Question about Coffee Makers & Espresso Machines
3group Wega Atlas Coffee Machine EVD/3 - Coffee Makers & Espresso Machines
3 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: wega coffee machine
Are you on Well water or distilled water?
If no then check the inlet solenoid valve, on the model of your machine it would be an electrical box with 2 pipe fittings on it, usually on the side of the machine.
Does the problem occur when the machine is turned off?
If yes then there is a leak either on the manual fill, or the exchanger in the boiler(happens when a machine freezes), or the inlet solenoid is leaking.
Does the pump run when the boiler is filling?
If the pump runs then the probe is calling for water and it needs to be replaced or cleaned with a wire brush, also check the electrical connector on the probe that could be damaged. If the problem is still happening then the auto level box is damaged.
Posted on May 16, 2009
mc1bean
  • 3053 Answers
SOURCE: I have a wega atlas compact coffee machine and I
Hello.
You cant really take the whole heads off, but what you can do, is take the screen off, if you look up in the head you will see a screw, most the time it is a flat head screw, and you have to use a small screw driver and unscrew the screw. You will find out that it is pretty stuck in there as the heat makes it pretty hard. But, if you can get the screens off, then you will notice the screen are pretty dirty. What i do a lot of times is order a couple extra screen as they are pretty cheep and every few months, replace them.Now my taking screen off and cleaning them, you will notice it will flow real good, but you cant really take the whole heads off, as then you will have o rings and other things to mess with, could cause more problems. Best thing is do your back flushing after you have taken off the screens and cleaned them and put them back on. Hope this helps, Mr Bean expert man, mike
Posted on Sep 05, 2011
Looking for a downloadable copy of a Pink Atlas sewing machine instruction manual. Any ideas?
I found a threading diagram for the Atlas sewing machine here: http://possumjimandelizabeth.com/xhtml/collect_sewing_atlas-thread.html . I found one manual for the Atlas Selectomatic for sale on Etsy: https://www.etsy.com/listing/158109125/pink-atlas-selectomatic-sewing-machine?ref=shop_home_active . (This person had another Atlas manual on Etsy but that has sold.)
Pictures of the pages of the manual for one machine are here:http://ataleoftwoquilters.blogspot.com/2014/01/atlas-sewing-machine-manual.html .
I hope this helps.
Jun 27, 2017 | Sewing Machines
I have problem with my Wega atlas espresso machine. When I turn on the machine water fills up but boiler doesn't heat and pressure doesn't build up. How can this be fixed?
Probably the boiler temperature or current fuse that blew. They are inline with the supply wires and usually clamped to the boiler. Easy and cheap to replace.
Dec 30, 2014 | Wega Coffee Makers & Espresso Machines
Water coming slow
filter plugged or pressure weak.
Dec 17, 2013 | Wega Coffee Makers & Espresso Machines
Im looking to source a wega Mininova espresso machine in SA?
Wega is good, generally, but avoid this Mininova. Tell me if you are looking to a home machine, or for commercial use. Either way, it proved unsuitable. We gave many Mininovas to scrap dealers, having made the mistake of damaging our reputation by promoting them.
Nov 12, 2013 | Wega Mininova EPU Espresso Machine
I have a wega atlas compact coffee machine and I would like to know if it is possible to take the shower heads off to clean them rather than just using a blind filter and back flushing.
Hello.
Sep 05, 2011 | Rancilio Classe 6 Espresso Machine
Coffee grinder is producing large granules
Adjust grinder to finer, if there are numbers on the adjustment knob, it is still possible to go past 0.
Apr 27, 2010 | Wega Mininova EPU Espresso Machine
Wega Atlas where is the boiler reset switch
Usually on the left side of the boiler just above the element, follow the wires from the element unitl you get to the red reset switch.
Jan 29, 2010 | Wega Mininova EPU Espresso Machine
I have a wega evd1 atlas; and there seems to be some sort of problem with the water not heating up at all. The steam wand is just shooting out water and the water is just coming out at normal temperature....
Hi The first thing I would check is a reset button on the boiler. The next thing would be to do a continuity check or Ohms check on the heating element. If you get no reading you have a bad element.
Jun 13, 2009 | Wega Mininova EPU Espresso Machine
No water through group head
The flashing lights is a no water error code. check water filter or inlet valve
Jan 01, 2009 | Wega Lyra
Wega coffee machine
Jun 28, 2008 | Wega Mininova EPU Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
