Question about AudioSource SW 8 Speaker
Capacitors on klipsch sw sub have failed - AudioSource SW 8 Speaker
I have the Klipsch Sub-10 Subwoofer, and it no longer plays music. Now it hums (vibrates constant) and corresponds (louder or softer) with volume control. Light is home but no one home situation. V
Does the subwoofer have the same hum when the input cables have been unplugged? Many input cables use very fine conductors, which often fail. A bad cable will often introduce a hum and prevent a signal from getting through. If the noise is still present without the input cable(s) connected, then repair options are limited. No schematics are available. There's a daughterboard that has been available, but its failure usually causes the system to die (short-circuit). The cost to repair the amplifier may be close to the cost to replace the entire sub.
Sep 14, 2014 | Klipsch Synergy Sub-10 Subwoofer Speaker
How to open klipsch sw-350
Go in from the sub plate on the back panel.
and then flip over and remote the driver, followed by the corner screws under the feet for the bottom plate
6f00ffda-6987-44cc-80b5-02c75ab512b6.jpg 47513548-8ca1-4eef-9d55-c6a300175a8c.jpg
Sep 05, 2014 | Audio Players & Recorders
Asko repair melbourne
it's more likely the amp, which klipsch provides as a complete unit.
Apr 08, 2014 | Klipsch Audio Players & Recorders
Klipsch sw 350 subwoofer not working in auto on off position
The audio signal on the subwoofer output of your amplifier turns on the subwoofer after a brief delay to prevent "popping". Sometimes you have to crank up the gain to turn on the sub, then turn it down to a comfortable level. If this approach does not produce results, there may have been a component failure in the input circuit.
Jan 14, 2014 | Klipsch SW-350 Subwoofer Speaker
The Fuse blows as soon as I turn the Sub on
Maybe power amplifier end module broken this could be an powerpack ic or transistor output stage cause of shortcircuit or even bad capacitors.
Oct 26, 2013 | Klipsch Sub-12HG Synergy Series 12-Inch...
I have a Pioneer VSX-1123-k receiver and a Klipsch SW 450 subwoofer and the connection is not clear. Can anyone help?
Should be an rca connector on the back of the receiver marked subwoofer or sub preout. connect that to the rca connector on the sub and it should be good to go.
Sep 26, 2013 | Pioneer Audio Players & Recorders
My klipsch sw112 sub stop working and know when i turn it on it just makes a clicking sound the led light flashes on and off
The sub amplifier circuit is probably damaged and the protection circuit takes over. Have a qualified electronics technician take a look at it.
Oct 13, 2012 | Klipsch SW-112 Speaker
KLIPSCH SUB WOOFER SW350 PARTS
you can order it on internet either asking the electronic companies, i tried that years ago found in usa a company which gave me a direction of a ic production company of tailand - ad the end it leaded again to a company near tepic where everybody were looking for .and here we go just right on front of the electronical ingeneur which said here in the whole country is nothing.
Apr 17, 2012 | Klipsch Sw-350 8-inch 350 Watt Subwoofer...
Cant get klipsch sub woofer to work. do is there a menu setting through receiver to do this?
What model is the sub? Is your Klipsch sub powered? If it's already plugged in and powered on make sure you have the RCA cable going to the correct LFE output on the Denon and have it set to 5.1.
Jan 03, 2011 | Denon AVR-1601 Receiver
AudioSource SW 8 Speaker Logo
Top AudioSource Audio Players & Recorders Experts
Josh Whitehead
Josh Whitehead
 Grubhead
Grubhead
Andrew Taylor
Andrew Taylor
Are you an AudioSource Audio Player and Recorder Expert? Answer questions, earn points and help others
