Question about Pioneer VSX-D466S Receiver
POWER OFF FLASHES THEN TURNS OFF
RECENTLY I HAD TO REPLACE THE FUSE ON THE RECIEVER AND AFTER THAT IT START SAYING POWER OFF IN THE DISPLAY AND SHUTS OFF BY IT SELF IS IT WORTH FIXING
2 Suggested Answers
  • 162 Answers
SOURCE: after turning on my reciever
check your speaker connection. if that doesn't work check your fuse to make sure it's good.
Posted on Mar 03, 2011
PDP - 436PG display turns off then straight off and the red standby flashes 3 times, pauses then repeats
That is an error code that likely means power supply issue and based on brand not likely to be a do it yourself fix. Consider having a authorized Pioneer service center look at it and get an estimate.
Nov 05, 2012 | Pioneer PDP-4360HD 43 in. Plasma...
Shuts off then red light indicator flashes, disconnected all speakers but still wont work
Hi, this is a power board issue. remove the cover and make sure that this unit doesn't have blow fuse. if the fuse is fine, you will then need to replace the integrated power/ main board.
May 21, 2009 | Denon AVR-1803 Receiver
When I turn on my receiver, it automatically turns off and the power button flashes red. Prior to shut down, the receiver display notes "Tuner Ext. In" What's the problem? It has worked p
Protection circuit turns off the unit because of critical conditions- wrong power supply voltages or one of the power amplifier channels is bad. First, visual inspect the power amp board near the heat sink for burned resistors, test outputs for a short. If there are no problem you may try to turn the unit on and you have several second before it shuts down to check power supply voltages and power amp output voltages and bias, then ... Long story you'd better take it to a repair shop or repair at ebcelectronics.com
May 09, 2009 | Denon AVR 2808Ci Receiver
Turns off when i turn it up
Does it power back up after it shuts down, if it does power back up it is unlikely it is an internal fuse, you would need to replace the fuse if that was the issue, could be an amplifier overload, check the demand your speakers require in watts, and be sure the right ohm speakers are being used, many receiver will display "overload protection"and shut down, and some just un-power to prevent a electical short from occuring.
Feb 02, 2009 | KLH R3100 Receiver
Other uses
Sure just be carefull how much power you put into them!
Please rate this answer!
Aug 10, 2008 | JVC MX-GT88 CD Shelf System
My denon reciever display wont't work
I read something the other day in the user manual about re-setting the microprocessors if the display doesn't display properly. Turn the amp off.  Hold down the input mode & analog buttons while turning power on. The whole display should flash on & off at 1 sec intervals, then release the two buttons. This resets the microprocessors & supposedly fixes display problems.
Jun 23, 2008 | Denon AVR-2805 Receiver
Reciever not working
Are all the speakers GOOD and all connected right?
If so then you have at least one blown output amplifier module.
Feb 16, 2008 | Sony STR-DE345 Receiver
Has power but no sound
it could be a fuse, i would check that for sure. i would also look at the stereo speakers for fuses there. i have seen some that fuse at the speakers. I would unplug from the wall and allow to cool down. Thermal fuse will reset itself. see if any of that helps.
Dec 27, 2007 | Panasonic SC-AK18 CD Shelf System
Shows to be stuck in Standby.
hold down the enter button and the advanced surround button for 5 seconds or so and the amp will restart, the display will come up and hopefully it will be ok. its often caused by using speakers under 8 ohms, or damaged speaker cables etc
Mar 20, 2007 | Pioneer VSX-D712 Receiver
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
