Question about Canon PowerShot S1 IS Digital Camera
Difficulty in retracting lens
Hello, i have power shot S1IS camera since 3 years..it was absolutely fine till few days back when i came across a problem of not retracting lens along with making some different sound while getting started and it gets switched off by itself..i cant switched it off..i read it user's manual but my problem's solution is not given..i can turn it to playback mode but only one old snap it is showing other than that no other function is working..really dont want to lose my this precious gift of mine,given by my son.. so please help me out.. thank you..
    Problem Solver:
  • 19 Answers
It could be the battery is at the end of its life. try getting a new battery for it and trying agian. If this is not the case then it could be the camera has come to the end of its useful life (they are not built to last very long sadly) but try the battery and see what happens.
Posted on Jul 09, 2007
SOURCE:
Turns off right after startup chime lens does not retract
This can happen when you use a battery that is almost without charge. Please remove the battery and charge it, before placing it back. Then be careful not to touch the lens, till the camera has a chance to retract it.
After you place the battery the lens should retract.
If the battery is really charged. You should not think it is charged, because you had it on the charger till the light indicated battery full.
There is also a chance you stopped the lens while it was coming out. A sensor detected this. To avoid damage to the lens construction, the camera switched off automatically. Also remove the battery and after a few seconds replace the battery and switch on the camera. Careful you don't touch the lens again.
Dec 26, 2013 | Sony Cyber-shot DSC-H5 Digital Camera
Camera was on, working fine. When powering off, telescoping lens did not retract so lens remained extended just a bit with lens cover open. Waited a few minutes, turned it back on and I get the "access"...
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
Nov 20, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Model Power Shot S1IS - my view finder is blurred but the photos taken are clear. Did I touch the wrong button??
Next to the eyepiece is a diopter adjustment. This allows you to focus the viewfinder just for your eye. The camera lens is not affected. I can adjust the diopter and shoot without my glasses haveing to be on.
Sep 29, 2009 | Canon Power-shot S1 IS Lens Converter
Sony cybershot DSC-W170 lens malfunction
sounds like you have dust, sand of some type stuck in the retracting lense. Ive found someone to tell me to take out my batterys and SD card, then tap the bottom of the camera on a table top. Replace the batteries and power up. Doing this, I was told it loosens up the debri for the lense to retract to close and to open again.
Aug 24, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Lens stuck out, camera won't switch on, Canon G9
I have fixed my g9 twice with the lens problem. 1st time I dropped the camera on asphalt lens closed. Turned on, lens stuck and not forcusing or retracting. Solution was to press lens against a door frame and push as I turned off the camera...it worked. The next time,the lens was extended and would not retract I had to place the camera on its back on a book while I used a small block of wood and a small hammer. It worked camera is working fine. After both cases, it took about 5 shots to calibrate the auto focus.
Jul 07, 2009 | Canon PowerShot G10 Digital Camera
Lens will not re-tract
you need repair lens or change lens ,I can repair or i can sell this part okay
Dec 18, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
Lens does not retract in play back mode
Never buy a Canon camera again. I have the same problem, and sorry that nobody has a solution. This is the worst of the 3 Canon digitals I have purchased. Lack of a view finder makes it impossible to preview shot when outside on a bright day.
Feb 23, 2008 | Canon PowerShot TX1 Digital Camera
Canon Power Shot Pro1 will not turn on
A new camera will fix problem perfectly. LOL Did you drop it? Seem like there might be a short or something similar. Had U ever play the game "Operation"? This camera need it, of cause done by the pro. LOL
Sep 09, 2006 | Canon PowerShot Pro1 Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
46 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
