Question about Makita 6408K 3/8" Variable Speed, Reversible Drill with Case
Makita 6408 drill motor. can't see how to replace the chuck.
I need to replace the chuck on my makita drill motor but can't see how to remove it. there doesn't appear to be a set screw on it and the shaft is straight splined. i have purchased a replacement part but it is threaded.
  • 2,176 Answers
If you have the 6408 as listed the spindle is threaded and you are correct there is no retaining screw. What you would need to do is find a bent handle allen wrench about the size of the chuck capacity 3/8" and insert the shorter end in the chuck and tighten. put the chuck on a block of wood or workbench and position the long end at about a 30 degree angle in the counter clockwise position and strike it with a hammer, this might take a couple hits. If this is not a 6408 let me know and I will look at the tool for you and see what you got.
Posted on Jan 23, 2009
  • 90 Answers
Some makita drills have a wrong way screw in inside the chuck. turn your screw driver like you would normally tighten a screw. when that is removed the chuck will unscrew from the spindle. use the large allen wrench and hit it hard to loosen the chuck. when i put the new chuck on i would put neversieze on the screw and the spindle. they will rust together and then you have to cut them off.
Posted on Aug 29, 2010
Check out the user reviews of this item on Amazon. One of them says he unscrewed the chuck.
Posted on Mar 11, 2009
Changing the chuck of a 6408 makita electric drill
Open the chuck and remove the screw inside the chuck (if fitted) the screw is left hand thread, fit the short end of the largest hex key that will fit into the chuck and tighten the chuck, put the drill into low gear and turn the clutch to the drill position, support the drill on a bench and strike the long end of the hex key with a firm blow (right hand thread) it may be neccessary to strike it more than once
Jan 30, 2013 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
How can i replace the keyless chuck on my makita
I answered that question already on another post, but if you need to know how to remove the chuck I have detailed instructions in the TIP SECTION on how to do this. Let me know if you need more help
Dec 31, 2011 | Dewalt Makita Bhp452 18v Lxt Lithiumion...
Removing the Chuck on a Makita 3/8 Corded Drill
did you remove the chuck retaining screw first?? you are on the right track with the hammer and wrench you might have to hit it a couple times
May 07, 2010 | Makita Drills
I have a 12v makita drill and cannot remove the chuck i have removed the screw inside the chuck. lease help
The chucks on most drills are left hand thread. To be sure which way to turn the chuck check the screw the chuck will turn in the opposite direction.
Mar 29, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
How do I remove and replace the keyless chuck on a makita hp1621F?
Remove the screw inside (clockwise)
mount a big Allen key in the chuck ,shortest part inside the chuck,
hurt the key with a hammer to make tre drill move counterclockwiseto unblock it
Nov 16, 2009 | Makita HP1621FK 5/8" Hammer Drill, 5.7...
Remove keyless chuck on a 12 volt makita drill
There should be a Screw in side the end of the chuck were u put the drill bit in u will have to undo it back wards its got a left hand thread
Oct 23, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Gripping tooth of drill detached
This is usually caused by a damaged spring between the gripping teeth. Might also be a damaged tooth. Easiest fix is replace the chuck.
Jul 11, 2009 | Drills
Damaged chuck
Grasp chuck, reverse it until fully open. Look inside where bit goes and should be an allen head or torque head screw holding chuck to motor arbor/shaft.
May 14, 2009 | Makita 5/8" 2 Spd Hammer Drill
Stuck chuck
open the chuck all the way, insde there may be a screw in the bottom it's lefthand thread turn it clockwise to remove, the chuck is also threaded, right hand thread. close the jaws on the short end of an allen wrench and strike the long end with a hammer to break it free
Apr 01, 2009 | Makita Usa Inc No.8390DWPE 18V Crdls...
Removing the drill bit from Makita bdf452.
try hitting the chuck with an hide mallet in the undo direction, it just needs shocking, to rease it
Feb 12, 2009 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Makita 6408K 3/8" Variable Speed, Reversible Drill with Case Logo
1,906 people viewed this question
Top Makita Drills Experts
epangan29
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
