Question about Maytag SAV2555A Top Load Washer
MayTag Washer PAVT244AWW: How do I remove the front panel?
I have a MayTag washer model# PAVT244AWW. The belt broke and needs replaced. I looked at the bottom where the belt fits, and noticed a pulley was broken. There are two small pulleys on the right bottom of the washer. I need the pulley that is in the front. Can someone tell me how to safely remove the front panel?
  • Anonymous Mar 05, 2009
    same thing only mine stoped draining and when i looked at it it was the pully on the motor that was broken.
  • 7 Answers
SOURCE: Maytag washer Model MAV6000
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine, parts are not that expensive, 50-80for bearing kit, here is my site on how to do it
there is also a download for the repair manual
http://maytagwasherrepair.googlepages.com/index.html
Posted on Apr 08, 2008
SOURCE: Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Posted on Oct 29, 2008
appldoctom
  • 311 Answers
SOURCE: pulley broke
i am instructing on the motor pulley.it is plastic,get it off any way you can with out hurting the motor shaft.i think somtimes i would use large channel locks.you dont need to save any of it.
Posted on Jan 08, 2009
SOURCE: Maytag washer has black gunk underneath on pulleys and belt
replace the transmission
Posted on May 26, 2009
  • 82 Answers
SOURCE: broken e-clip
This is not an easy clip to put in. If you have purchased the thrust bearing kit (part number 12500036) to get the clip it will be helpful but may still be hard to get the clip in. The kit comes with another washer that is thinner, making it slightly easier to install the clip. The reason it is hard to get in; your brake (part num. 35-2948) has worn and as your brake wears the shaft raises and puts more pressure on the clip (which is probably why your clip has broken). I would advise to change the brake and thrust bearing kit. Even after changing both of these the clip can still be a problem to getting on. You will need to use a small screwdriver to pull the transmission shaft down and get one side of the clip in at a time. It is slightly easier with 2 people, one pulling the shaft with a screwdriver and the other putting the clip on. The only problem, changing the brake requires a specialty tool which is about $100. The tool relieves the pressure of the brake spring which is somewhere between 200-400lbs pressure. You may want to call the local repairman on this one unless you don't mind spending this much on a tool and take precautions to relieve the spring correctly.
Posted on Dec 13, 2009
Maytag centennial washer belt broke
There is no belt on that model you posted.
Jan 21, 2014 | Maytag Centennial MTW5800TW Top Load...
Maytag maxima washer won't drain
get to the back of the unit and take out the 2 screws on the back of the lid . remove the lid. look at the front electrical panel -remove the screws holding it in place. look inside the unit on the right and left side -- there may be 2 screws holding the front on - about 7 inches down. there may be two screws also at the bottom of the front panel. If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all. If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions. If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Jan 08, 2014 | Maytag Washing Machines
Maytag performa pavt244aww washer burnt rubebr and black pieces
Check with the belt off that the bowl will turn freely, if not check drum bearings or something caught between inner & outer bowl. Make sure when you fit new belt it is adjusted to the right tension or it will slip & burn.
Nov 24, 2013 | Maytag Performa PAV2200
Need to replace drive belt on a Maytag top loading washer (SAV571EEWW). Canto figure out how to get to it. Is there a diagram?
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-Parts/Model-SAV571EEWW/3048/0153200/M0512417/00004 If you see the two fastners marks #7 that is the key to removing the front panel to getting access to the drive belt. A putting knife pressed in on those fasteners will release them and allow you to remove the panel.
Jun 21, 2011 | Maytag Washing Machines
I have a maytag washer model# pavt244aww and it jumps all over the place while it is spinning. any ideas what the problem could be I cant seem to figure it out
There is a stabilizer bar that stretches across the back of the washer, and a pivot point in the right front corner. Both can be accessed through the back panel (tension bar) or top (pivot) of the washer.Look for one end of the tension bar having become disconnected, or the pivot point having become dislodged or broken.
Dec 10, 2009 | Maytag Washing Machines
Seized tub - Maytag pavt244aww washer
you may have a seized up pulley on your pump. this will burn the belt. also check the pulley on the end of the motor.
Oct 27, 2009 | Washing Machines
How do I take the front cover off a Maytag MAV4755AWW washer to change the belt for spinning the drum?
Although I'm not familiar with that particular model, most Maytag washers have the belts under the washer (no need to remove the front panel) --- just tip the washer back and check to see if the belts are underneath.
Jun 22, 2008 | Maytag Washing Machines
MAYTAG TOP LOAD WASHER
you don't say which model you have. one version uses two belts accesible by just tipping the machine back. Another version you must remove the front panel, and drop the pump and you'll be able to replace the one belt.
Jul 03, 2007 | Maytag Atlantis MAV7260B Top Load Washer
Maytag SAV2555A Top Load Washer Logo
310 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
