Question about DISH Network Vip 222k Hdtv Satellite Receiver Make Offer 2
Error 019 It says their is a problem with the smart card but I don't even have one in the smart card slot
New camera, Canon PowerShot A2300, I have not used it, yet. Just placed the new battery in after I charged it, and I put in the San Disk 8GB SDHC Card, and the camera says "memory card error". I ca
Normally, you can only insert an SD card one way. Try a different SD card or check to see if the SD card you're using has the "write protect" switch on. If that's not the issue try formatting the card in your PC and then format it in the camera.
Mar 05, 2013 | Canon PowerShot A2300 16 Megapixel Digital...
Tip
Micro SD card
Don't bother with anything over 2GB even with prices dropping for media cards. Maximum capacity is 2GB. Be sure to format as Fat16 also. Even with the size "limitation" this will record an immense amount of values as the result files are relatively small.
on Sep 21, 2013 | Columbus V-990 GPS Data Logger microSD...
All telephony functions, including emergeny call are disable due toa communicatio eror
Basically the solution is to claim the warranty and Nokia replaces a new one for you, what if you are out of warranty, just someone like me? Nokia has no answer for that, thank you Nokia ;)
I was thinking "Sim card icon and communication error", maybe it is sim card slot issue? I don't know, but here's what I try -
0. Switch off N9001. Open up N900 case at the back(battery part)2. Take out battery3. Take out sim card from the slot, clean it4. Put the sim card back to the slot5. Tighten the slot6. Take the toilet paper, yes I say toilet paper because it was on my desk when I was trying to fix this7. Try to tear the toilet paper and make it thicker by layering them8. Make the toilet paper slightly same size(square) as the sim card slot9. Put the toilet paper on top of the sim card slot and push in a bit10. Put back your battery and press it little hard, the toilet paper will be underneath11. Close the case12. Switch on your phone
The phone works automagically, don't ask me why, it's really high tech fix if you ever encounter this issue.
Jan 03, 2012 | Nokia N900 Smartphone
Card locked
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here. If these don't help, and you do end up having to format your card, see the recovery software, along with the corrupted card procedures in this blog article.
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
I cannot take picture because memory card error
The IXUS V2 (Powershot S200) uses a compact flash card. Remove the card and look in its slot. I suspect that you have a bent pin in there. If so, don't fret as there's a good chance that you can fix this yourself, IF you have some patience. See this article and do it very slowly and methodically.
Aug 01, 2011 | Canon IXUS V2 Digital Camera
Does Dish Network VIP722K have a removable smart card
They have smart card slots, but don't use them for standard satellite usage.
Jul 06, 2011 | DISH Network ViP722 DTV Receiver /...
Can I use 8MB VGA card in place of 32 MB AGP card
Assuming that the slots are the same (otherwise there will be a diference at AGP version) you can change this VGA, but you will get lower quality image (especially on videos). I don't know details for these VGA cards (brand / model) so I can't give you more details.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jun 23, 2011 | Computers & Internet
Samsung Mobile Phone;Model SGH-i200 will not retrieve incoming mms photos and will not send photos attached to sms (says I need to set up profile??) Thanks
It's one of two things. 1: the programing in your phone might be messed up, so you may have to take it into your provider store. Odds are though there won't be anyone smart enough to do anything about it (even though they do have the capabilities), so you might have to send it to the manufacturer. 2: Most likely your provider has blocked your internet service. Most smart phones can't send or receive MMS's if the subscriber decides to cancel there internet services. I think it's just a way to get you to pay for something you don't want. Non smart phones (that don't even have internet capabilities) are able to send and receive MMS's without having to pay for internet service at all, unfortunately most phones now are smart phone based even if they're not called as such. You don't have to get a plan for internet service, but you will end up paying for each kb you use to send and receive each MMS. If you do send and receive a lot of them you might actually be better of getting an internet plan. Ether way it sucks that we have to pay twice. I mean if we pay to send why does the other person have to pay to receive? Isn't it already payed for? Even when it's physical we don't pay to receive a package as well.
Mar 31, 2011 | Cell Phones
DISH Network Vip 222k Hdtv Satellite Receiver Make Offer 2 Logo
89 people viewed this question
Top DISH Network Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a DISH Network Audio Player and Recorder Expert? Answer questions, earn points and help others
