Question about Radio Communications
HT1A515HS/7- bluetooth headset - Radio Communications
Connecting pc to bluetooth headset
Make sure your computer's Bluetooth chip supports the Headset or Handsfree Bluetooth profile (if your computer has a data-only Bluetooth profile, you cannot pair your headset to it). Place your headset into pairing mode. On your computer, click Start, and then click Devices and Printers.
Bluetooth Headsets: How to Pair to a Windows 7 Computer - Support ...
https://www.plantronics.com/us/support/kb/detail.jsp?vfurl=/articles/en_US/...c... https://www.google.co.uk/webhp?sourceid=chrome-instant&rlz=1C1CHBD_en-GBGB719GB719&ion=1&espv=2&ie=UTF-8#q=Connecting+pc+to+bluetooth+headset
Dec 05, 2016 | Radio Communications
How to pair bluetooth with nexus 7
Hi on the bose website it says- No, the Bluetooth mobile phone connectivity is for communications only. so using it on tablets and such would not be compatible. Thanks
Feb 01, 2014 | Bose A20 Headset with Bluetooth - Airbus...
Windows 7 bluetooth driver drivers
As you do not mentioned the device on what you want to install.
so i can say you can check out following link:
http://drivers.downloadatoz.com/download/14174,bluetooth-peripheral-device-driver.html
Dec 18, 2013 | Samsung HM1100 Bluetooth Headset
How I can get a Nokia BH-503 driver cd?
How to connect bluetooth headset Nokia BH-503 with Windows 7
I try to use bluetooth headset with my laptop(Dell Latitude E6500) but I can't find device Nokia BH-503 in my bluetooth searching windows.
Many people found this problem. How to fix it? I think this problem is human error or device manual not cover,how to use device with computer and laptop.
if you want to find your bluetooth devices when you search bluetooth devices from your computer.
- Turn off bluetooth headset.
- Start add bluetooth devices function from your computer for search bluetooth devices.
- Hold call button on Nokia BH-503 untill the light blue and red blink (not only light bule blink).
- You will see Nokia Bluetooth BH-503 in your searching window.
- select Nokia BH-503 device and click "Next" for connect the device
- wait for windows find and install driver.If can't found driver let to check it in this web -->>>http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
Nov 15, 2011 | Nokia BH-503 Bluetooth Headset
Mad Catz PS3 Bluetooth® Headset Wireless Headset can not hear
I was able to use myBluetooth Headset on Windows 7 by installing the drivers found in this link: http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
Good luck! It took me about a week to find the solution.
Apr 27, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
How to pair with iphone
Hello
1.From the main home screen of the iphone open "SETTINGS".
2.From the setting menu go to "GENERAL".
3.From General go to "BLUETOOTH".
4.In the Bluetooth menu you will see an on/off switch. Make sure you turn the switch to "ON".
5.From here you want to go to your bluetooth headset. Hold the on button for about 5-10 seconds until the light starts blinking. Once light is blinking go back to iphone.
6.In the Bluetooth menu (same as step 4) your iphone should have discovered your bluetooth headset. However if it is not paired yet. Open the headset menu.
7.In the headset menu you are required to enter the appropriate PIN number (which should be given inside your bluetooth headset instruction manual).
8.After you have entered the correct PIN number press connect.
9.From here your Bluetooth Headset should be connected and ready to use.
NOTE:Fully charge your bluetooth headset before syncing it to your iphone
Goodluck
Apr 16, 2010 | Samsung WEP410 Bluetooth Headset Wireless...
When I have my headphones in the volume works but when I take them out it dosn't work anymore
THIS MAY HELP!
For PSP Go owners, a very cool feature is the ability to pair bluetooth devices with the system. This recipe will show you how to toggle between outputting audio between the PSP Go’s speakers/headphone jack and a bluetooth headset/speaker.
1. Pair your bluetooth device with your PSP Go.
-Go to Settings > Bluetooth Device Settings
-Be sure to turn the Bluetooth Connection ON. Then select Manage Bluetooth Devices.
-Click on Register New Devices; put your headset into pairing mode and pair it with the PSP Go by following the onscreen prompts.
2. Once your headset/device is paired. Be sure to leave the Bluetooth Connection on.
3. Finally, open up the music player or a game and when you want to switch between the PSP Go’s speaker or your headset, just hold the Audio button on top for about 7 seconds. It will change the volume icon w/a bluetooth icon and audio on your PSP Go should start outputting via your headset.
To toggle back to speakers/headphones, again hold the audio button for about 7 seconds and it will switch back.
This should work with any bluetooth headset and does not require it being a stereo headset (ie any $5 headset should work).
Mar 26, 2010 | Sony PlayStation Portable (PSP) Console
My phone
Pairing your Cell Phone to your
Bluetooth Headset:
(FROM Bluetooth Headset)
1. Make sure Bluetooth Headset is fully charged!
2. Hold down talk button (center button of headset) up to
(Five) 5 seconds, then WAIT until you see a solid blue
light then immediately flip open earpiece part of headset.
THIS MEANS the HEADSET IS NOW IN PROGRAM MODE.
AT THE SAME TIME/ WHILE BLUETOOTH
IS STILL OPEN & IN PROGRAM MODE….
(FROM CELL PHONE)
1. Click on “Menu” (Left Button)
2. Scroll to Bluetooth icon. (Lower Right Hand side of menu)
3. Click “Ok” button
4. Then click on “My Devices
5. Click “OK” again
6. Select “FIND NEW”: Cell phone searches/connects to pair up
with Bluetooth Headset.
7. Once your Cell phone discovers your new headset, select
ADD” or click on the recently paired headset device.
8. You will then be prompted to enter a pairing code.
Use either..
a. 0000 or
b. 1111 or
c. 9999
Congratulations on paring/ connecting your new
Bluetooth Headset
w/ to your new Cell phone!
Jan 16, 2008 | Kyocera Switchback KX21 Cellular Phone
Radio Communications Logo
225 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
