi1
  • 979 Answers
SOURCE: the fan motor makes a noise when it's running. I'ts 7 yrs old.
The noise could be the blade is coming loose on the shaft. It would need to be tightened. Or it could be it is striking the frame.
Posted on Feb 23, 2013
The freezer stopped working (the fridge is working but not as cold as it should be), I cleaned all the vents and the freezer worked again fro a short time then I heard a noise like possibly the fan...
It does sound like a bad fan motor. With the compressor getting hot you may need to change the start relay, overload and run capacitor if it continues to run like this with a defective fan motor. What is the correct model number? Sea Breeze
The condenser fan motor for a model MZD2766GES is part number=> 61005323 Condenser Fan Motor or here=> 61005323 Condenser Fan Motor
Oct 18, 2013 | Maytag MZD2766GES Side by Side...
The fan motor makes a noise when it's running. I'ts 7 yrs old.
Feb 21, 2013 | Maytag Freezers
Maytag Refrigerator, Vibrating Noise
What is a short time? 5 or 6 secondswould be icemaker fill valve.Tubing in back is a common noise maker ,could be somthing hitting the condenser fan blade.
Nov 27, 2012 | Maytag MSD2434GE Side by Side Refrigerator
I have an Admiral top=freezer refrigerator model LTF2112AR. Suddenly, this evening, the motor in the back of the freezer began making continuous noises, it sounds like a grinding noise, but it is still...
Is the compressor making the noise or is it the fan motor that is making the noise. If the compressor then you are looking at over $500 for replacement and you will have to decide if your refrigerator is worth that type of investment.
But if it is the fan motor, then you could replace it yourself. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170333 Item 11 is the fan motor and you could replace it. The compresson is item 1 and would require a trained person to replace it.
Jun 16, 2011 | Maytag Admiral Top-Freezer Refrigerator
Noise coming from fan in the freezer like it is hitting something
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Feb 14, 2011 | Maytag MBB1956GES Bottom Freezer...
My Maytag MFD2560HES bottom fridge is making a loud humming noise.
Any time there is the sound of humming it is important to locate where the noise is coming from. Sometimes fans wear to a point that at one speed the sound as if humming. Sometimes compressors hum with more catastrophic results. Because your model is a bottom freezer it would be a good idea to open drawer to freezer and see if the sound is from fan in freezer or if pulled away from wall is the sound the fan or compressor area? I believe I will be able to locate a service manual but I will need you to help me pinpoint the location of the loud sound so we can get the sounds back to normal. Let me know if you are able to try that and what you find, Sea Breeze
Mar 23, 2010 | Maytag MFD2560HES Bottom Freezer French...
My upright freezer is making a loud screaching noise something like a car's slipping fan belt makes in winter. It is still freezing but sounds like something is on the way out.
If you have the model number you posted under, you are looking at replacing the evaporator fan motor, which would be a part number 4309014 for that Maytag MQU1556A. It is located inside the freezer, behind the lower back wall.
Jun 22, 2009 | Maytag 15 cu. ft. / 425 liter Upright...
Maytag refrigerator clicking noise and stopped working
either inside fan out of alignment or defrost timer could be bad
Jun 02, 2009 | Maytag MSD2756G Side by Side Refrigerator
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
5 year old Maytag Wide by Side Refrigerator side not cooling
Same issue with my 6 yr old Maytag side-by-side model #MSD2756GEW. Turned out it was caused by a faulty circuit board. This circuit board is located in the upper right fridge section. Apparently these boards are sensitive to power surges (which we have here in central Texas from time to time.) When the circuit board is fried, it makes a noise like a fan blade malfunctioning and it stops the auto defrost feature in the freezer from working. So the freezer ices up at the back, and the ice prevents the cold air from reaching the fridge section.
Our circuit board (which we thought was a fan) made ominous noises for a few months. (The noise would last only a minute or so and stop shortly after we opened a door). Eventually we noticed that the fridge wasn't as cold and the freezer had snow in it. Finally the board stopped making noise and about a week or so afterward we noticed that the milk had spoiled and the fridge wasn't very cold. The food in the freezer side pretty solidly frozen, thankfully.
In addition to replacing the circuit board, the fridge had to be de-iced or it would not work properly. I put it all frozen into a large camping cooler where it stayed for several hours. I opened the freezer doors and put table fan and pointed a hobby light which gets quite hot, at the back of the freezer. Within 3 hours, the ice had melted significantly so I could see through the grate at the back of the freezer. This really great technician named Tracy, made a special trip to the parts store to get the circuit board and came back within a couple hours, bringing with him a steamer. He removed the back panel inside the freezer section (the coils are behind there) and used the steamer to melt the rest of the ice before he left.
Tracey, who works for a local appliance repair company, told me that about 4 years ago, Maytag started making their fridges with built-in surge protection, so the circuit boards apparently don't get fried on the newer models as they do on my 6 yr old model. He recommended that we put plug the fridge into a heavy-duty surge protector - which we are definitely going to do.
TR
Feb 13, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag MSD2756G Side by Side Refrigerator Logo
47 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
