Question about Radio Communications
HT1A515HS/7- bluetooth headset
What brand is this
Connecting pc to bluetooth headset
Make sure your computer's Bluetooth chip supports the Headset or Handsfree Bluetooth profile (if your computer has a data-only Bluetooth profile, you cannot pair your headset to it). Place your headset into pairing mode. On your computer, click Start, and then click Devices and Printers.
Bluetooth Headsets: How to Pair to a Windows 7 Computer - Support ...
https://www.plantronics.com/us/support/kb/detail.jsp?vfurl=/articles/en_US/...c... https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Connecting+pc+to+bluetooth+headset
Dec 05, 2016 | Radio Communications
Windows 7 bluetooth driver drivers
As you do not mentioned the device on what you want to install.
so i can say you can check out following link:
http://drivers.downloadatoz.com/download/14174,bluetooth-peripheral-device-driver.html
Dec 18, 2013 | Samsung HM1100 Bluetooth Headset
How I can get a Nokia BH-503 driver cd?
How to connect bluetooth headset Nokia BH-503 with Windows 7
I try to use bluetooth headset with my laptop(Dell Latitude E6500) but I can't find device Nokia BH-503 in my bluetooth searching windows.
Many people found this problem. How to fix it? I think this problem is human error or device manual not cover,how to use device with computer and laptop.
if you want to find your bluetooth devices when you search bluetooth devices from your computer.
- Turn off bluetooth headset.
- Start add bluetooth devices function from your computer for search bluetooth devices.
- Hold call button on Nokia BH-503 untill the light blue and red blink (not only light bule blink).
- You will see Nokia Bluetooth BH-503 in your searching window.
- select Nokia BH-503 device and click "Next" for connect the device
- wait for windows find and install driver.If can't found driver let to check it in this web -->>>http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
Nov 15, 2011 | Nokia BH-503 Bluetooth Headset
How to set up to iphone
First open the blueooth setting on the iphone
start the bluetooth service(turn on) on the iphone.
Power on the bluetooth headset.
search devices in iphone, wait till it finishes searching, until you see the name of your bluetooth headset.
the headset would blink two or three time(could be more depending on the brand)
then at the iphone screen a pop out will come asking for the passcode or passkey.
The passkey default would be always 0000 or 00000, you should see your product manual or documentation of your specific bluetooth headset if you are not sure on the passcode.
If connection is a success. the headset would blink and the iphone woould veify and lists it to itself.
Now you have a working bluetooth headset.
Jun 27, 2010 | Cardo S-800 Bluetooth Headset Wireless...
My Bluetooth V2.0 with not pair or scan intp my ps3
PS3 supports Bluetooth V2.0, in fact the Playstation branded headset is V2.1. All versions of Bluetooth are backwards compatible. Are you sure that the headset is going into proper pairing mode?
See these tips:
Pairing mode:
http://www.fixya.com/support/r5009033-put_most_bluetooth_headsets_into_pairing
Pairing to PS3:
http://www.fixya.com/support/r5009279-pairing_headset_playstation_3_ps3
May 06, 2010 | Motorola Mobility Bluetooth Hands Free...
Mad Catz PS3 Bluetooth® Headset Wireless Headset can not hear
I was able to use myBluetooth Headset on Windows 7 by installing the drivers found in this link: http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
Good luck! It took me about a week to find the solution.
Apr 27, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
How to pair with iphone
Hello
1.From the main home screen of the iphone open "SETTINGS".
2.From the setting menu go to "GENERAL".
3.From General go to "BLUETOOTH".
4.In the Bluetooth menu you will see an on/off switch. Make sure you turn the switch to "ON".
5.From here you want to go to your bluetooth headset. Hold the on button for about 5-10 seconds until the light starts blinking. Once light is blinking go back to iphone.
6.In the Bluetooth menu (same as step 4) your iphone should have discovered your bluetooth headset. However if it is not paired yet. Open the headset menu.
7.In the headset menu you are required to enter the appropriate PIN number (which should be given inside your bluetooth headset instruction manual).
8.After you have entered the correct PIN number press connect.
9.From here your Bluetooth Headset should be connected and ready to use.
NOTE:Fully charge your bluetooth headset before syncing it to your iphone
Goodluck
Apr 16, 2010 | Samsung WEP410 Bluetooth Headset Wireless...
I am unable to pair my motorola blue tooth with my LG Wine
You must enter the default Bluetooth pairing code, on your phone, when prompted. The code is 0000 (four zeros).
For your reference, the brand of a Bluetooth device has nothing to do with compatibility. Bluetooth Corporation licenses its technology to many other companies. Devices using Bluetooth technology must conform to the Bluetooth standards. So, a Motorola Bluetooth device will definitely pair with your LG phone, or any other brand of phone supporting Bluetooth device communication.
Jan 25, 2010 | OEM Systems Bluetooth Headsets - Model...
Activating the buetooth function.
You have to "pair" your bluetooth device with your phone. This is just a fancy way of saying "sync" with each other. Check your bluetooth headset instructions on how to do this.
I am using a Motorola H700 Bluetooth Headset. To "pair" it with my phone I have to hold down the call button on the actual bluetooth headset itself while the headset is turned off. This puts the headset in "pairing" mode so its ready to detect any phone that wants to sync with it.
Then I have to go to my actual LG CU400 and enable bluetooth settings. Next, go to "Device List" settings and select "new". The phone will scan for the headset. Once the phone detects the headset it will request a numercial passcode. Your bluetooth headset instructions should list this passcode. Enter the passcode and the phone and headset are now connected! I hope this helps. Good Luck!
Jan 05, 2009 | LG CU400 Cellular Phone
Pairing my bluetooth to my phone
The Passkey for any bluetooth is 0000 so if you put that in it should work.
Dec 24, 2007 | GE Bluetooth In-ear Headset Wireless...
Radio Communications Logo
112 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
