Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
Samsung rs20ccms fridge and freezer stopped working
Will not go to tempreture, trying to put right on digital panel will not go cold or freeze
  • minirobs Apr 13, 2009
    freezer is ok but fridge will not get cold! why????
I have come across this problem too and understand it is a fault with the back plate which Samsung have now modified.
Posted on Apr 15, 2009
CANNOT SET TEMPERATURE
Nominal tempretures for the refrigerator side are 36-38 degrees. Nominalk tempreture for the freezer section is 0-4 degrees. Your main board that controls your entire refrigeration can be found on this diagram as 1-5 http://c.searspartsdirect.com/lis_png/PLDM/50039314-00004.png
What tempreture are you trying to achieve? By setting the unit colder you also cause the unit to work harder as well shortening the lifespan of your refrigeration compressor as well as other key parts that perform to make your unit produce cold. Some key things to look for are any type of freeze up on the rear wall of the freezer which is termed as a defrost issue and if you do have this issue message me back and I can instruct you to solve this situation. I await your reply
Thank you,
Rick
Jul 01, 2012 | Samsung RB215LASH
Samsung fridge freezer SR2028CVW not cooling or freezing
If you have used it since 2004, it probably is worn out.
May 02, 2017 | Samsung Refrigerators
Fridge is freezing
there is a way to adjust it but its very difficult..best to just replace it. the thermostat that is.
Jun 09, 2009 | Whirlpool ED2FHGX Side by Side...
Samsung twin cooling fridge/freezer model Rs21dcsv Fridge temp control led display digit flashing and fridge not at right tempreture
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Jul 31, 2008 | Refrigerators
SAMSUNG RS20CCMS AMERICAN STYLE FRIDGE FREEZER
in the freezer section there is a 6 screws. unscrew them and remove the back panel. there will be 2 wires attached to the panels, remember where they go. you will see a metal evaporator which will be filled with ice. this is the problem. use a hairdryer to melt the ice. this is essential as you mustn't puncture the wall of the fridge with any sharp item. before replacing the panel ensure that everything is dry or ice will reform, and also ensure that the fan blades are turning properly or cold air will not be blown into the fridge.
May 22, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
SAMSUNG RS20CCMS SIDE BY SIDE FRIDGE FREEZER . THE FREEZER HAS STOPPED WORKING BUT THE FRIDGE STILL WORKS FINE
Defrost by turning off for 48 hours and the unit will work ok (for a while)
Its a design fault common to many Samsung Side By Sides
Mar 20, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Samsung RS2556SH
I have a samsung Refrigerator model No. RS2556sh. The Fridge temperature indicator is blinking at 38 degrees. What is the cause for it? How can stop it? Please anwser me through my email: alicezhang90@yahoo.comThanks.
Feb 06, 2008 | Samsung RS2556 Side by Side Refrigerator
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
1,027 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
