Question about Microsoft Windows Vista Ultimate Edition
How to stack windows - Microsoft Windows Vista Ultimate Edition
  • andrew911 May 11, 2010
    What do you meanby stacking
I don't have product key
Posted on Feb 11, 2009
  • Mr_MaDO__x5 Feb 11, 2009
    i don't have the product key
  • 4 Answers
If you are talking about cascading the open windows, you can right click the task bar (where there aren't any programs), and select Cascade Windows.
How to solve stack overflow line 207?
every time coming stack overflow at lin207
Feb 07, 2014 | Microsoft Windows XP Professional
Stack line overflow at line 42
Stack overflow is an internal command that tells a program or data to link up with other code. The software developer who wrote the software program was directing the flow, like traffic on the highway; and somehow the path did not make a proper move in one direction or the other. This linkage is common to an Operating System. Windows 8.1 for example has a better flow than the previous Windows versions.
Dec 21, 2013 | Microsoft Windows Vista Home Premium with...
In minecarft what does this mean: hs_err_pid#
This error could be related to two things, a corrupt java installation or an issue with the graphics driver.
Try first to reinstall the java engine first, if that fails try to reinstall the graphics driver.
Chances are it is a Java issue.
Good luck.
Jan 22, 2013 | Microsoft Corporation Xbox 360 Live...
"Stack overflow at line 0"
b> A stack is a section of memory where a program stores its variables, calculations, option states and program parameters. When started, a program is allocated some memory to use for the stack; a stack overflow happens when a program exceeds its allocation. The offending program may attempt to write into adjacent memory sections, causing conflicts with other programs. Stack overflows are common with Java, C++, Perl and other runtime environments, which assist in running programs. A stack overflow at line 0 indicates that the offending program tripped up from the start; however, stack overflows can occur on any line number.
Click "Start," "Control Panel, then "Internet Options." Click on the "Advanced" tab. Check "Disable Script Debugging (IE)" and "Disable Script Debugging (Other)" under the "Browsing" options. Uncheck "Display a notification about every script error." Check "Enable Automatic Crash recovery." Click "OK." Download and install a Java update from the Java website. http://www.java.com/en/download/manual.jsp Download and install a Windows update. Hope this helps.
Dec 24, 2012 | Microsoft Windows XP Professional
Unable to start bluetooth stack service
Computer services are found under computer management:
Click start, right click computer and click manage. At the bottom of the computer management window click services and applications, in the main window double click services. Look down the list for your bluetooth service, right cllick and cllick properties. Look for startup type, click the dropdown menu and choose automatic and then cllick start, just below. Click apply and then ok to close window. Restart the machine and see if issue is resolved.
Mar 18, 2012 | Computers & Internet
MY BT-03I Connect Successfully to my laptop but laptop can't detect that as a headset/speaker so i can't hear any thing with it !!! please help me
If you are running Windows XP, you will need to load on a "Bluetooth Stack" for Audio Profile support. These are not free, unless they are bundled with your laptop of the Bluetooth add-on card.
The built in Windows XP Bluetooth support is minimal and based on data transfer only.
Bluetooth stack providers include Widcomm and BlueSoleil. The Laptop Vendor or add-in card provider need to provide the stack.
See: http://en.wikipedia.org/wiki/Bluetooth_stack
Apr 23, 2011 | Genius BT-03i Bluetooth Headset
Stack overflow at line 598
Stacks are reserved memory that programs use to process hardware events. A stack overflow occurs when there is not enough space in memory to run the hardware interrupt routines. To resolve these behaviors, you can modify the "STACKS=" line in the Config.sys file, eliminate terminate-and-stay-resident program (TSRs), and eliminate hardware conflicts.
When Windows delivers an error message that is related to an internal stack overflow, there is not enough space in memory either set aside or available to handle the calls that are made to the computer hardware. There are several things to consider when you troubleshoot this behavior:
  1. The Config.sys startup file may not be properly configured for the Windows installation. Use the following values: STACKS=64,512 ;(this is the maximum allowed)
    FILES=60
    BUFFERS=40 If you are using the dual-boot capabilities in Windows, the Config.sys and Autoexec.bat files may not contain the correct configuration to run Windows. When you are dual-booting between Windows 3.x and Windows, these files may not have been renamed back to Config.dos and Autoexec.dos.
    Examine the Config.sys file to determine if files such as Himem.sys or Emm386.exe are loaded from a folder other than the Windows folder. If so, boot Windows by using the Safe Mode Command Prompt Only option. Rename the Config.sys file to Config.dos and the Autoexec.bat file to Autoexec.dos, and then restart your computer.
  2. Some TSRs may be interfering with Windows. Disable any non-boot device drivers in the Config.sys and Autoexec.bat files. If you install from Windows 3.x and you receive a stack overflow error message, check the Win.ini and System.ini files for non-Windows-based programs or drivers that are loading.
  3. There may be an incompatible hardware configuration. Check the port and IRQ settings of the network adapter, sound card, and modem. Make sure that there are no COM2/COM4 or COM1/COM3 conflicts and that no devices are sharing IRQs. Disable or remove conflicting devices.
  4. The computer may need a BIOS upgrade. Check the BIOS version and contact the manufacturer of your computer for information about a BIOS upgrade.
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 28, 2010 | Microsoft Computers & Internet
Lost bluetooth adapter when formatting my laptop
You will need to reinstall the Toshiba Bluetooth stack.
http://download.cnet.com/Bluetooth-Stack-for-Windows-by-Toshiba/3000-2112_4-95448.html
Be sure to get the proper stack for your operating system
May 27, 2010 | Toshiba (PA3370U-1BTM) Bluetooth...
Satellite a135-s4527 windows xp bt stack expiring
u can find here what u want
http://aps2.toshiba-tro.de/bluetooth/?page=download
Aug 07, 2009 | Toshiba Satellite A100-S8111TD Notebook
Suffering with BO:STACK virus
Trojan Hunter, Avast, BitDefender, Ad Aware, F-prot AV
All Free or at least Full Trails
Dec 11, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
43 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
