Question about John Deere Garden
How to replace the alternator on a john deere sst16
John deere sst16 charging problem
  • 142 Answers
SOURCE: John Deer riding mower
http://www.deere.com/specsapp/CustomerSpecificationServlet?sbu=CCE&pciModel=L120%20GX&displayModelName=L120%20Lawn%20Tractor&tM=HO&pNbr=SKU20346
Here is a link to John Deere website for this model, it states that it has a 16 amp charging system. It also has the phone numbers listed for contact, and requesting the manuals for this mower.
Posted on Sep 20, 2008
SOURCE: how to replace belt on john deere 425
take a sharpy and outline it before removing
Posted on Jul 19, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
SOURCE: I would like a wiring diagram for a John Deere
I found the diagram.
Posted on Oct 20, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
I have a sst16 and the battery will not stay charged any suggestions as to what the problem could be. I can not find the fuses is there a diagram
battery will not stay charged Deloris, Have battery tested could be bad (lucky to get 2 seasons out of one). You have to see if charging when running with a digital volt meter. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to test small engine charging system battery alternator
Repairing the Charging System on John Deere 175 Lawn Tractor
Electrical System Troubleshooting for Lawn Tractors Mowers
Apr 03, 2016 | John Deere Garden
Why won't my john deere sst16 spin steer not steer in reverse?
I copied this right out of the operators manual for this machine, and it is a zero turn machine as well
" NOTE: Operating the mower while backing up is strongly discouraged. The Reverse Implement Option should be used only when operating another attachment or when the operator deems it necessary to reposition the machine with the mower engaged. "
an educated guess says they deactivated the steering in reverse
also I hope you have a supply of air filters for your steering valves for this model as ive replaced a few already for folks that have these
Nov 13, 2015 | John Deere Garden
John Deere 4100 Battery is not charging, have put in a new alternation. have replaced battery Any help please
Is the alternator putting out more 13-14 volts? Are all of the terminal connections clean and in good condition, and the wires to the battery as well?
Feb 22, 2015 | John Deere Garden
John Deere SST16 Riding Mower
have some one activate it while you feel it if you feel a click or movement its working if not its bad then get a volt meter set to 12 volts ceck the voltage going to it 1 ground 1 hot if its grounded to frame it may have only 1 hot wire when its activated
Aug 21, 2014 | John Deere Garden
I have a John Deere SST16. The mower steers fine until I engage the mower blades then it will not steer anymore.
sounds like there is an obstuction, maybe from the deck, or deck hanger interfering with steering components
May 07, 2011 | John Deere Garden
My SST16 starts easily but dies out when I turn the blades on. What can i do
Make sure the clutch stays depressed when you engage. Or check the safety switch.
Jul 24, 2010 | John Deere Garden
Garden Logo
240 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
