Question about Dishwashers
Frigidaire dishwasher LGHD2433KM1 will not run
Error message ou
I need to know what the error code pf means for a frigidaire gallery model #fgh202465nf1a
Hey Carol, I understand that you are receiving an "PF" error message on your Frigidaire Dishwasher. Typically this error code indicates a power failure. Before considering contacting a service provider, I would recommend resetting the dishwasher by turning off the power to the appliance for about five minutes. After the five minutes return power to the appliance, this should allow the appliance to return to working condition. At this time if you find the problem still persists, you may want to consider contacting a professional technician. The concern could be the control board. Hope this helps! -JK
Oct 11, 2015 | Frigidaire Dishwashers
My Frigidaire dishwasher displays a CO code and won't run. Why?
Good Afternoon Jodi, thank you for your post!
Based off what you have described your Frigidaire dishwasher is displaying an error code "CO" and will not run. An error code of "CO" may be a miscommunication within the control panel and you can clear that error code by disconnecting power from it for roughly ten minutes. If you continue to experience an issue with your dishwasher I would suggest contacting a professional technician for a diagnosis to be completed. I hope this information is helpful. -Matt
Mar 05, 2015 | Frigidaire Dishwashers
Have an FO error on frigidaire dishwasher. anyone knows what this error means?
Hello Ermellina, thank you for your post!
If you are getting an error code "F0" on your Frigidaire dishwasher, it usually means that you are experiencing an issue with the water level. To clear the error code, you can reset your dishwasher. However, since you have already turned off the circuit breaker, at this point, I would recommend connecting with a professional appliance tech for a clear-cut diagnosis. Best - Z
Sep 14, 2014 | Frigidaire Dishwashers
Error message how to check for codes
Good Afternoon Friend,
I understand you are getting an error message and want to know how to check for the codes on your Frigidaire dishwasher, model# PLD3460. You can take the kick plate off the bottom of the front of your appliance, and there should be a row of lights. One of those lights will be lit up and have a word on it stating what code is. Hope this is helpful.
-Best Regards-
WP
Jun 25, 2014 | Frigidaire 24 in. PLD3460 Built-in...
Message "er" and "uo" on front panel and slight bumping noise
The UO code on most Frigidaire dishwashers means that the vent at the back of the dishwasher is open (or at least the sensor is claiming it is open). Since this vent should be closed except during the drying cycle, the unit will not start. This avoids having the washer spray water into your cabinet during the wash cycle.
The vent sensor is an optical sensor that is inside the vent assembly. So there are a few places that could fail causing the error. First check the wiring and the connectors for the wires between the vent and the CCU (main control board). If there are any broken wires or corrosion the message may not be reaching the control board. Replace any faulty wiring. If the wiring is fine, try replacing the vent assembly. On some Frigidaire models, the wiring and the vent assembly need to be replaced at the same time. If that doesn't solve the problem then the control board needs to be replaced.
Please note: when I look at the parts for the FDB1050REC0, I found a static dryer vent, http://www.appliancepartspros.com/frigidaire-static-dry-vent-154433001-ap3214620.html . Please make sure that you are buying the parts for the correct model dishwasher.
I hope this helps.
Dec 17, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
My dryer runs but will not dry I have a error message ad.
Here is a tip that will help you with how to clean that dishwasher up and get it smelling good again...
Dishwasher Maintenance
heatman101
Jul 02, 2011 | Frigidaire Electric Dryer
Frigidaire 4000 series dishwasher error code
This is likely an indication of a problem with the circulation pump motor under the dishwasher like maybe a bad circulation pump motor but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for Frigidaire Dishwasher Parts: http://www.repairclinic.com/Frigidaire-Dishwasher-Parts
www.RepairClinic.com
Feb 03, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
Top Dishwashers Experts
