Question about Nuby (94040)
Can't open nuby nibbler - Nuby (94040)
What spare parts should i get
The rotary unit inside the head ,, the small gear set with transfers power through the head
Apr 16, 2014 | Metabo Kn6875 14 Gauge, 5.2 AMP 550 Watt...
Powermate nibbler won't work
Put some air motor lube oil in the air inlet and then hook up air supply. If that doesn't do it then open the motor to see if there is a stuck vane.
Dec 31, 2013 | Powermate Air Nibbler
Does Ace sell nibblers?
Sure. Check out the nibblers available on the Ace site: http://www.acetoolonline.com/Electric-Nibblers-s/1101.htm
Apr 24, 2013 | Cutter Tools
Where can I buy nibblers online?
Try this model from Amazon
http://www.amazon.com/Hitachi-CN16SA-16-Gauge-Nibbler/dp/B00005Q7BR/ref=sr_1_1?s=hi&ie=UTF8&qid=1358332173&sr=1-1&keywords=nibbler
Jan 16, 2013 | Cutter Tools
I don't own an air compressor. Is there another kind of power nibbler that isn't pneumatic?
Yes, there are electrical nibblers that work just as good as the pneumatic ones. of course, there are also handheld manual nibblers too
What is the thickest sheet metal that manual nibblers can effectively cut through?
they should be effective up to about 1/2" thickness. However, on softer metals you can probably go a little thicker, and on harder metals you might have to go a little under 1/2"
What is a nibbler?
A nibbler is a small tool used for cutting sheet metal without distortion.
I have nuby steam microwave sterilizer but have lost the instructions and dont know the amount of water to put in or the amount of time to put in microwave
I have this as well. Put 200ml in for 5 min. keeps bottles sertilized for 3 hours, and if you keep them in the nuby sterilizer it will keep for 24 hours. hope this helps :)
Sep 13, 2011 | Luv N Care Nuby Touch Microwave Steam...
Hello. I recently purchased a Nuby teether. It's 3 colorful keys with gel inside. I washed it & gave it to my son & the gel leaked out of the green key. As you can imagine, i am not happy about...
if they are individual keys they are just water filled and won't do harm, if they are 3 on a ring they are filled with purlic jel and same thing,, won't harm your child. you can contact their customer service at 1-800-588-6227 Please take a moment to rate my reply thank you Good Luck
May 04, 2011 | Nuby Toys
Nuby (94040) Logo
42 people viewed this question
Top Nuby Video Game Consoles & Games Experts
James Wishart
Are you a Nuby Video Game Console and Game Expert? Answer questions, earn points and help others
