Question about Garden
Relacing fuel lines in a weedeater blower/vac
I'm replacing the fuel lines in my weedeater blower/vac. This particilar carb has a primer bulb. Just to be sure, what lines go where? The bigger line went to the top of the carb next to the primer bulb (I think). The smaller line was directly underneath that, just below the primer bulb housing. Is the smaller line the one that gets the filter and is fed all the way to the bottom of the tank? And the larger one just enters the tank about a 1/2'' or so right?
    President:
  • 1,990 Answers
Sounds Correct on this End.
Posted on Jan 23, 2009
Ryobi instruction manuals
The primer does not necessarily need to work for the unit to run. It does have a choke to aid cold starts. However it is a good indication of something wrong in the fuel system. A primer bulb that does not return to shape or does so slowly indicates a clogged screen in the carb. Check the fuel filter and fuel lines. Replace the fuel lines if they are stiff or discolored, rebuild the carb and replace primer bulb.
Aug 29, 2014 | Ryobi Blower Vac 205mph Leaf Blower Or...
Husqvarna problems
No, it is a return line to the tank from the primer. It sounds like the hoses are reversed. The fuel should flow from the tank via the main fuel line (with the filter)( sometimes the main line is smaller than the return line) to the carb, fills the carb then to the primer bulb, and from the primer bulb back to the tank. With just enough fuel in the tank to cover the fuel filter start pressing the primer bulb. Check for fuel coming out the short hose into the tank. If instead the bubbles come out the filter and the primer goes dry try reversing the lines at the carb and/or the primer bulb and try again until you get the proper flow pattern.
Aug 29, 2014 | Husqvarna 125bvx Hand Held Blower Vac
What would be wrong with my weedeater when i press the primer bulb gas will start to come out of the gas cap ?
You could have a clogged tube from the primer into the carb, but it also sounds like the fuel tank is overfilled.
Jul 14, 2014 | Fuel Line & Primer Bulb Repair Kits 2...
Blower will not prime and start
Primer bulb has hole in it or fuel line cracked.First use needle nose pliers to crimp fuel line just before primer ,dont use to much pressure and see if bulb will hold vacuum when you press it.If it wont hold vac either buld has hole or valve in primer is defective.If it does then you need to crimp off fuel line feeding carb and see if primer holds vac.If it does not then you need to replace powervalve inside carb.
Nov 16, 2009 | Homelite Garden
Where do you put the line from the gas tank I have A mcCulloch weedeater the tank have two lines it all so have A primer
One line is a return line short, the other is connected to the filter and to the carb fuel intake. The primer bulb will not fill if they are reversed.
Oct 11, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
How to hook up a carburator on a weedeater with a primer bulb
Typical fuel line routing2.gif is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Sep 18, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Apr 22, 2009 | Craftsman Garden
Leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Oct 25, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
1,746 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
