Question about Panasonic CQ-C8803U CD Player
Speaker makes a popping sound when car starts
Installed a new deck couple days ago ( panasonic cq-8803u) and when i start my car my speakers make a loud pop. then thats it. If i play a cd in my deck all my speakers work great. No problems at all. But when i play the radio i only get bad quality sound out of one speaker. My speakers should be wired correctly since the cd's play nice. I'm not sure wat the problem could be coming from. Antenna connection is good. could there be a short somewhere since i get the popping? actually the pop happens as soon as the head unit is powered up. Any ideas?
May be the antenna jack such is connected in cassete is n't good
Posted on Jul 09, 2007
I am having problems with my speakers in n my vehicle. Can you make any suggestions?
Sounds like u may have a loose or poorly connected speaker wire.. some times installers use electrical tape witch can come off or cause issues..I would check all speakers independently withe the balance and fade options on the deck, then find the ones affected and then check wiring to them , if all wiring connections are good, then u may have blown a speaker.. if you had brand new speakers install you could have blown the voice coil by amplifying the volume too loud too fast...
Most speakers have a Break-in Point.. meaning not to put speakers at max volume for the first few days..
Jun 27, 2016 | 2004 Hyundai XG350
I have a Panasonic CQ-DF601U ... I hooked it up but get no sound from speakers. Also the side of it gets really hot. Is that normal for the heat sync side.
It may be getting hot because the amp is shorted out. If you have a bad speaker or one that is grounded, you won't have any sound. Disconnect all the speakers and connect them back one at a time. If the first one doesn't work, disconnect and start with a different one. If none of them work is is in the stereo. If any work, i would check the ones that didn't to see if they are bad or grounded out.
Please Rate!
Apr 28, 2011 | Panasonic CQ-DF601U CD Player
Volume won't turn upon my panasonic cq-vad7200u car stereo
this may be a pre amp only deck
and if it is ou have to buy amplifiers to make the speakers work
May 07, 2009 | Panasonic CQ-VAD7200U Car DVD Player
I had my subs installed a month ago and a few days ago the subs are working,everythings connected but not working and my subs aren't blown out because i don't have my music that loud so whats the problem?
what model kenwood speakers do you have? what head unit do you have? do you know how they hooked up the rca cables to the back of the deck? if this deck has got 3 pre outs you may have lost the sub pre-out. are you amp lights coming on? if you are still having problems you can take a 9v drill battery or bigger and touch the wires from the speaker to the battery, make sure positive to positive and neg. to neg. the speakers should pop if they are ok, that should re-assure you on the speakers. let me know and ill help where i can. good luck
Feb 27, 2009 | Kenwood Car Audio & Video
Scooter stereo
Hi again,
My apologies, missed the connection. Now I remember, must be really getting old.
Back to your concern, which fuse pls? the 15 amps for the Panasonic or the amp"s fuse.
Incidentally, even if the speaker wires were wired incorrectly, that would not cause the fuse to blow. The only way the fuse would blow is if the unit was connected with the polarity reversed, even just once. Internally, most units have a reverse protection diode and/or regulator that would short circuit itself. Thereafter even if it were wired correctly to the battery, the fuse will always blow.
Looking forward to hearing from you.
Aug 05, 2008 | Panasonic CQ-C8100U CD Player
No sound...
you have wires grounding out at the back of the unit. i suggest trying to completely rewire it and see how that works. its easy if youve never done an install so dont sweat it. email me if you have any questions.
wellgood04@yahoo.com
May 13, 2008 | Panasonic CQ-C7301U CD Player
Panasonic CQ-DF903U CD Player
When you unhooked your deck it still had power going to it, you need to unplug your car battery and plug it back in that should reset the deck and get the error message to go away.
Good luck,
Chris
Feb 27, 2008 | Panasonic CQ-DF903U CD Player
Problems with cd player
Need to Know what shuts off. Power or audio just Shuts off.
If Power is cutting off try disconnecting all speakers see if it stays on. If it does connect 1 speaker at a time if you hear a pop when connecting any of the speakers or when fist turning on you probably have on side of speakers grounded (common ground) this radio is not designed to have any speaker be grounded since each speaker wire is at a 6v potential. Do all speakers produce proper sound when stereo is working if not whatever speaker isnt may be defectve. Just a couple of many possibilities. kstahl65@att.net
Jan 12, 2008 | Panasonic CQ-HX2083U CD Player
No sound from CQ-1305U car CD/stereo
You may have one of this two problems:
One of the speaker wires is grounded to the chassis.
Or your car may have a factory amplifier between the radio and the speakers.
My suggestion is to rewire the speakers lines
Dec 25, 2007 | Panasonic CQ-DP383U CD Player
MY panasonic CQ-C9700u starts to skip sound threw the speakers when i put it over 25 on the volume but the bass box still goes until 40?
Hi Lando,
Your Sub box gets its signal from the PReamp output. This means your problem stems from the CQ-C9700U amplifier section. You may need service from Panasonic on this one, or a new Head unit. I cannot think of any adjustment that you can do to eliminate a skip sound.
Dec 02, 2007 | Panasonic CQ-C9700U CD Player
Panasonic CQ-C8803U CD Player Logo
307 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
