Question about Samsung PCN5425R 54" Rear Projection Television
Samsung 54" Projection TV (PCN5425R)
I was recently watching tv and all of a sudden the picture went blurry and then shut off on me. I thought maybe it was a fluke, turned it back on and it turned off within a second or two. I unplugged the tv for about a minute, tried to turn the tv back on and the red light on the front blinked a few times and then stayed solid. I called an electroni place and they said to count the blinks and it might offer some info on what the problem was, I counted, I think 6 at one point, but now it stayed solid. I am hoping this is a problem that I can fix myself, since the place I need to repair it at is an hour away and I only have a car....just won't fit. If anyone could help, I would appreciate it.
    Scholar:
  • 150 Answers
Sears does inhome service, if you do try to fix it, there is usually a board mounted to the back of the tubes (above the others), if it has this convergence board, try unplugging the red connector with the blue wire and turning set back on, if it powers with a 3d looking picture, you have a bad convergence module. Other than that you may want to call a repairman.
Posted on Jul 09, 2007
SOURCE:
I have a samsung dlp Model no. Pcn5425r The problem I am having is that the picture is all distorted with curved edges and blurry doubled images. I thought it was a convergence problem so I replaced it...
You don't have a color wheel in this model. There is probably a fuse blown that you missed or a resistor in the circuit outside the convergence IC's (STK 392-040). Did you press the perfect focus in the convergence part of the menu?
Jun 23, 2011 | Samsung PCN5425R 54" Rear Projection...
Problem with my Samsung PCN5425R 54 in. projection. I am seeing double and pictured is bowed and I see red and green colors on the screen. Is this the convergence board. Is this difficult to fix? I am not...
Your convergence ic’s have failed, this is a common problem with most all projection tv’s, the repair is involved. I suggest in your case calling a local repair shop.
Sep 01, 2009 | Samsung PCN5425R 54" Rear Projection...
Convergence problems
Did you buy the board new or used? It could also be your convergence Ics and not the convergence that is causing the shutdown . The convergence ICs are not located on the convergence Board.
May 21, 2008 | Samsung PCN5425R 54" Rear Projection...
Samsung Rear Projection screen went out.
MrPeab,
Where did you purchase the convergence amps previously? Your set takes two STK392-040 Sanyo amps and there is a high probability that that is the problem here again. The convergence amps for these units are really critical and chinese knock-offs are abundant. Is it possible that you didn't get Sanyo originals?
Another thought is what about the heat sink used when they were installed? Did you do the installation or have it done professionally?
Bill
I doubt seriously that unplugging the unit will have any affect.
Jan 30, 2008 | Samsung PCN5425R 54" Rear Projection...
Blurry picture
you probably have a bad convergance board you can get one at partstore.com but if the color is realy out of wack you will need the board it is very easy to install even for a novice unplug the set take off the lower back hte board is on the upper right only one screw and a couple of plugs but first try to adjust the lens have someone watch and loosen the wing nuts and turn the lene,s slowly one at a time i started with the red one you need to have the set on when you do this i replaced the board first works great now
Nov 12, 2007 | Samsung PCN5425R 54" Rear Projection...
Tv problem samsung PCN5425R 54 in.
Very easy repair....Just replace the convergence amp board part# BP95-00142E (about $80) It includes both convergence IC's and associated components (Five connectors,one screw,easy access)no soldering...
Sep 20, 2007 | Samsung PCN5425R 54" Rear Projection...
My 54" PCN5425R TV will not turn on
You will need to locate the convergence amp IC's, the STK392-040, and replace both of them. The originals IC's can be ordered here http://www.mcminone.com/search.asp?keyword=STK392-040&btnSubmit.x=4&btnSubmit.y=6 Good Luck
Jul 25, 2007 | Samsung PCN5425R 54" Rear Projection...
Convergence: concave picture with double image
An easy replacement on the Samsubgs is to replace the convergence board. If you are doing this yourself it is just a plug in board. Here is a link for the part number and how to purchase it. http://www.partstore.com/Part/Samsung/Samsung/PCN5425/Samsung/Samsung/BP9400383A/New.aspx
Apr 09, 2007 | Samsung PCN5425R 54" Rear Projection...
Pcn5425r black screen
possibly other problems on the deflection board your scaned derived voltages are probably missing when a flyback goes it almost always takes out other components or b+ voltages/g
Feb 02, 2007 | Samsung PCN5425R 54" Rear Projection...
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
107 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
