I want to replace speakers on my Aiwa NSX-AVH80 system that still works! Will I be able too? and what make/kind is best for such an older systems.
Speakers are SX-NAVH80--Front SX-C400-- Center SX-R230- Surround Sound-two The center speaker is already is not working and the front ones are just plain ugly and too big. I can continue using the Surround Sounds if need be. I have shopped around but the salesmen are not too helpful. They never seem to tell me if it is possible they always show me their top of the line surround sound systems which of course I cannot afford. Will there be a problem with the connections/hookups. Is it better to just replace the whole unit when I get enough money. If so what do you recommend lower/middle range cost. Thank you Norene
techman
  • 3130 Answers
SOURCE: no surround sound
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Posted on Jun 04, 2006
  • 6 Answers
SOURCE: Surround Sound Center Speaker/Sound Card issue
You need to use a digital interface cable between the sound card and the speakers to get all of the 6 channels to work properly.
Posted on Sep 24, 2006
dsom
  • 56 Answers
SOURCE: AV-DV75 center speaker works surround speakers do not
If all others had been fine before this problem arose, and you are sure that you haven't changed anything in your amplifier's channel selection menus, the problem might be deeper to solve! Try these out; 1-If the amplifier has a test menu to check out all channels plugged in, activate it. You must be able to get sound, which is like rustle, from each speaker. 2- Check your plugs, cables etc. be sure that there isn't any short circuit 3- Grab your amplifier's remote control and find the "channel selection menu" that allows you to increase and decrease volume levels for each speaker independently.
Posted on Apr 15, 2007
simplemitch
  • 752 Answers
SOURCE: No sound from stereo
If you can hear a hiss then the spkrs and amp are OK. It sounds like you're not on whichever source you're wanting to hear or it is on mute. Make sure ther is no function enabled that turns the sound off or over-rides it (like a tape monitor or AUX in...).
Posted on Sep 22, 2007
djdizzys
  • 22 Answers
SOURCE: Just a question on specs for Aiwa NSX-5200 system
Hello I have had a look on the internet and found this for you it should let you download the user manual for free, good luck you should find out your specs
www.devicemanuals.com/company/AIWA-manuals-page9.html - 49k -
djdizzys
Posted on Feb 20, 2008
Looking for manual for aiwa -avh80 plus other parts
http://www.eserviceinfo.com/index.php?what=search2&searchstring=aiwa+xr-avh80+audio+system ........ check that out /
Jan 24, 2015 | Aiwa Audio Players & Recorders
Sx-nd22 speaker to be connected whihc one is positive and which wire is negative
http://www.retrevo.com/support/Aiwa-NSX-D22-manual/id/1076dj393/t/2/
Page 4:
1 Connect the front speakers.
Connect the right front speaker to the SPEAKERS R terminals and place it on the right side of the unit. Connect the left to the SPEAKERS L terminals and place it on the left side.The speaker cords with the white stripes go to the + terminals.
Jan 15, 2011 | Aiwa NSX-A777 Shelf System
Hello. A dog chewed the falt cable that connects the RX-NAVH80 to the FD-NH80. Is there a replacement cable available anywhere? If so, do you know what the cost might be> Thanks. Russ RussRossRR@aol.com
The company, Aiwa, is defunct. Parts & support, therefore, are zip. I used Gorilla tape to bind the cable ends together. It works as long as there is no movement to the cable. Best solution: time to shop for a new stereo.
Dec 02, 2009 | Aiwa NSX-AVH80 System
Aiwa nsx v900
did you check on speaker wires? Red is +Positive, Black is -Negatives....
Jul 12, 2009 | Aiwa NSX-DS55 CD Shelf System
Need a replacement belt for Aiwa NSX-A777
CONTACT ANDREWS ELECTRONICS AT WWW.ANDREWSELECTRONICS.COM, THEN CALL THE CUSTOMER SERVICE LINE THEN TELL THEM WHAT YOU NEED.
Feb 24, 2009 | Aiwa NSX-A777 Shelf System
Accidentally my aiwa 3 cd changer fall down and damaged
Same model is not in stock however new models in Aiwa and Sony are very nice in music.
Jan 25, 2009 | Aiwa NSX-DS55 CD Shelf System
My Remote Control Unit for my Aiwa Digital Audio System CX-NA707
It would be a lot quicker (and could be cheaper) to spring for a universal remote.
Mar 17, 2008 | Aiwa NSX-AVH80 System
43 people viewed this question
 Grubhead
Grubhead
